    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Incorrect GPS signal in the water workout
    7 Posts 5 Posters 1.1k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      temafey
      Hi.
      I noticed that when i use my Suunto 9 Baro in the open water (sea) i receive incorrect results, means completely incorrect. Usually GPS work good - during running, bycicle sessions. But in the water it works very bad. If you faced with this as well, how you fix it? or what to do in this case?
      Thank you in advance!
      surfboomerangS 1 Reply Last reply Reply Quote 0
      • surfboomerangS Online
        surfboomerang @temafey
        @temafey I think openwater swimming is one of the hardest sport to get a good GPS track as water blocks most of the GPS signal.
        Accuracy comes with the algorithms Suunto develops. I don’t think there is very much you can do to get better readings.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        DMytroD T 2 Replies Last reply Reply Quote 2
        • DMytroD Offline
          DMytro @surfboomerang
          @surfboomerang apart from one thing. You can buy a buoy. Then you get near perfect GPS, but you’d have to sacrifice other metrics bc watch isn’t on your hand
          • T Offline
            temafey @surfboomerang
            @surfboomerang i understand that GPS accuracy in the sea cannot be as good as running or bicycling, but GPS in the water shows me on time 600m distance, next time 40m, but distance all the time same. this is big difference i suppose
            Jamie BGJ 1 Reply Last reply Reply Quote 0
            • Jamie BGJ Offline
              Jamie BG Bronze Member @temafey
              @temafey could be due to wave hights, style of swimming, angle of hand in water- a variety of things.
              T 1 Reply Last reply Reply Quote 0
              • T Offline
                temafey @Jamie BG
                @jamie-bg even when i stay and preparing for swimming, start open water workout it shows me in a second 40m already i swam. no waves, yes different styles.
                pavel.samokhaP 1 Reply Last reply Reply Quote 0
                • pavel.samokhaP Offline
                  pavel.samokha @temafey
                  @temafey There a number of things to remember if you want to have better swimming track results:
                  • Water doesn’t transmit GPS signal so you can get track only if you’re swimming freestyle (crawl), not breaststroke or anything when your hands underwater for long periods
                  • Enable workout mode at least a couple of minutes before actual start so watch acquires best signal
                  • Do not make pauses in water during exercise. If you pause while you’re in water and your hands under water during pause - watch is losing signal. After you continue your swim it takes time before watch gets GPS fix again.
                  • Experiment with different GNSS combinations. While for running almost any GNSS is okay nowadays, it may have an effect for OWS.
                  • Try putting watch on different hand
                  • The only way to get perfect track/distance in open water swimming - is to use Swim Buoy and put watch in it.
                  These are mine recommendations, based on my experience. Suunto also has some on this page https://www.suunto.com/Support/faq-articles/lifecycle/how-to-get-more-accurate-open-water-swim-tracking/
                  Opinions expressed are solely my own and do not express the views or opinions of my employer
                  1 Reply Last reply Reply Quote 3
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
