    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro, data missing when pressing button for split time in exercise
    75 Posts 8 Posters 12.3k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator @Gregor Kržan
      @gregor-kržan the best hypothesis is that because the header is missing Strava is recomputing the data. I would be very annoyed if I was you also, but if it happens so often there must be something wrong with your watch. Did you send your watch to Finland or some local dealer?
      Blog: isazi's home
      Gregor KržanG 1 Reply Last reply Reply Quote 0
      • Gregor KržanG Offline
        Gregor Kržan @isazi
        @isazi I didnt send to Finland because I sent it to official service which is only official service in Slovenia for Suunto.
        isaziI 1 Reply Last reply Reply Quote 1
        • isaziI Offline
          @gregor-kržan I can only suggest you to contact them again and show them this forum topic also. Don’t know if @Dimitrios-Kanellopoulos can help you with support.
          Blog: isazi's home
            Dimitrios Kanellopoulos Community Manager
            Did it take a long saving time ?
            What sport mode did you use?
            Did you use navigation?
            To me the issue is abvious. The watch does not save the activity correctly due to some reason .
            So as much possible info you can add it will benefit.
            The main question for me is:
            • When you finish the activity does the watch save it and present you with the data of the summaries?
            According to what I see the watch should crash at that point.
            Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
              Gregor Kržan @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos
              Thanks for your reply here. Ok when problems started I used only one sport mode - customized hiking with laps and I thought that was the case. Watch took more time than usual to save exercise and there was only data available for duration and distance I think…no altitude or HR. On Suunto App there were same invalid values as shown above.
              Then I took watch to licensed service where they tested it and told me everything is ok. I later did few different trainings and sport modes and in two cases same irregularities happened. First in running with no pauses and second in cycling with 30 min pause. All looks ok on Strava though.
              In both cases watch took more time to save exercise then usually does and data is again only duration with pause included plus distance and I think avg speed. No altitude or HR again. No navigation used.
              Brad_OlwinB Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @Gregor Kržan
                @gregor-kržan Another possibility is you have a corrupt sport mode. If only one sport mode is causing the issues you might try deleting the mode and making it again.
                Vector/T6c/Vertical 2 Ti
                  Gregor Kržan @Brad_Olwin
                  @brad_olwin no its not the case…as mentioned above…I had problems in hiking, cycling and running
                  Mff73M 1 Reply Last reply Reply Quote 1
                  • Mff73M Offline
                    Mff73 @Gregor Kržan
                    @gregor-kržan
                    Maybe worth trying to hardreset again (and eventually a couple of time more). If something is stucked in software, it is the best way to clea’ it. You already did it, but maybe issue might had survived.
                    Other reset solution : try the shipping mode.
                    (https://forum.suunto.com/post/46365).
                    Good luck.
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                      Dimitrios Kanellopoulos Community Manager @Gregor Kržan
                      @gregor-kržan do you use some Belt ? Maybe some HR monitor is causing this
                        @dimitrios-kanellopoulos I use Garmin belt…yes…you think that could be the case? But I do all trainings with belt so why are irregularities only in some trainings.
                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                          @gregor-kržan I have seen this in the past. Some belts with spartans would get stuck on saving.
                          I don’t know how to help here to be honest. I suspect a bug related to the belt that the watch overcomes when saving the activity.
                          What I can do , is if you can , send some logs and I can create an issue for the watch team.
                          Gregor KržanG MagoZicheleM 2 Replies Last reply Reply Quote 0
                            @dimitrios-kanellopoulos ok…would be very grateful…what should I do to help?
                              @gregor-kržan so just after one of those hikes etc press send logs from the suunto app and from the suuntolink. Remember the time around this happened or from Suuntolink pass me back the ID of the logs that i gave you back. Of course you should have connected the watch before and let it sync with the Suuntolink.
                              So 2 ways
                              Either Suuntolink -> send logs -> give me the log id
                              Suunto app -> send logs -> mark the time and will need your account name / id in private.
                                @dimitrios-kanellopoulos Just sent you ID on chat.
                                • MagoZicheleM Offline
                                  MagoZichele @Dimitrios Kanellopoulos
                                  @dimitrios-kanellopoulos when the problem happened to me, even if not identical but similar to the one discussed in this topic, I was using the sensor on the wrist of the S9, for the HR
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
