    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No Vo2max since update 2.14.12
    48 Posts 11 Posters 6.0k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      Tobi74
      I tried different HR and GPS modes for running every day. But no Vo2max value will be shown in the app or on the watch? 🤷‍♂️
      Re: S9 Baro titanium not measuring VO2Max or fitness levels with 2.10.18 - is this a known problem?
      surfboomerangS 1 Reply Last reply Reply Quote 0
      • surfboomerangS Online
        surfboomerang @Tobi74
        @tobi74 Are you running more then 15 minutes?
        I see the values appear in SA (newest beta). Also after the watch firmware update.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        T 1 Reply Last reply Reply Quote 0
        • T Offline
          Tobi74 @surfboomerang
          @surfboomerang
          I am running between 1h and 3h but no values. With Wrist hr on and GPS plus HR strap on. Or wrist hr off plus HR strap on and GPS. But still no values . I did soft and hard reset also!
          surfboomerangS isaziI 2 Replies Last reply Reply Quote 0
            @tobi74 do the values appear in the watch activity logs? If so, try clearing the Suunto App cache on the phone.
            OnePlus Nord 4
            • isaziI Offline
              isazi Moderator @Tobi74
              @tobi74 every time you do a hard reset the previous history is lost, so previous activities are not taken into account.
              Blog: isazi's home
              • T Offline
                @surfboomerang
                no there is nothing in the activity log.
                  @tobi74 And you use “Running” or “Hiking” as sport type? Is it a default sport mode or a custom one?
                  Maybe there is something wrong in the sport mode. Did you try to recreate it?
                  OnePlus Nord 4
                  • T Offline
                    @surfboomerang it is the basic running mode. No user adjustments 🤷‍♂️ I contacted Suunto support already bit no answer until today 🤔
                      @tobi74 Can you post pictures from one of the running logs in the watch and also one of the Fitness Level page on the watch? (the screen all the way down)
                      OnePlus Nord 4
                      T 2 Replies Last reply Reply Quote 0
                      • T Offline
                        @surfboomerang !![2_1619673962760_851CC9D0-1006-4A13-83D9-9799EA36EC23.jpeg](Uploading 13%) ![1_1619673962760_063B972D-22EB-4C1F-A72B-39C5108F01AC.jpeg](Uploading 13%) ![0_1619673962759_56025E28-1284-4103-A08E-4F26283A6D04.jpeg](Uploading 13%) 0FE48765-B087-4B48-A17F-061ABF344FFC.png A0047172-DA0E-49BE-B57F-9647D7B62ECF.png 0B63B0E3-1690-4834-A0E7-5C1034E842AE.png
                        • T Offline
                          @surfboomerang ![5_1619674737393_ABB1D69C-B894-40EB-BF29-AC404136ECD7.jpeg](Uploading 0%) ![4_1619674737393_3F5D071E-9DF4-4DE7-93D9-361B919C12D5.jpeg](Uploading 0%) ![3_1619674737393_8C5F4A7F-F744-4D04-8A47-531BB68C4451.jpeg](Uploading 0%) ![2_1619674737393_F4C946CB-68AD-4E35-86C7-7FE88A00A96F.jpeg](Uploading 0%) ![1_1619674737393_387AD534-6E54-495E-BFEA-339C78DA2601.jpeg](Uploading 0%) ![0_1619674737392_0F9289B3-2FDA-4A58-B10D-3729C1C91650.jpeg](Uploading 0%)
                          • T Offline
                            TyreseJ4
                            I really dislike the V02 Max feature. You go out and crush a run and it gives you +1; Go out and take it easy and it hits you with like -10. For example, on Monday I ran a 9 miler at about a 6:20 per mile pace and it bumped me up like 1 point. The very next day I took it easy and my V02 Max went down like 10 points. Lol the feature is a joke. Suunto should either remove the feature altogether or find a better way to give you a more reasonable score that takes into account hard days vs easy days. Theses devices treat V02 Max like it’s your credit score.
                            DMytroD isaziI 2 Replies Last reply Reply Quote 0
                            • DMytroD Offline
                              DMytro @TyreseJ4
                              @tyresej4 first of all: I agree that the values are unreliable. Even more so if it’s a walk or a hike, even a fast one.
                              On the other hand it seems somewhat logical to get a lower vo2 value from less stressful training. Since it’s the maximum oxygen consumption that’s beeing displayed, it seems reasonable that your maximum intake on less stressful activities is lower that on the hard ones. Of course I would expect the values to be extrapolated, but maybe the extrapolation is rather conservative not to overestimate the result.
                              • isaziI Offline
                                isazi Moderator @TyreseJ4
                                @tyresej4 sorry but that’s not how it works. VO2max does not get lower when you take it easy (I can walk and it does not go down), it goes down if the ratio between your heart rate and output (e.g. pace) goes up, i.e. to a lower output corresponds a higher effort. So if you see those huge drops either you run slow in zone 5, something I believe you do not do, or there is some issues with your HR readings.
                                Blog: isazi's home
                                DMytroD 1 Reply Last reply Reply Quote 1
                                • DMytroD Offline
                                  DMytro @isazi
                                  @isazi I disagree. Since I do not run I see that walks bring my vo2max down significantly. Right now I have smth about 33 and I’m 21 and doing quite a lot of sport, so it’s not really believable. Furthermore If I walk slowly like 5 - 5.5 kmh, vo2max goes down even more. And to bring it back up I need to go at speeds 6.5 kmh and up.
                                  Rob33R isaziI 2 Replies Last reply Reply Quote 0
                                  • Rob33R Offline
                                    Rob33 Bronze Member @DMytro
                                    @дима-мельниченко Am rather in agreement with @isazi , on flat ground, an endurance outing where I am very good rhythm and low cardio, my Vo2max does not go down. It even goes up sometimes compared to a tempo or vma session where I make the heart go up well (and also the rhythm).
                                    On the other hand or I find that it is completely wrong, it is the trail sessions with elevation gain.
                                    DMytroD 1 Reply Last reply Reply Quote 0
                                    • DMytroD Offline
                                      DMytro @Rob33
                                      @rob33 alright, don’t now what’s my issue then.
                                      Conserving trail runs - it’s to be expected, since algorithm doesn’t take elevation into account.
                                      • isaziI Offline
                                        isazi Moderator @DMytro
                                        @дима-мельниченко I know it works with walking, but it is a metric developed for running and cycling. It’s also not a direct measurement but just a guess based on the proxy of effort against output. The faster you can run with the lowest HR, the higher Firstbeat VO2max will be. Contrary, the slower you go with the highest HR, the lower it will go.
                                        Blog: isazi's home
                                        • T Offline
                                          Tobi74
                                          What‘s really anointing is: I am contacting the suunto support since one month! Via chat function, email or by phone. They could not offer a solution even they are not replaying on any email! I bought this Watch in February, so 50% of the used time i could not use the full range of features the offer. For a product of that quality and price it is a very poor performance Suunto is offering.
                                          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                            Dimitrios Kanellopoulos Community Manager @Tobi74
                                            @tobi74 what solution to offer for an algorithm that needs time to build and a proper effort?
                                            Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
