    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 raise to wake feature
    suunt9raise
    59 Posts 23 Posters 9.0k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • grant28G Offline
      grant28
      I have downloaded new software but unable to make this feature work. Any suggestions are welcome
      • ? Offline
        A Former User @grant28
        @grant28 Please ensure both Raise to Wake and Standby are set to On.
        Full summary of backlight related changes can be found here.
        surfboomerangS 1 Reply Last reply Reply Quote 1
        • surfboomerangS Offline
          surfboomerang @Guest
          @nickk And make sure Do Not Disturb is off
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          Mouse CruiserM 1 Reply Last reply Reply Quote 1
          • Mouse CruiserM Offline
            Mouse Cruiser Bronze Member @surfboomerang
            @surfboomerang
            During exercise this feature working as it should, during normal wearing watch is not waking up backlight.
            Suunto Vertical
            Suunto 9 Baro
            Suunto Spartan
            Suunto Ambit3 peak
            • EgikaE Offline
              Egika Platinum Member @Mouse Cruiser
              @miš-kan read above - Standby light needs to be on to make it work in watch mode.
              A bit lacking logic imo.
              Mouse CruiserM 1 Reply Last reply Reply Quote 0
                Mouse Cruiser Bronze Member @Egika
                @egika if you rely only on logic, clear and precise instructions for use are completely unnecessary.
                Suunto Vertical
                Suunto 9 Baro
                Suunto Spartan
                Suunto Ambit3 peak
                  Dimitrios Kanellopoulos Community Manager
                  I hope the above helps a bit
                  Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                  Mouse CruiserM DMytroD Rob33R 3 Replies Last reply Reply Quote 6
                    Mouse Cruiser Bronze Member @Dimitrios Kanellopoulos
                    @dimitrios-kanellopoulos Thank you very much. That is aswer, that my logic can process.
                    Suunto Vertical
                    Suunto 9 Baro
                    Suunto Spartan
                    Suunto Ambit3 peak
                    1 Reply Last reply Reply Quote 3
                    • DMytroD Offline
                      DMytro @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos so what’s the difference between
                      standby off raise to wake on
                      and
                      standby off raise to wake during an exercise?
                      isaziI Brad_OlwinB 2 Replies Last reply Reply Quote 0
                      • isaziI Offline
                        isazi Moderator @DMytro
                        @дима-мельниченко that during exercise you have raise to wake backlight.
                        Blog: isazi's home
                        DMytroD 1 Reply Last reply Reply Quote 0
                        • DMytroD Offline
                          DMytro @isazi
                          @isazi If one refers to the picture, both scenarios have exact same description - almost word for word.
                          isaziI 1 Reply Last reply Reply Quote 1
                          • isaziI Offline
                            @дима-мельниченко you’re right.
                            Blog: isazi's home
                            • DMytroD Offline
                              DMytro @isazi
                              @isazi is this intended?
                              isaziI 1 Reply Last reply Reply Quote 0
                              • isaziI Offline
                                @дима-мельниченко probably.
                                Blog: isazi's home
                                • Brad_OlwinB Offline
                                  Brad_Olwin Moderator @DMytro
                                  @дима-мельниченко If you do not want raise to wake on all the time but only when you exercise, this is the setting. I imagine this might preserve daily battery life better than leaving it turned on all the time.
                                  Vector/T6c/Vertical 2 Ti
                                  • DMytroD Offline
                                    DMytro @Brad_Olwin
                                    @brad_olwin what I’m saying is according to the picture @Dimitrios-Kanellopoulos provided there are two combinations leading to the same result. I’ve checked and it is indeed so.
                                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                      Dimitrios Kanellopoulos Community Manager @DMytro
                                      @дима-мельниченко ideally the raise to wake should be disabled if the backlight is not set to on.
                                      There are with the backlight off 2 raise to wake options , that yes have the same effect. None.
                                      However once the backlight is set to something else those are 2 different options.
                                      • DMytroD Offline
                                        @dimitrios-kanellopoulos that disagrees with my experience.
                                        If standby is off and raise to wake is either on or exercise only, raise to wake is present only during an exercise.
                                        My setup:
                                        S9 non-baro, circuit training
                                        However I don’t think that my results are limited to either one of the above.
                                          @дима-мельниченко s
                                          According to the above picture when standby light is off raise to wake does nothing. Right ?
                                          If it works for you (I just tested and doesn’t for me) then it’s out of the specs so a bug right ?
                                          DMytroD 1 Reply Last reply Reply Quote 1
                                          • DMytroD Offline
                                            @dimitrios-kanellopoulos said in Suunto 9 raise to wake feature:
                                            @дима-мельниченко s
                                            I should think so.
                                            Probably, yes
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
