    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Treadmill distance too high in SSWHR Baro
    Scheduled Pinned Locked Moved Spartan
    34 Posts 6 Posters 6.5k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      Darren_M Bronze Member @Dimitrios Kanellopoulos
      @dimitrios-kanellopoulos said in Treadmill distance too high in SSWHR Baro:
      @slashas an how would that be precise? For example, my cadence is 90/180 no matter what speed (up to 7:00m/km). However, my stride varies.
      (playing the devils advocate here but I might be missing something)
      Doesn’t then this make the stride a variable and not something constant?
      If you have a milestone or a Stryd you will see this.
      I can provide screenshots if needed
      Strange because, running speed is the product of stride frequency (SF) and stride length (SL), and both are shown to increase when runners increase their speed. Anyway, putting the way the Garmin works it out to one side because the Garmin may be using a more complicated algorithm to produce stride length, it is average stride length, so maybe it’s sampling and looking for patterns rather than just raw maths. I obviously don’t have that information. I just know using stride length in the settings worked for me when on a treadmill. If you run on a treadmill at a certain speed you should be able to work out the error between watch and treadmill and add a number to a stride length setting to correct that error for next time. It will never be totally accurate, but it must be better than a 45% error.
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager @Darren_M
        @darren_m said in Treadmill distance too high in SSWHR Baro:
        If you take a look how stryd works or milestone you will see that your stryd length varies.
        That said I am full on with your proposal and unfortunately suunto does not have that except an automatic calibration.
        However back to our nice discussion if you do some research you will see that good running posture should have a stryd variance not cadence (stryd frequency).
        For example the faster you go the bigger the stride should be. If you go slower and instead of deacresing the stride you decrease cadence then you are overstriding. And that is not good.
        Anyways. I know there are plans in suunto for this but not in the very near future.
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          Dimitrios Kanellopoulos Community Manager @SlaSh
          @slashas said in Treadmill distance too high in SSWHR Baro:
          @dimitrios-kanellopoulos you are correct stride is variating depends on pavement and etc, but on treadmill it is almost constant.
          I am not 100% sure about this. Perhaps less variant but still my stats show differently.
          SlaShS 1 Reply Last reply Reply Quote 0
          • SlaShS Offline
            SlaSh Platinum Member @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos you can check my treadmill activities most of them are 54spm cause I set constant speed on the tradmill so my spm is always constant in most cases 🙂
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              true that but how about if that changes? I never use constant on TM.
              In a case of constant speed or same style lets set it like so everything is ok. It’s the happy flow in other words.
              • D Offline
                @dimitrios-kanellopoulos How accurate is the auto calibration method Suunto use? The OP has this massive error of 45% more distance. Is that kind of error common? That would be bad for those who run on them as part of their regular training plan.
                Dimitrios KanellopoulosD SlaShS 2 Replies Last reply Reply Quote 0
                  The calibration afaik happens based on GPS. So outside runs calibrate it.
                  The TM is an indoors device that shows you the pace and distance so I suppose (not really knowing) trying to match that with a watch will always produce an error so Suunto has not put effort into that.
                  That is because Suunto focuses on outdoors with it’s proclaimed FusedSpeed and not indoors.
                  In short, if you lose GPS you won’t want to have an “indoors” calibrated value dictating your speed but rather your outdoor calibrating value doing that.
                  As I ve read around even Stryd has some idoors issues with TM.
                  Might worth reading the :
                  Mysteriously Low Treadmill Pace
                  here https://the5krunner.com/2017/02/10/stryd-announcement-interesting-development-for-footpod-pace-and-treadmill-users/ and https://blog.stryd.com/2017/02/10/mysteriously-low-treadmill-pace-2/
                  also
                  https://www.dcrainmaker.com/2017/02/5-random-things-i-did-this-weekend-39.html#2-tunnel-testing
                    However, just to add, there is a request and work on manual calibration and setting the above factors from what I have seen.
                    But again perhaps I have to displease you as I am kinda sure it wont be on the next update.
                    • D Offline
                      @dimitrios-kanellopoulos Ok thanks. It doesn’t upset me at all. In fact if I’m even looking at a TM I’m either recovering from injury or there’s something pretty running on it, haha! I’m all for the outdoors when running, especially on the trail. I am injured at the moment and about ready to test the damaged muscle, so that’s how I got onto the subject. I’m also an Instrument Technician, so I repair, maintain & calibrate precision instrumentation, therefore I don’t like errors, on any instrument, in any mode.😁
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                      • SlaShS Offline
                        SlaSh Platinum Member @Darren_M
                        @darren_m for me on the beginning massive errors were thrown, but seems auto-calibration works it is now within 10-20% and I dont care much 🙂 as I am focusing on HR and time as doing warm up treadmill incline speed walk.
                          Speedy recovery man!
                          Regarding the upset I am the middle man here and sometimes my position has to bare bad news for example (not sure how bad this is but I have seen people attacking me personally in several forums like I am the only dev/headmaster/etc on Suunto). Perhaps this has become my complex. (Just speaking my mind out loud here). However this place looks more sane 🙂
                          • D Offline
                            For the benefit of the OP and his question. I tried the watch on the treadmill today, but only did 2 km to check my injured calf muscle. I was impressed with the results. I wound the TM speed up to 12 Km/h (5:00/km) which took 0.11 km to achieve and then start the watch. I stopped the watch at an indicated 2.15 km on the Treadmill. Here’s what the watch produced:-
                            I know this is only a short distance, and it’s only one test so it may not repeat, but if it did produce this kind of accuracy repetitively, I’d be fairly happy with it.
                              @darren_m to be honest I am surprised 🤩😀😮
                              J 1 Reply Last reply Reply Quote 0
                              • J Offline
                                Jonathan Schwarz Bronze Member @Dimitrios Kanellopoulos
                                @Dimitrios-Kanellopoulos any update on calibration for the treadmill? I did a run today with my Suunto 9 baro on Treadmill activity. Steady state at 12k/h (5:00min/km pace).
                                After 55min, my watch read total distance of 15km and a 3:54’ pace. I never cranked the treadmill above 12km/h.
                                Any updates on a way to manually calibrate distance on the treadmill?
                                Suunto Race Steel All Black -
                                Suunto 9 Baro (retired)
                                Suunto Ambit 3 Vertical Lime (retired)
                                Suunto App - Always latest version
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
