    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No Vo2max since update 2.14.12
    48 Posts 11 Posters 5.6k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      Tobi74 @Dimitrios Kanellopoulos
      Since the newest update the Vo2max value is not displayed or calculated…. So that problem needs to be solved. Or at least an information that they have no solution at the moment.
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager @Tobi74
        @tobi74 it’s not due to the new update. Right ? You had done a full reset of the watch correct ?
        Although it’s covered here , vo2max is determined by firstbeat and that is a black box for suunto.
        What helps is to have a good hr reading , run in zone 3 and higher , for more than 15 minutes , and I would say about ,30mins + for the whole run.
        If you use ohr , it can be more tricky as if the ohr quality is not good enough, it won’t report vo2 max.
        If you use a belt, clean it up to not have artifacts.
        The only reason that vo2max is not appearing is due to the black box from firstbeat not being able to get a good quality run to determine that. And that applies only for the first time it needs to determine the base.
        If the first run cannot determine a vo2max then the last 6 runs / walks start to contribute to a more generic detection.
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        T Soylent YellowS 2 Replies Last reply Reply Quote 0
        • T Offline
          @dimitrios-kanellopoulos thanks for that explanation. I did hard and soft resets, changed the battery of the heart-rate belt…. And so on.
          I will do a 10k test run tomorrow. Maybe the value will appear again. I agree with you about the black box and the firstbeat plugin. It will be always a problem with third party pugs if one party is doing an adjustment .
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Tobi74
            @tobi74 soft resets are no issue, but every time you do a hard reset it starts from scratch and it may take a while to estimate the value again. So hard resets aren’t a way to make VO2max reappear faster, they are a way to postpone it further.
            Blog: isazi's home
            • Soylent YellowS Offline
              Soylent Yellow Bronze Member @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos I’ve got the same problem here with my 9 Baro. Watch hard reset itself during the firmware upgrade, and since the hardly a Vo2max reading.
              I ran a HM marathon yesterday, so that’s all Zone 3/4/5 on a flat course with open view of sky and a Polar H10 HR Monitor with a new strap and fresh battery, and still zilch. No Vo2max reading at all. I am really starting to believe that 2.14.12 changed something on the data delivery to FirstBeat’s ‘Black Box’, either because the GPS signal is noisier than before, or because the HR data gets massaged or re-interpreted somewhere.
              Have a look at the images below. It is quite clear when the 2.14.12 upgrade took place!
              isaziI 1 Reply Last reply Reply Quote 1
              • isaziI Offline
                isazi Moderator @Soylent Yellow
                @soylent-yellow next firmware will fix some issues with VO2max.
                Blog: isazi's home
                • T Offline
                  Tobi74
                  update 2.14.16 is online. I have already updated. let see if it works now 😉
                  • isaziI Offline
                    @tobi74 I think this will be fixed in the next update, but I may be wrong.
                    Blog: isazi's home
                    EzioAuditoreE 1 Reply Last reply Reply Quote 1
                    • EzioAuditoreE Offline
                      EzioAuditore Gold Members @isazi
                      @isazi You are right, still no Vo2. Out of 6 runs only my first 2 had vo2 (I got notif that the HR is not ideal on those runs for some reason 🙂 ) all the rest runs no vo2.
                      Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                      Suunto Wing
                      • isaziI Offline
                        isazi Moderator @EzioAuditore
                        @hristijan-petreski wait just a little bit more 😉
                        Blog: isazi's home
                        1 Reply Last reply Reply Quote 3
                        • isaziI Offline
                          isazi Moderator
                          This should be fixed in 2.16.26 (it has been for me for a while at least).
                          If any of you still has problems, please let me know.
                          Blog: isazi's home
                            @isazi Thank m8. I found a pattern when using some suunto+ functions to affect the vo2. E.q.: When strava relative effort I always had vo2 when TP I had the bug. I will try it and will give you a feedback.
                            Suunto Wing
                              Dimitrios Kanellopoulos Community Manager @EzioAuditore
                              @hristijan-petreski that is interesting. Please keep me posted
                                @argo320 lets continue here
                                • What activity do you use ?
                                • What S+ do you use
                                • What belt / OHR do you use
                                • Does the vo2max not get reported on the summary of the sport (after finishing the activity) ?
                                EzioAuditoreE Argonaut330A 2 Replies Last reply Reply Quote 0
                                  EzioAuditore Gold Members @Dimitrios Kanellopoulos
                                  @dimitrios-kanellopoulos In my case I had:
                                  • running (the basic/default and custom created)
                                    – without belt
                                    – belt too (HRM Pro)
                                    Always when choosing suunto+ with TP my vo2max was absent (in the watch after the activity was finished but also when visiting the logbook). I used also Climb/Hill and the Strava relative effort and the Vo2 was present. Will hill run tomorrow so I will be using Climb again, but on Saturday I will have long run and will try the TP data. Will report further if all is ok after this FW. Cheers.
                                  Suunto Wing
                                  • Argonaut330A Offline
                                    Argonaut330 @Dimitrios Kanellopoulos
                                    @dimitrios-kanellopoulos ok and thanks for your time, so:
                                    • I mainly and only use RUNNING
                                    • Usually i use NO S+ at all, if i go on unknown trail sometimes i use SAFE or if doing some treshold i use TrainingPeaks Running Pace (but very seldom)
                                    • No belt, just wrist
                                    • It doesnt get reported on the watch summary at the end and on the app VO2 tab
                                    As said, this pattern is quite randomized, sometimes i get the VO2 either with or without the S+ functions.
                                    Today, after the update, i went for this run to test it and i got no VO2, using Weather S+.
                                    Let me know if anything else is needed 😉
                                    Suunto Ocean
                                    Suunto 9 Baro
                                      Lets nail this one. Please report again with the findings after the update etc
                                      NOTE: For OHR if the quality is bad it can not appear , but that is a different case
                                      Argonaut330A 1 Reply Last reply Reply Quote 1
                                      • EgikaE Offline
                                        Egika Platinum Member
                                        @Dimitrios-Kanellopoulos so now I do get a strange effect with the firmware of today:
                                        I start a running activity as a test indoors, let it record for 30sec and stop it wothout actually moving (no GPS, HR 60bpm).
                                        I get a VO2max registered of 53.1 in the summary of this activity and this value is also updated in the VO2 in the main screens.
                                        I think this should not happen?!
                                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                          @dimitrios-kanellopoulos ok i will use for a week or so, and taking note of behaviour re VO2 recording, then will report again on this thread and take it from there. In the meantime let me know whether i need to send the logs today, grazie.
                                          Suunto Ocean
                                          Suunto 9 Baro
                                            Dimitrios Kanellopoulos Community Manager @Egika
                                            @egika for such a small run it should show some previous calculated value. Vo2max depends on previous runs.
                                            Also on short activities it might increase due to the little hr raise
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
