    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 raise to wake feature
    suunt9raise
    59 Posts 23 Posters 9.1k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • kabziorK Offline
      kabzior Bronze Member
      OK, so two questions:
      1. I do not have standby options fixed/adaptive/off, for me it is just simply on/off.
      2. How one does turn off light completely? Now I have standby off and raise to wake off, but light is still triggered by pressing any button. Can I turn it off completely?
      DMytroD 1 Reply Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @kabzior
        @kabzior 1. that’s because the picture is for s9p not s9: adaptive means using the sensor
        2. I think now you can’t, earlier it was possible with toggle, but now it’s gone
        kabziorK 1 Reply Last reply Reply Quote 1
        • kabziorK Offline
          kabzior Bronze Member @DMytro
          @дима-мельниченко thanks, regarding first one - that’s what i tought, but that’s ok.
          but the second one is a bummer, I go for long trekkings and often change between nav screen (with track) and ETA screen, but I do not need backlight, now I think battery efficiency will be lower due to the fact I cannot turn light off. I suppose it might be noticeable in 10-12h activity.
          DMytroD 1 Reply Last reply Reply Quote 1
          • DMytroD Offline
            DMytro @kabzior
            @kabzior doubt it. I never had my backlight on toggle and still was able to meet the predicted battery life. Granted I rarely train for longer than 3h in a row, but still…
            • zhang965Z Offline
              zhang965
              I’m very happy about this feature come to S9.
              but I just… don’t understand why it turns on the back-light on the moment where I don’t need it; when I need it, it doesn’t turn it on.
              last time, when I was running, I rise my arm to watch the time, the back-light is still off, so, I put my arm back, but I noticed the light is ON!
              so I raise my arm, and I see the light just turns off just before my eyes.
              Winners Wear Winners
              Brad_OlwinB 1 Reply Last reply Reply Quote 5
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @zhang965
                @zhang965 said in Suunto 9 raise to wake feature:
                If you raise your arm fast enough to hit yourself in the head you will see the watch lit:). Just kidding, I think the light is on for too short a time as well. I think if you experiment a bit you will get used to it. I often will raise my wrist then flick my wrist to see the data on the watch before the light goes out.
                Vector/T6c/Vertical 2 Ti
                • Tomas5T Offline
                  Tomas5 Gold Members
                  My wife was curious how this rise to wake works, so on suunto 5. In settings in backlight section i set standby to ON, rise to wake to ON. But it doesn’t work at all. I tried restart watch but no difference. I even disabled do not disturb, auto do not disturb and sleep traking as i thinked that maybe watch think i sleep already. But no luck. Rise to wake doesn’t work for me. Should i use some specific arm movement? Or just is enough to rise hand and turn wrist to direct watch at me?
                  Suunto Ambit 2 > Suunto 5 > Suunto Race 2
                  • DMytroD Offline
                    DMytro @Tomas5
                    @tomas5 this indeed should be enough. Maybe try exaggerating the movement a little?
                    Also could it be that the backlight is just dim and you don’t notice? Try in dark room?
                    Tomas5T 1 Reply Last reply Reply Quote 0
                    • Tomas5T Offline
                      Tomas5 Gold Members @DMytro
                      @дима-мельниченко you are right, it is too low intensity to notice in room where is light 😉 so it works fine. Is it possible somehow lower backlight when button presed to this lower intensity too?
                      Rob33R DMytroD 2 Replies Last reply Reply Quote 1
                      • Rob33R Offline
                        Rob33 Bronze Member @Tomas5
                        Raise to wake mode test: the lighting comes on very frequently only with the usual arm movements of running …
                        Similar experiences?
                        gerasimosG 1 Reply Last reply Reply Quote 3
                        • DMytroD Offline
                          DMytro @Tomas5
                          @tomas5 don’t think so
                          • Rob33R Offline
                            Rob33 Bronze Member @Dimitrios Kanellopoulos
                            @dimitrios-kanellopoulos Are there data on the loss of autonomy according to the choices offered?
                            • gerasimosG Offline
                              gerasimos Bronze Member @Rob33
                              @rob33 @dimitrios-kanellopoulos same problem…with simple movement on run (e.g. skipping) lights on very frequently(without turn wrist)
                              kinda bug or just high sensitivity…??
                              everything else perfect.
                              (s9 non baro.)
                              (Raise to wake mode test: the lighting comes on very frequently only with the usual arm movements of running …
                              Similar experiences?)
                              Suunto Vertical Ti
                              Suunto S9 gen1
                              Suunto Ambit3 peak
                              Rob33R S 2 Replies Last reply Reply Quote 4
                              • Rob33R Offline
                                Rob33 Bronze Member @gerasimos
                                @gerasimos It seems that many people wonder about this function … Lack of explanation?
                                gerasimosG 1 Reply Last reply Reply Quote 0
                                  @rob33 its a very useful and new function, need more time and daily tests from customers to check out …
                                  Just little patience and feedbacks and experts will solve it…(if it’s real problem and not an isolated issue)
                                  Suunto Vertical Ti
                                  Suunto S9 gen1
                                  Suunto Ambit3 peak
                                  isaziI 1 Reply Last reply Reply Quote 1
                                  • isaziI Offline
                                    isazi Moderator @gerasimos
                                    @gerasimos Dimitrios already said he’s collecting feedback for Suunto on the backlight behavior 🤟
                                    Blog: isazi's home
                                    Radu NegoescuR gerasimosG 2 Replies Last reply Reply Quote 1
                                    • Radu NegoescuR Offline
                                      Radu Negoescu @isazi
                                      I’ll add my two bits of feedback on this feature too - last night, while putting the kids to sleep, the light kept coming on. I’m on S9Baro, backlight off, standby on, raise to wake on. Let’s say that in last night’s scenario I can’t complain - the room was dark, it was 9pm, and it was working as expected.
                                      However, with it being quite reactive/sensitive to hand movement, I am wondering if it wouldn’t make sense (at least for us on S9B without adaptive settings) to take into account the time of day (and probably day of year / location) as a heuristic to determine if backlight is really needed. I don’t need it to react, even at low intensity, at 10am, but I would need it at 7am in winter months here in Europe.
                                      Dimitrios KanellopoulosD ? S 3 Replies Last reply Reply Quote 0
                                        Dimitrios Kanellopoulos Community Manager @Radu Negoescu
                                        @radu-negoescu use DND. Same applies to s9p.
                                        I use DND from 9pm to 7am
                                        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                                          gerasimos Bronze Member @isazi
                                          @isazi Dimitrios best of the best.💪 💪 💪 💪
                                          Suunto Vertical Ti
                                          Suunto S9 gen1
                                          Suunto Ambit3 peak
                                          • ? Offline
                                            A Former User @Radu Negoescu
                                            @radu-negoescu said in Suunto 9 raise to wake feature:
                                            Like garmin with “after sunset” mode for backlight?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
