    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Turn by Turn Navigation in opposite way does not work properly
    15 Posts 10 Posters 1.2k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      AndreasKauth
      Servus S9 Users, and i supose, this is the same at other watches…
      in the search, i found nothing to this issue…
      Today, i took a little hike, planned with komoot. We started in the opposite direction as planned in Komoot like often in the past - the watch had no problems with this. Now with turn-by-turn-navigation, the commands are in the wrong way. When i had to turn right, the watch says left - went two times the wrong way till i realized, that the commands are wrong…
      The watch had during the hike one black-screen-restart (there are now two hikes in one sunday 💪 ), i don´t know, if it has to do with the “wrong-way-issue”…
      Can this be fixed, or have i to go, like i planned in Komoot in future?
      Thanks a lot
      isaziI ? jthomiJ 3 Replies Last reply Reply Quote 3
      • isaziI Online
        isazi Moderator @AndreasKauth
        @andreaskauth the issue of the watch possibly having issues following a route in reverse is known already.
        For the turn by turn, unfortunately you need to plan in Komoot the direction you want to use the route, there is no way for Komoot to add waypoints for both directions.
        Blog: isazi's home
        • ? Offline
          A Former User @AndreasKauth
          @andreaskauth it’s not TbT, it’s labeled waypoints. Until Suunto produces true TbT, which would probably require onboard maps, you’ll have to either go straight on or remember to reverse directions if you’re going backwards.
          OktanO 1 Reply Last reply Reply Quote 1
          • jthomiJ Offline
            jthomi Moderator Gold Members Silver Members @AndreasKauth
            @andreaskauth good find!
            Rob33R 1 Reply Last reply Reply Quote 0
            • Rob33R Offline
              Rob33 Bronze Member @jthomi
              @jthomi we believe we are progressing and finally not enough time …
              • OktanO Offline
                Oktan @Guest
                @zrumlow or he can create 2 routes in komoot, one for each direction, just in case
                Suunto 9 Baro Titanium & Ambit 3 Peak
                ? 1 Reply Last reply Reply Quote 1
                • M Offline
                  martin Bronze Member
                  I think turn by turn instructions are generated in Komoot and sent to the watch, thus if you reverse the route in the watch, you just get the turn by turn instructions from last to first, instead of having them really reversed.
                  You’ll have to reverse the route in the Komoot app (Choose your tour, click «plan similar», then click on the three dots icon which is on the right of waypoints green bar on the top, and choose the reverse option). Save that new tour and sync again with the watch.
                  sartoricS A 2 Replies Last reply Reply Quote 1
                  • jthomiJ Offline
                    During planning a Route with komoot I found out that reversing a planned route can change positons of some waypoints, you should look into the route before saving.
                    • sartoricS Offline
                      sartoric Moderator @martin
                      @martin
                      Of course.
                      TbT is just a route with named waypoints … and wps are named based on how you draw the route.
                      SVTS - 2.50.28
                      SSSWHR BARO Amber - 2.8.32
                      Samsung A5 2016 - Android 7.0
                      Suunto App Android 6.7.12 beta
                      • A Offline
                        AndreasKauth @martin
                        I probably know the most tricks in Komoot, i´m working with it for years. And it ist very nice, that i can get the information about the turns on each waypoint without having the app running on smartphone.
                        Actually, this is not what i expected in the 21. century, so i was really suprised about the issue.
                        In future, i will go the “right way” in my routes.
                        Thanks for your reply!
                        • ? Offline
                          A Former User @Oktan
                          @oktan ya that works as long as you remember to do that and have a cellular signal when you roll up to the trailhead. Doesn’t do you much good on top of a mountain though.
                          ? DMytroD 2 Replies Last reply Reply Quote 1
                          • ? Offline
                            A Former User @Guest
                            @zrumlow one may not go unprepared to top of a mountain which he/she doesn’t know 😉
                            • DMytroD Offline
                              DMytro @Guest
                              @zrumlow you can create both routes in advanced. It may be not as elegant, but if TbT is important - why not?
                              • ? Offline
                                A Former User @DMytro
                                @дима-мельниченко I mean, I just flip them in my head if I’m going backwards
                                DMytroD 1 Reply Last reply Reply Quote 0
                                • DMytroD Offline
                                  DMytro @Guest
                                  @zrumlow that’s a possibility too 🙂
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
