    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Treadmill distance too high in SSWHR Baro
    Scheduled Pinned Locked Moved Spartan
    34 Posts 6 Posters 5.9k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • aldnetA Offline
      aldnet
      I understand by the system Suunto is calculating distance indoor is aproximate but I don’t know what’s an acceptable difference
      Today I run 11km in treadmill (the machine gives me this distance, and also calculating by the speed I set up the treadmill) And the watch indicates 15,96, should I expect these difference too high?
      Or directly my watch is starting to became crazy?
      Anybody in the same situation?
      Suunto 9 Baro Black (2.11.38)
      Suunto App IOS 1.50.0 (8284)
      iPhone 11 Pro (iOS 14 Beta 4)
      Dimitrios KanellopoulosD SlaShS 2 Replies Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @aldnet
        @aldnet said in Treadmill distance too high in SSWHR Baro:
        Usual case. You can unfortunately not calibrate atm the distance or the run factor at the baro.
        I would not worry about that since it’s hard to match the distance with the threadmill due to a lot of reasons.
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        • aldnetA Offline
          aldnet
          Thanks for the information @Dimitrios-Kanellopoulos
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            No problem. Just for you info, even stryd has issues with uncalibrated threadmills.
            I would not worry and perhaps in some next update we can calibrate the Spartans.
            For now I would suggest to get a pod , or ignore and edit the activity distance. In the end you should always trust the threadmill.
            • SlaShS Offline
              SlaSh Platinum Member @aldnet
              @aldnet run outside with GPS some distance with the same manner as you do on treadmill and watch will calibrate to you, after treadmill distance calculation will be a lot better.
              Dimitrios KanellopoulosD aldnetA 2 Replies Last reply Reply Quote 1
                Dimitrios Kanellopoulos Community Manager @SlaSh
                @slashas said in Treadmill distance too high in SSWHR Baro:
                yep that as well. But in the same manner. That is why I said the threadmill sometimes (especially on gyms that they are overused and not maintained) can also be giving wrong distances.
                • aldnetA Offline
                  aldnet @SlaSh
                  @slashas wow, interesting. this is the same way Apple Watch suggest to calibrate. I will try, I have made some runs outside, let’s check if with time the difference decrease.
                  SlaShS 1 Reply Last reply Reply Quote 0
                  • SlaShS Offline
                    @aldnet for me for example watch shows around 15% more distance than treadmill, but I do not care much about it, as it won’t be spot on. If you want correct distance, pace and etc Footpod is your cure 😉
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                      but also ask youseld why would you do such an investment for just the treadmill. A pod is fine for bad GPS or tracka nd field but on treadmill the treadmill shows the distance and pace.
                      I use a pod for track and field but for treadmill I just run (since also the pod does not do it 100% right) and then I edit the activity in MC.
                      In this case I have all data ok
                      • aldnetA Offline
                        aldnet
                        Do you recomend some specific footpod @slashas ?
                        Suunto Foot pod is compatible with Spartan?
                          nope afaik. Perhaps stryd live ?
                          • SlaShS Offline
                            SlaSh Platinum Member @Dimitrios Kanellopoulos
                            @dimitrios-kanellopoulos how about milestone? Should be just fine for treadmill, stryd too expensive just for it…
                            What a funny thing with live that for additional 100$ you can buy FW upgrade and live becomes regular stryd without wireless charging 😉
                            • oeagleoO Offline
                              oeagleo
                              I have had an Addidas BTLE footpod, but decided to try a Milestone pod. After some discussion with Meir at Milestone, I discovered that these pods are calibrated at the footpod, in other words, you set your watch to be at 100, even, or no calibration. Then, calibrate the footpod in the app, and it is calibrated for whatever device you use.
                              I know this works, for I have used a calibrated Milestone footpod with a Fenix 5x, a Spartan Ultra, and now a SSWHRBaro, and they are all consistent over courses that I know the distance. At $30 it’s one heck of a deal. Oh, yeah, I bought mine. 🙂
                              It would be good to be able to import all of the metrics of the Milestone into the Spartan, for they do track stride length, ground contact, etc.
