    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Sunnto 9 with Polar OH1 or Verity Sense
    16 Posts 8 Posters 3.5k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • 7 Offline
      77alex77 Bronze Member
      Hello,
      Do you know if I can connect the Suunto 9 (or a Suunto 5) with the Polar OH1 or Verity Sense ?
      Actually, my wife uses the Suunto smart sensor with her Suunto 5 but she cannot put the belt exactly as it should be and the consequence is the sensor does not work properly (it works perfectly with me).
      I think the Polar OH1 or Verity Sense could be a way to manage this issue.
      Thanks for your help.
      pilleusP 1 Reply Last reply Reply Quote 0
      • pilleusP Offline
        pilleus @77alex77
        @77alex77
        Yes. no problems with both watches. 👍
        https://www.instagram.com/moves.are.life/
        Suunto Vertical Black Lime
        Suunto 9 Peak Pro Black
        Suunto Spartan Ultra Stealth Titanium
        7 1 Reply Last reply Reply Quote 1
        • 7 Offline
          77alex77 Bronze Member @pilleus
          @pilleus : thank you very much, much appreciated.
          What about the new one, the name is Polar Verity Sense. I have just seen it …
          cosme.costaC ? 2 Replies Last reply Reply Quote 0
          • cosme.costaC Offline
            cosme.costa @77alex77
            @77alex77 If it is bluetooth you shouldn’t have any problem.
            • ? Offline
              A Former User @77alex77
              @77alex77 i use the OH1 every time. Very easy to use. I put it on the inside of my front arm where the skin is thinner.
              The new one do the same just with a better battery 24h instead of 12h. And better range for bluetooth
              • 7 Offline
                Hello and thank you for the answers. I have ordered one, I will report here how it works.
                cosme.costaC 1 Reply Last reply Reply Quote 1
                • W Offline
                  wakarimasen Gold Members
                  I’ve been using one for years - it’s the next best thing to a chest strap, especially for weight training. Hope it works well for you.
                  Suunto Race Titanium
                  Suunto Ambit3 Peak
                  Polar H10
                  Polar OH1
                    @77alex77 said in Sunnto 9 with Polar OH1:
                    I’m using the combo S9B + Polar OH1 for more than a year without any issues but charging it once a week and that the response is a bit slower than a chest strap. I mean the HR graph shape is correct but it is delayed some seconds, but I think is the same for all OHR.
                    isaziI 1 Reply Last reply Reply Quote 1
                    • isaziI Offline
                      isazi Moderator @cosme.costa
                      @cosmecosta I agree about being precise but a bit slower to react (it’s just a matter of seconds though) then a chest strap.
                      Comparing it with a chest strap I also realized that it is not that precise for some workouts, better than the wrist, but still if your arm muscles are moving a lot I still prefer the strap.
                      Blog: isazi's home
                      W inkognitoI 2 Replies Last reply Reply Quote 2
                      • W Offline
                        wakarimasen Gold Members @isazi
                        @isazi Totally agree with this. If you wear both at the same time, you can see the lag between a chest strap and one on the upper arm
                        Suunto Ambit3 Peak
                        Polar H10
                        Polar OH1
                        • inkognitoI Offline
                          inkognito Platinum Member @isazi
                          @isazi Yep. Optionally, one can also experiment with placing the OH1 on the leg. Or even use the headband and place it on the temple 🙂
                          SV: fingers crossed :D
                          S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                          Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                          Despite some pretty bad luck, I still love Suunto!
                            cosme.costa
                            I think the delay “can be” important for some people and not for others. For what I use it, running and trail running, the delay is not so important, if one day I decide to do some test where this delay it is important or more precise values are needed I would use the POLAR H10 that I also have and I’m using mainly for biking with a garmin 530.
                            I bought the OH1 because the H10 (the Suunto Smart Sensor too) were giving me bruises when I was running and sweating, and this bruises didn’t have time to heal between runs. With the OH1 I do not have this problem.
                            BTW, I always wear the OH1 in the upper arm.
                            • 7 Offline
                              Thank you all for your messages.
                              I have received the Polar very sense and tested it just a few minutes : it works fine. Tomorrow, my wife should run with it, I will tell you what I think versus the Suunto smart sensor she has used till now.
                              • 7 Offline
                                Hello,
                                After 1 hour of running, my wife has told me the Polar Verity Sense worked fine with her Suunto 5. She is very happy.
                                1 Reply Last reply Reply Quote 5
                                • 7 Offline
                                  Hello,
                                  I have bought a Verity Sense for myself and link it to my Suunto 9. I wear it on the forearm.
                                  After 4 trainings, I can tell you that it works really better than my Suunto smart sensor. I think the belt of the smart sensor is not compatible with my skin because after a while, or from the very beginning, the smart sensor provides wrong data. [I’ve tried all the recommendations provided by Suunto to make it working better but without any good results]
                                  With the Verity Sense, that works perfectly. The data provided are very consistent all along the training.
                                  My trainings are about 1h15 long and after 4, the battery of the Verity Sense went from 100% to 90% which is quite good.
                                  • BulkanB Offline
                                    Bulkan Moderator
                                    Thanks for sharing.
                                    The smart sensor works well.
                                    I’ve tried Wahoo, polar, Garmin, Suunto… and finally I like yo use the polar OHR, hH10 and the Suunto (the new one).
                                    When I want to use RR of HRV and an app and the watch with the same sensor the polar is my to go. If I go to swim I use the Suunto’s.
                                    Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                                    With your input, this post could be even better đź’—
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
