    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B crash, not all data saved
    14 Posts 2 Posters 959 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Stefan KerstingS Offline
      Stefan Kersting Platinum Member
      Today I did ski touring and suddenly my watch crashed. The display was just black and after a short time it came back, but the activity was finished. So I started a new activity at once but when downloading both activities to SA the first activity when the watch crashed the data set is incomplete. Usually you have three dots and three pages with data when ski touring. This is tha case when I started the second activity. But the first activity has not all data and among these the calories and the ascents has gone lost. Is there an possibility to rescue the whole data set?
      22E08C59-00FC-4AB5-A7FB-3D7946FEAE47.png 39E8510F-BA14-4419-9FAE-2D54B7EC2127.png
      Instagram: https://www.instagram.com/helgelandsbukken/
      https://www.instagram.com/suunto_adventures/
      IG: Helgelandsbukken, suunto_adventures
      Vimeo: vimeo.com/helgelandsbukken
      Blogg: https://turblogg.midnattsola.com
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Stefan Kersting
        @stefan-kersting I believe the header is not completely populated if the watch crashes. If you pass the fit files to a service that recomputes the data you should at least recover something.
        Blog: isazi's home
        Stefan KerstingS 1 Reply Last reply Reply Quote 1
          Stefan Kersting Platinum Member @isazi
          @isazi ok, i will try that, thanks for your help 🙂
          • isaziI Offline
            @stefan-kersting now to understand why it crashed. If you send the logs very soon after it happens the people at Suunto may investigate the issue and find if there is a bug, but it may be too late now.
            Blog: isazi's home
            Stefan KerstingS 2 Replies Last reply Reply Quote 0
              @isazi why is it too late now? The support is closed now…
                @isazi sendt the logg to the support. I checked the logbook too and the logg on the watch is empty and looks like that
                • isaziI Offline
                  @stefan-kersting because the logs only last few hours, so they need to be sent just after the event happens, and then you just need to write support the time you sent logs and from which account.
                  Blog: isazi's home
                  • isaziI Offline
                    @stefan-kersting this is the activity summary that is empty because it was not saved before the crash.
                    Blog: isazi's home
                    Stefan KerstingS 1 Reply Last reply Reply Quote 0
                      @isazi ok, then this activity is lost…
                      • isaziI Offline
                        @stefan-kersting not totally, you have something in SA, and if you check the FIT file there’s probably some information that can be recovered also.
                        Blog: isazi's home
                          @isazi in qs i see there is eg the ascent information but not in SA. So ascent information is very important to get 🙈😅
                          But i also see that the Heart Rate is nit saved, just the average…
                          • isaziI Offline
                            @stefan-kersting I did see the HR values in your SA activity though, so the samples are there.
                            Blog: isazi's home
                              @isazi actually that’s right. Weird that the app shows it, the watch doesn’t, at the same time calories are not calculated…
                              • isaziI Offline
                                @stefan-kersting so while the activity is going on the watch adds data to the “activity file”, such as elevation, coordinates, HR, etc. At the end it computes some statistics and adds them to a header.
                                What I understand is that in case the watch experience a crash, you end up with empty or incomplete header. Now SA and other applications can compute some stuff on their own, but for some things they rely on the header. This is why you have some data but not all of them.
                                Blog: isazi's home
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