                              'Life should not be a journey to the grave with the intention of arriving safely in a pretty … rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”.
                              1 Reply Last reply Reply Quote 3
                              • aldnetA Offline
                                aldnet
                                Thanks for the suggestions.
                                @oeagleo so, which data synchronize Milestone with Suunto, distance and pace? something more?
                                • oeagleoO Offline
                                  oeagleo
                                  In my experience, judging from the inside walk I did yesterday, speed, distance, cadence, and pace show in Movescount after a “USB Sync”. The Milestone App also shows Ground contact, stride length, and foot strike data for runs. I don’t do run, as my knees don’t work so well anymore. In addition, the Milestone app shows graphs of Pace vs. Cadence, and Pace vs. Stride Length, and Pace vs. Ground contact time. Those would be nice to be imported into movescount, somewhat like the HRM-Run/Tri does for Garmin devices.
                                  • D Offline
                                    Darren_M Bronze Member
                                    The easy answer to this is to add a setting to the Treadmill sport mode called ‘Stride length’. Essentially this is just a mathematical multiplication factor. One pulse from the accelerometer multiplied by the stride length and you achieve a set distance. Accuracy obviously depends on the accelerometer. However, it’s worth seeing stride length come to the watch settings as it will get you fairly close if the sensor is any good at all. Relying on the watch calibrating after running isn’t really a fix because if you run with someone slower, or vary your pace significantly, or even run up hill during a run, you’ll change your stride length accordingly and that has to result in an incorrect calibration. Also, the watch could produce estimated stride length from runs with GPS i.e. by distance/steps=stride length. I know from my Garmin my exact stride length at different paces, and they repeat to within 0.01 metres. With this stride length info you could alter the number in the stride length setting to suit the type of treadmill training you’re doing that session. The more data collected, the more scope you have for reasonably accurate treadmill training at different pace. Should be easy to implement, surely?
                                      Dimitrios Kanellopoulos Community Manager @Darren_M
                                      @darren_m said in Treadmill distance too high in SSWHR Baro:
                                      The easy answer to this is to add a setting to the Treadmill sport mode called ‘Stride length’. Essentially this is just a mathematical multiplication factor. One pulse from the accelerometer multiplied by the stride length and you achieve a set distance. Accuracy obviously depends on the accelerometer. However, it’s worth seeing stride length come to the watch settings as it will get you fairly close if the sensor is any good at all. Relying on the watch calibrating after running isn’t really a fix because if you run with someone slower, or vary your pace significantly, or even run up hill during a run, you’ll change your stride length accordingly and that has to result in an incorrect calibration. Also, the watch could produce estimated stride length from runs with GPS, i.e. by (steps/distance=stride length). I know from my Garmin my exact stride length at different paces, and they repeat to within 0.01 metres. With this stride length info you could alter the number in the stride length setting to suit the type of treadmill training you’re doing that session. The more data collected, the more scope you have for reasonably accurate treadmill training at different pace. Should be easy to implement, surely?
                                      nice but why do you exclude cadence?
                                      • SlaShS Offline
                                        @dimitrios-kanellopoulos he already mentioned it by saying steps 😉 higher spm shorter stride length.
                                          @slashas an how would that be precise? For example, my cadence is 90/180 no matter what speed (up to 7:00m/km). However, my stride varies.
                                          (playing the devils advocate here but I might be missing something)
                                          Doesn’t then this make the stride a variable and not something constant?
                                          If you have a milestone or a Stryd you will see this.
                                          I can provide screenshots if needed
                                          SlaShS D 2 Replies Last reply Reply Quote 0
                                          • SlaShS Offline
                                            @dimitrios-kanellopoulos you are correct stride is variating depends on pavement and etc, but on treadmill it is almost constant.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
