    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    System update – PXDZ.210326.002.A2
    Scheduled Pinned Locked Moved Suunto 7
    101 Posts 25 Posters 21.1k Views 25 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • pilleusP Offline
      pilleus @Guest
      @flypg said in System update – PXDZ.210326.002.A2:
      that you have, into Developer Options, all the “… animation scale” set to OFF?
      No, factory settings and afterwards no changes at all. To be sure, it is not a custom setting which causes the problems with the Solstice watch face.
      In the meantime there are more users with this problem. May be it’s a location issue? Germany or Europe Central with problems?
      I experienced this with some WearOS apps concerning the weather forecast. No data for Germany available …
      https://www.instagram.com/moves.are.life/
      Suunto Vertical Black Lime
      Suunto 9 Peak Pro Black
      Suunto Spartan Ultra Stealth Titanium
      ? 1 Reply Last reply Reply Quote 1
      • Jamie BGJ Offline
        Jamie BG Bronze Member @Pierre Lellig
        @pierre-lellig
        If you expecting fenix battery life, then sell watch and buy fenix now. This isn’t an enduro fitness watch and no matter what you do, will never have similar battery life (look at S9B for a comparable suunto watch to Fenix).
        Full smartwatches (wear os, Apple Watch, Tizen) don’t have great battery life - +1.5 days normal operation is the norm, and +3days is excellent. Most only allow continous trackng battery life of up to 10/12 hours - S7 is the exception at up to 18hrs.
        When did you buy your watch and first use it? If last week/this week there are some standard issues that could be driving this issue - please refer to the S7 sticky in the S7 forum - it addresses all of these issues.
        Tiles/new features - sounds like you don’t have the latest update. Check you system version (pull down quick settings - swipe from top of screen down, then click on the settings cog, scroll to botton on list and press on system, scroll to bottom of list and press on about - scroll to build number - is it: PXDZ.210326.002.A2 - if not you need to wait for your system update for the new features (should come through in the next couple of weeks).
        PS - Right from left swipe should bring up tiles. It sounds like you are seeing some tiles. Long press on first tile, if a tile it should become smaller, scroll left to right until you get to a plus sign - press this to add tiles. When in this mode, pressing and holding on a tile and flicking/pushing it to top of screen will remove it from current tile list (you can always re add it). The arrows at the bottom move currently selected tile left or right in the list.
        Pierre LelligP 1 Reply Last reply Reply Quote 0
        • Pierre LelligP Offline
          Pierre Lellig @Jamie BG
          @jamie-bg
          I have it for 1,5 month (too late to send it back).
          Update has been done a few days ago (I’ve seen it)
          I’ve checked the version, it’s 002.A2 😉
          Jamie BGJ 1 Reply Last reply Reply Quote 0
          • Jamie BGJ Offline
            @pierre-lellig
            Ok - that is a good start.
            you have the info on tiles, also a good idea to read the sticky as excessive battery consumptions could be due to losing bluetooth connection (need to make sure android isn’t killing wear os app and hence you bluetooth connection). Make sure your play store is set to manual update (there have beeen loads of updates, these can drain battery hence I prefer to manage when I perform them so I can manage battery).
            have you tried restarting watch - can often solve battery glitches.
            What watch face are you using - some are much heavier pm battery than others, especially if have custom ambient screen settings (if so change to minimum for ambient).
            Are you using AOD on/off?
            What gesture settings are you using? I find that tilt to wake uses battery for me, due to my wrist movements, so have that off. Touch to wake on. If using a suunto face, am ok with power save tilt on, with AOD off - as even with my excessive wrist movement, its shows face in ambient so still using low power coprocessor and still lower consumption than @
            Are you using Gesture navigation?
            Is OK Google on?
            All of these can have a major impact on battery life.
            As a general rule with AOD on, touch to wake on, tilt to wake off, nav gestures off, recovery/sleep/24/7HR on, you should be between 2-3% battery usage per hour depending on watch face and usage (my normal is around 2.6%). With AOD off, suunto watch face, tilt to wake off, power save tilt on, touch to wake on, nav gestures off, recovery/sleep/24/7HR on I am getting just under 2% per hour. Prior to update i.e. without recovery/sleep/24/7HR on it used to be around 2% and 1.5% respectively.
            • SteffS Offline
              Steff
              I have a problem with Komoot integration.
              I linked my Komoot account in Suunto app, made a route in Komoot but the flag button for routes library is missing from my Suunto app.
              I’m I doing something wrong ?
              How can I import the Komoot route in Suunto app ?
              I’m using Suunto App 4.39 beta
              This is the missing button
              isaziI 1 Reply Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @Steff
                @steff what you show does not look like Android, I do not have that button either.
