    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B HF peaks during training
    12 Posts 4 Posters 997 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ReinerR Offline
      Reiner Bronze Member
      Dear experts,
      I’m using a Suunto 9 Baro for running since a half year.
      In the last view months i noticed a repetitive issue on the HF tracking:
      The HF jumps up from 145 to 220, stay a view minutes on this level, and falling down back to my normal level around 145-150. (straight track with consistent speed of course)
      I read topics here that some people had this failure sometimes on the beginning, directly after starting tracking. But not in my case. The peaks are spread over the entire training session.
      I tried different positions on both arms, also different strengths of the arm belt. No difference.
      To shut myself out I tried also a heart belt, my heart isn’t blowing to 220, the peaks are only on the watch. (lucky)
      I don’t know what I can try to find the reason for this issue?
      Slowly I guess there is a case for contacting support / warranty.
      Because the issue did not exist when used in the first mounts of my Suunto 9 experience.
      Below 2 examples.
      Best regards from Germany,
      Reiner
      (And sorry for my bad English)
      Watch: Suunto Race S
      • ReinerR Offline
        Nobody with experience on this topic?
        Just want to check here until i contact support at next step.
        cosme.costaC 1 Reply Last reply Reply Quote 0
        • cosme.costaC Offline
          cosme.costa @Reiner
          @reiner said in S9B HF peaks during training:
          Is this with the optical HR or using a chest strap?
          ReinerR 1 Reply Last reply Reply Quote 0
          • ReinerR Offline
            Reiner Bronze Member @cosme.costa
            @cosmecosta
            Only with the optical, never with the strap.
              cosme.costa @Reiner
              @reiner This has been discussed several times. With the S9, OHR is not very accurate, it works for some people but it doesn’t for a lot as well. For me it doesn’t work and I get readings like yours.
              You can try to wear it tighter using a Velcro strap (people that uses this strap say that there is a big improvement.
              I do not think that you unit is faulty. If you want reliable HR readings you should use a strap.
              ReinerR 1 Reply Last reply Reply Quote 1
              • ReinerR Offline
                @cosmecosta
                Thanks for your answer!
                I tried to messure the difference between optical HR and Strap when optical sensor delivers normal readings. From my experience there are only a couple percent deviation, for me as an amateur very okay.
                But this kind of peaks are kompletly wrong, unusable at all.
                I just had contact to support chat, they confirmed this as a malfunction to me, next step i have to tri, is a hardreset via Suuntolink.
                I only did a softreset bevore.
                • ReinerR Offline
                  Reiner Bronze Member @Reiner
                  I am very frustrated …
                  After hard reset the issue is still available.
                  Support told me everything is okay with my watch, because in the fist section of the training the result is valid. And the deviation on the end is triggered by me.
                  Yes, it seems that wetness by sweating could be a reason for the issue.
                  But – In the first 4 monts of using the S9B, this deviation doesn’t exist, and my current sweating isn´t another sweating than a half year before. On my current trainings, I noticed that a very little bit of wetness by sweating is enough to produce the malfunction.
                  I have the same wight, speed, skin, sweating, nothing changed like I bought this watch.
                  At that time the HR recording worked very well, and now the results are completely bad in every record.
                  Are there runners here whose watch delivers good results despite sweat/wetness?
                  D cosme.costaC 2 Replies Last reply Reply Quote 0
                  • D Online
                    dulko79 @Reiner
                    @reiner did you maybe change the position of watch on arm? Did ambient temperature change significantly in the last 4 months?
                    App: beta
                    Phone: Iphone
                    iOS
                      cosme.costa @Reiner
                      @reiner Do not get frustrated, really. The technology is what it is. I also do not think your watch is defective.
                      I do not know you but there are plenty of reasons that could lead to these “faulty” readings, like last four months we were in winter, so colder months and less sweating, maybe you have lost some weight and your wrist is thinner or your strap has got some elasticity and the watch now has more space to move…Besides S9B has never shined for its OHR. I only use the built in OHR for shorts walks or hikes and I have to wear it very tight to have some decent readings.
                      From what I have read from other people, the velcro strap for the watch helps quite a lot to improve the OHR, but it seems that is quite difficult to buy.
                      My recommendation is to buy a chest or OHR strap. I use the polar OH1 arm band, it is very comfortable and very reliable. For chest straps I suggest you to buy the Suunto one or the Polar H10 or H9.
                      ReinerR 1 Reply Last reply Reply Quote 6
                      • ReinerR Offline
                        Reiner Bronze Member @dulko79
                        @dulko79
                        Not at first, but when I noticed the deviation, I tried different positions. Shure, there was strongly temperature changes in the last mounth, my gues was the cold also. In the last weeks the coldness was gone, and i notice that the deviation was still there.
                        • ReinerR Offline
                          @cosmecosta
                          Wow! One of your recommendations could be a soloution. Because i always use the same holes in the strap on my trainings. I tried to fit the strap very thigt (contrary to the manual) and the results are clearly better. No persistent 220HR until today, i am very relieved.
                          Its realy possible, the strap has lost some elasticity.
                          To avoid a chest strap was the reason why i bought a HR watch. Bevore i was using a chest strap linked to my mobile phone. Sports Tracker since a very long time 🙂
                          I like the recommanded OH1 arm band, that could be a good alternative.
                          • A Offline
                            Albert Willem Knop
                            This sudden rise in HF but also dropping of HF during steady state training is something I see a few times per month. In training sessions I use the chest strap only. In the past it occured more. When changing to a Polar H10 chest strap the problem was gone for some time but it returned but in a lower frequency. Watch, chest strap and sensor were replaced by Suunto but gave no improvement. I never had these problems in my old Suunto T6c. I am now busy to get my Suunto T6c in working order again as I think it is a more reliable training watch. Partly as those very high or very low HF do not occur and also while the EPOC measurement/calculation is way better. In the Suunto T6c it increases and decreases in 1 unit steps. In the Suunto 9 it sometimes jump 5-10 EPOC units. This makes pacing of the training very difficult.
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
