    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto heart rate strap only works when pausing and un pausing the current activity
    Scheduled Pinned Locked Moved Spartan
    9 Posts 7 Posters 1.7k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • P Offline
      peringmar Silver Members
      Before starting an activity the watch finds my heart rate strap instantly. But when I hit record the heart rate will not be displayed correctly. It will display a low value regardless intensity.
      First when I pause and then unpause the activity the heart rate will show correctly. Does someone else have the same issue? If yes what watch are you using? Maybe this does not just apply for the Spartan and if you have the same problem, maybe try this trick.
      In the screenshot below is an example of the issue. For the first manual laps the heart rate is displayed wrong but at lap 6 after pausing and un pausing the watch it is displayed correctly.
      Could this be a bug?
      Here is a better image showing the problem.
      Suunto Spartan Sport WHR
      Suunto Race
      surfboomerangS BrunoHB 2 Replies Last reply Reply Quote 0
      • surfboomerangS Online
        surfboomerang @peringmar
        @peringmar I have never seen this with my S9B combined with HR strap. Just to be sure… the watch itself is also showing incorrect values or is it just SA?
        Is the watch displaying the correct heart rate before you start?
        Just some basic HR strap things you can try:
        • try wetting the contacts / apply contact gel
        • soft reboot the watch
        • remove / replace HR sensor battery.
        • re-pair the HR sensor
        • Try another sport mode
        • re-create your sport mode
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        P 1 Reply Last reply Reply Quote 0
        • P Offline
          peringmar Silver Members @surfboomerang
          First, thank you for the suggestions, but I have already checked most boxes due to this being a repeated problem for me.
          The watch shows the correct HR before start.
          To clarify, it is the watch that shows the wrong data during activity.
          Suunto Race
            Dimitrios Kanellopoulos Community Manager
            if its in the first minutes most probably its contact issue.
            This is what I had observed.
            Prestart -> all ok
            First x minutes -> bad
            PAusing helps. Perhaps the strap is not moving.
            In regards to that, please try to use a non nylon / polyester t-shirt / top. Maybe that creates static
            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
            • P Offline
              peringmar Silver Members @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos
              But what I find strange is that for this activity it did not find my correct heart rate for 6 minutes, but then a 2 second pause solved the problem.
              That is why I usually do this 2 second pause right after starting (just forgot this time) because otherwise HR reading won’t work.
              Suunto Race
              B 1 Reply Last reply Reply Quote 1
              • B Offline
                Bradleyd Bronze Member @peringmar
                @peringmar, I experienced this same funky low bpm count on a cycling commute yesterday using a Spartan Ultimate and a SmartHeart sensor. I’ve not seen this same low jump(s) using my regular commuting Ambit3 Sport watch with the same strap.
                Looking at the below image from SA, the heart rate before 0:12 minutes is absolutely too low, the jump to 137 bpm is a good correction and happened when I stopped riding to fiddle with the watch and strap, the jump to +165 bpm is wrong before the 0:20 mark, the remainder of the rates are fairly accurate.
                @surfboomerang , I don’t think this is an issue with wetting the strap or battery. The watch displayed roughly the same values I see in the SA time series.
                Adding my experience, since I had the activity sitting open when reading this post.
                Mff73M 1 Reply Last reply Reply Quote 1
                • Mff73M Offline
                  Mff73 @Bradleyd
                  @bradleyd said in Suunto heart rate strap only works when pausing and un pausing the current activity:
                  Spartan Ultimate and a SmartHeart.
                  Is it the new Suunto Model this Spartan Ultimate? 🤣😍
                  And how do you feel with such a Smart Heart? 😊
                  Hey, just kidding 😉😇
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  • BrunoHB Offline
                    BrunoH Gold Members @peringmar
                    @peringmar I’ve experienced something opposite of yours. In the beginning of an exercise my watch shows reasonable figures, but afterwards the Suunto App log looks like there’s double heart rate (way over 200 bpm) for a few minutes and then it finds the correct heart rate.
                    Compasses: M-311, A-10, SK-7
                    Diving: Finnlight Navy 90, Vyper
                    Sports: Metron, S7, S9B and Vertical
                    • J Offline
                      Jannas10
                      I’m having the exact same issue and with a Suunto 9 Baro, supposedly their flagship watch of a few years back. It’s not a heart rate strap issue. Before starting the activity the heart rate reading is accurate, the moment I start the activity the reading is 35% odd lower. The moment I pause the activity, the reading is accurate again.
                      Have you found a solution? It’s driving me mad. I feel let down by Suunto.
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