                Blog: isazi's home
                SteffS 1 Reply Last reply Reply Quote 0
                • EgikaE Offline
                  Egika Platinum Member @pilleus
                  @pilleus what you can check: in gestue settings, there are two switches.
                  1. tilt to wake
                  2. tilt to ambient mode
                  if the first switch is on, the second is deactivated.
                  While it is deacivated, maybe it is still on?
                  Then try to switch off 1. , then switch off 2. and switch 1. back on.
                  See if it has an effect?
                  pilleusP 1 Reply Last reply Reply Quote 0
                  • SteffS Offline
                    Steff @isazi
                    @isazi and how do you import Komoot routes on Android ?
                    I’m also on Android, that picture was taken from the dc rainmaker review.
                    • isaziI Offline
                      @steff have you checked the manual?
                      Blog: isazi's home
                      • SteffS Offline
                        Steff @isazi
                        @isazi yes, I checked, no mention about the Komoot integration introduced in the latest update.
                        All I found is this https://www.suunto.com/partners/komoot/ which only says “Just plan your route on komoot and sync with your Suunto watch to get started!”. No instructions on how to sync it.
                        I also check this https://support.komoot.com/hc/en-us/articles/360059177271-Connection-with-Suunto-Watches
                        I have the region unlocked, the tour saved in Planned tours but it still does not appear in the Suunto app
                        If I’m missing something please tell me.
                        • ? Offline
                          A Former User @pilleus
                          @pierre-lellig 10% in 30’ is a lot.
                          You can see on my previous captures.
                          2% drainned in 23’ fully connected, with all features actives and using the S7 during this time in the morning with the display ON.
                          @martin-vrska It’s automatic, the images started to display and change during the day.
                          @pilleus Sorry, my bad, I not note about Factory Reset.
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @Steff
                            @steff All you need to do is connect Komoot with the Suunto App, plan a route in Komoot. In SA under routes the Komoot route will appear and you can then toggle the route to load into the watch. That is it. Just saw your other issue on iOS. If you have no routes in SA, just draw a placeholder route, that should make it work. You need to be on the latest beta SA app as well.
                            Vector/T6c/Vertical 2 Ti
                            • SteffS Offline
                              Steff @Brad_Olwin
                              @brad_olwin Do I need a premium Komoot account?
                              Maybe here is the problem.
                              I have the free Komoot account with 2 free regions unlocked and the route is in one of them.
                              I double checked now and the Komoot route does not appear in Suunto app, Routes tab.
                              • pilleusP Offline
                                pilleus @Egika
                                @egika said in System update – PXDZ.210326.002.A2:
                                1. tilt to wake
                                Been there, done that. No effect. I tried all combinations before resetting the watch and afterwards too.
                                • SteffS Offline
                                  Steff @Steff
                                  @steff I made a few other routes in Komoot and suddenly they started to appear in Suunto app.
                                  The first created routes still do not appear in Suunto app but new routes do, so the problem it’s fixed.
                                  • pilleusP Offline
                                    pilleus
                                    Yesterday near sunset I got another picture now. Dimmed with the sun near the sunset point. The first time after four days. May be it was the first sunset this week … 🕶
                                    Just to be sure. This and the same dimmed screen at sunrise are the only changes to the background? Over the day there is only the blue sky in the upper half and the black area in the bottom half? No changes for rainy days?
                                    • EgikaE Offline
                                      @pilleus said in System update – PXDZ.210326.002.A2:
                                      according to my experience the pictures itself changes between sunrise (sun on the left - at least in northern hemisphere), day, sunset (sun on the right) and night.
                                      What also changes is the angle and height of the sun based on your latitude and day of year. It’s really gimmicky 🙂
                                      • I Offline
                                        ianharding @Guest
                                        @flypg Brilliant! The solstice background was black at least 50% of the time. Changed developer options to enable animations and now it’s in colour every time 🙂
                                        Martin VrskaM EgikaE 2 Replies Last reply Reply Quote 1
                                        • Martin VrskaM Offline
                                          Martin Vrska @ianharding
                                          @ianharding Where do I change developer options, please?
                                          Suunto Vertical 2 - Arctic Gray - 2.56.18
                                          Suunto Spark
                                          Suunto Vertical - Steel Black, Strap Canyon Orange - 2.37.34 - SOLD
                                          Suunto 9 Peak Pro - Titanium Sand - 2.22.60 - my wife
                                          Google Pixel 9a - Android 17
                                          Suunto App 6.12.7 beta
                                          • EgikaE Offline
                                            Egika Platinum Member @ianharding
                                            @ianharding that is strange, as those animations should be enabled by default and from the factory.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
