    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    System update – PXDZ.210326.002.A2
    Scheduled Pinned Locked Moved Suunto 7
    101 Posts 25 Posters 19.1k Views 25 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • SteffS Offline
      Steff @isazi
      @isazi I didn’t noticed that it is the beta version. Thanks
      • olymayO Offline
        olymay Gold Members @Stiniva
        @stiniva said in System update – PXDZ.210326.002.A2:
        Update HR and sleeping are great. Only i dont know battery is on 5% after 24h.
        And also Suunto face Solstice is black and white with numbers thats it… i dont know on videos on Internet i can see that face is in colour and you can see planet 🙂
        Great watch 🙂
        The watch needs to get your location in order determine sunrise and sunset times. Make sure you don’t have location services turned off.
        And of course, a restart of the watch never hurts 🙂
        Suunto 7 Graphite Copper
        Suunto App Beta (Android - Pixel 6 Pro)
        • pilleusP Online
          pilleus @olymay
          @olymay no third party app and a fresh installation after factory reset on the S7.
          I stay with the sleep tracking of the Skagen Falster 3, because it is smaller than the S7 and I have all data in Google Fit (heart rate is missing from the S7 sync).
          So the problem is solved.
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          olymayO 1 Reply Last reply Reply Quote 0
          • olymayO Offline
            olymay Gold Members @pilleus
            @pilleus said in System update – PXDZ.210326.002.A2:
            Strange. I would definitely contact Suunto support.
            Swapping between watches each day would drive me nuts!
            And by not tracking sleep in the Suunto 7 that essentially renders the new resources feature useless.
            HR isn’t syncing? Do you mean from sleep (which it should be) or during the day (which only syncs from the S7 during activities, unless you keep Google Fit tracking turned on)?
            As an engineer I would call this a problem ignored not a problem solved 😂 but whatever works for you 🙂
            pilleusP 1 Reply Last reply Reply Quote 0
            • I Offline
              Ironhorz
              Any advice on forcing this update? I picked up my watch from REI yesterday and I cannot get it to download anything…it’s currently stuck on the Jan 2020 update: PXDB.200111.001.A2
              I tried countless times yesterday and today to force the update, but no luck trying the following:
              • watch on charger trying to manually pull the update
              • watch off charger trying to manually pull the update
              • Bluetooth off and WiFi on with the watch off and on the charger trying to manually pull the update
              • tapped the “System is up to date” screen for a few minutes straight to see if that would force the update
              I like the watch itself and would like to keep it, but if I can’t get it to update then I’ll return it.
              Thanks in advance for any help or advice you might have!
              Aleksander HA 1 Reply Last reply Reply Quote 0
              • Aleksander HA Offline
                Aleksander H Bronze Member @Ironhorz
                @ironhorz check out this post about staged rollouts by Dimitrios,
                https://forum.suunto.com/topic/6327/suunto-7-not-updating/15?_=1619338559464
                Basically, the old update from before April 19th is probably no longer being distributed. You therefore need to wait for the latest update to be made available to you (it doesn’t go out to everyone at once). I’d say stop trying to force it if it’s not working. I read on Reddit once that there is a limit to how many can force themselves past a staged rollout on WearOS. Not sure if it’s true, but it would make sense. I was never able to force download the previous update when that came out and just had to wait a few days.
                Forget about the update and use the watch as normal. You’ll probably get it sometime next week.
                I 1 Reply Last reply Reply Quote 1
                • I Offline
                  Ironhorz @Aleksander H
                  @aleksander-h Thanks so much for the response, I really appreciate it! I’ll just hang tight and give it some time then, hopefully I’ll have the update in the next week or so. 👍
                  • pilleusP Online
                    pilleus @olymay
                    @olymay said in System update – PXDZ.210326.002.A2:
                    According to the explanation on the S7 sleep will be synced with start and end time.
                    In Google Fit I can see what you can see on the attached screenshot. No heart rate. I have Google Fit not configured on the S7 to be sure that steps and daily activities which are not recorded by the Suunto wear app are coming from Suunto and not from Google Fit. Works fine, but sleep data are without hr data.
