    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    10 Posts 5 Posters 1.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      Ad1411
      Hello,
      Since the new firmware, my s9b is losing a lot faster than before.
      I soft reseted the watch.
      Does someone has this problem.
      For example: in a night from 90% to 75%. Watch not on my wrist.
      surfboomerangS J 3 Replies Last reply Reply Quote 0
      • surfboomerangS Offline
        surfboomerang @Ad1411
        @ad1411 I don’t see this behavior on my S9B after the latest firmware update.
        If soft reset the watch didn’t help. Try depleting the watch totally and then charge it to 100% to see if that helps.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        A 1 Reply Last reply Reply Quote 0
        • A Offline
          Ad1411 @surfboomerang
          @surfboomerang thx. I ll try that
          • J Offline
            jeromep @Ad1411
            @ad1411 Hello, i have the same problem and it is not the first time. Only one thing worked for me ==> hard reset (factory parameters). I will do it that evening and I hope it will works like the last time… Suunto does not work correctly on this suunto 9 ! 😞 maybe my last suunto watch.
            • J Offline
              jeromep @Ad1411
              @ad1411 Hello, for information the hard reset worked again. Only 3% in almost 24 hours
              A 1 Reply Last reply Reply Quote 3
              • A Offline
                Ad1411 @jeromep
                @jeromep cool.
                hard reset via suuntolink?
                J 1 Reply Last reply Reply Quote 0
                • J Offline
                  jeromep @Ad1411
                  @ad1411 Yes exactly. It is perfect since the last hard reset. “0%” that nigth.
                  • go-outG Offline
                    go-out
                    Hello @Ad1411 ,
                    I recently updated the Suunto 9 software on my watch from v 2.14.12 to v 2.16.25 and noticed some battery drainage as well. I would like to share my scenario.
                    It seemed that backlight was constantly turned on. Even when backlight was turned OFF in the shortcut menu.
                    I’ve checked some settings and every seemed oké. I’ve reboot the watch (12 seconds upper button) and reviewed the settings again. I played with power saving setting and noticed that the power saving turned of backlight. But this did not work for me, because I did not received notifications. At the end the standby setting within the backlight setting was turned ON. I’m not sure if I did that or it happened via the software update, but it is worth to share.
                    My settings (in bold the change that solved my battery drainage):
                    • Shortcuts: Do not disturb: OFF
                    • Shortcuts: Backlight: OFF
                    • Settings: General: Power Saving: OFF
                    • Settings: General: Backlight: brightness low, standby OFF, raise to wake: off
                    Please review your settings and let me know if you have the same scenario.
                    FYI @Dimitrios-Kanellopoulos
                    • Djordje SD Offline
                      Djordje S Bronze Member
                      Hello,
                      Definitely battery is lasting shorter.After update with same settings, cca4 days.
                      Before that 5 days.
                        Contacted support. They told me to send watch to their service center.I will turn off raise to wake option as it probably consume too much battery.
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