                    • olymayO Offline
                      There is definitely more than just the start and end times synced across, as the data for the different sleep stages is being sent too.
                      I have the HR there for my sleep recordings and spikes in HR correlate with REM sleep stages.
                      However I check to ensure this is data is not coming from from Withings Sleep Analyser (the data entry states it comes from Suunto however).
                      pilleusP Jamie BGJ 2 Replies Last reply Reply Quote 1
                      • pilleusP Online
                        pilleus @olymay
                        Yes, but Suunto gives the information about start and end time. On the watch and online.
                        • Jamie BGJ Offline
                          Jamie BG Bronze Member @Nigel Taylor 0
                          @nigel-taylor-0 watching tv on the couch and it thinks you have fallen asleep.
                          I would hope that if you answer no it wouldn’t record the session as a sleep.
                          Nigel Taylor 0N 1 Reply Last reply Reply Quote 0
                          • Jamie BGJ Offline
                            Jamie BG Bronze Member @olymay
                            Confirmed over the last couple of nights (using Cinema and Touch lock mode) that my battery usage is approx 1.2% (max) / hr
                            • Jamie BGJ Offline
                              @olymay and @pilleus - I agree with Pilleus - in google fit I am getting no HR data for sleep tracking - getting exact same as he is getting.
                              Only time I get HR data is for a tracked activity.
                              Only part of the sleep tracking on GFit I like seeing is the bottom graph of sleep stages across time. Wish the suunto app had this, otherwise I don’t use GFit at all (no point) and Beta version of Suunto app has everything you need.
                              olymayO 1 Reply Last reply Reply Quote 1
                              • olymayO Offline
                                olymay Gold Members @Jamie BG
                                @jamie-bg and @pilleus
                                After some further checking it appears my sleep HR in Google Fit was coming from my Withings Sleep Analyser but Google Fit was telling the sleep data was coming from Suunto.
                                I Agree with @Jamie-BG that the only benefit to using Google Fit for the sleep data is the display of the sleep phases. I really wish this could be shown in the Suunto app.
                                Apart from the sleep phases, there really is no reason to look at the data in Google Fit any more (although I do still like my data in a central location, just in case I switch device brand in the future) as the Suunto App has 99% of what I want in it now 🙂
                                @pilleus have you tried a sleep with the Suunto 7 in cinema mode instead of aeroplane mode yet? To see if this has an impact on battery life?
                                I am getting the same battery usage as @Jamie-BG
                                • Nigel Taylor 0N Offline
                                  Nigel Taylor 0 Bronze Member @Jamie BG
                                  @jamie-bg said in System update – PXDZ.210326.002.A2:
                                  😂 but the question is “are you awake?”
                                  If you answer “no”, then you are asleep (so not sure how you’d purposely click it!?) so it should consider it as a sleep session?
                                  • pilleusP Online
                                    pilleus @olymay
                                    Cinema mode: 14 % battery usage in 8 hours, seems to work better, but I used the original watch face, because the Solstice is not usable.
                                    Solstice watch face: most of the time the display is black, colours only random, no change with changing energy options or AOD (location service is activated, connection to the phone is established, no change after two factory resets).
                                      Aleksander H Bronze Member @pilleus
                                      Strange. I only had issues with it when I used it for the first time, and that was because it was missing location. After that, I’ve had no issues.
                                      EgikaE 1 Reply Last reply Reply Quote 2
                                      • EgikaE Offline
                                        Egika Platinum Member @Aleksander H
                                        @aleksander-h said in System update – PXDZ.210326.002.A2:
                                        same here.
                                        just activated it again and its live and in color.
                                        • isaziI Offline
                                          isazi Moderator
                                          Solstice is working for me too.
                                          Blog: isazi's home
                                          • vr2udtV Offline
                                            vr2udt Bronze Member
                                            Solstice is definitely my favourite watch face now. 😊
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
