    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Resources - high drop after a walk
    29 Posts 11 Posters 2.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • helgonet12H Offline
      helgonet12
      Hi!
      I have a question regarding the resources on my S9B with the latest firmware. The resource is as far I can see ok when I wake up (06:47) like on the picture 94%.
      Around 07:45 I take my dog for a slow, calm walk for about 20 -30 minutes and the resource drops down to ca 55% This huge drops only happens when I record the activity with walk and only in the morning.
      If I take another dog walk the same day for lunch and in the evening the huge drop in resources will not appear as it didi in the morning. Even if I record the activity. If I do not record the walk then I think the drop is working as it should.
      So the drops happens only in the mornings and only when I use the record the walk activity. Does this happen to you as well?
      I have set my resting and max heart rate according to my age and fitness level. So it should be ok. I have followed this for a couple of weeks now and it it the same behaviour for all recorded activities. It is the same huge drop in the watch as it is in SA. (latest beta version) Any idea what might be the problem? Thanks.
      zadowZ ChrisAC 2 Replies Last reply Reply Quote 1
      • zadowZ Offline
        zadow @helgonet12
        @helgonet12 I am absolutely with you. Noticed the same. I created an activity to measure my morning HR. I started it right after I woke up, just for 5 minutes. Still lying on the bed and not moving at all. After these 5 minutes long activity of doing just nothing, my resources drops from 100% to 30%. Pretty strange, isn’t it?
        Suunto Race
        Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
        Suunto Smart Sensor
        Wahoo Tickr FIT
        Hammerhead Karoo 2
        Swim Ride Run Rest Repeat
        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
          Dimitrios Kanellopoulos Community Manager @zadow
          One used walking
          The other @zadow?
          I might remember something similar. Could you just for my sanity use indoor running or running to see if the same happens?
          Creator of Quantified-Self.io
          youtube.com/c/dimitrioskanellopoulos
          https://instagram.com/dimitrioskanellopoulos
          https://www.strava.com/athletes/7586105
          zadowZ helgonet12H 4 Replies Last reply Reply Quote 0
          • zadowZ Offline
            zadow @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos I created a custom activity view from “Other6” sport mode with duration and average HR field only. Nothing else.
            I also tried “Yoga” sport mode. Same effect. It caused very high resource drop when used very early in the morning, in fact, right after wake up.
            Suunto Race
            Suunto Smart Sensor
            Wahoo Tickr FIT
            Hammerhead Karoo 2
            • zadowZ Offline
              @dimitrios-kanellopoulos Ah sorry, regarding running… hm… good question, now when I am looking back at my early bird runs, it seems like the drop in resources after morning runs is reasonable… it could point to issue for morning activities without GPS? Just a guess…
              Suunto Race
              Suunto Smart Sensor
              Wahoo Tickr FIT
              Hammerhead Karoo 2
                @zadow the thing is if I recall correctly that some activities like yoga are considered “daily” for the firstbeat thingy.
                So a little spike on HR or bad HR can ruin the stress.
                I am creating a bug anyways for you guys. I can confirm it also affects me with some sport modes like yoga.
                Lets try tomorrow some other sport mode and report back here
                zadowZ helgonet12H 2 Replies Last reply Reply Quote 4
                  helgonet12 @Dimitrios Kanellopoulos
                  @dimitrios-kanellopoulos Hi I´ll try indoor running tomorrow and running the day after. For info I always use external heart rate on these walks. I did not in the beginning and thought that the drop was due to HR spikes created from the watch therefor I started to monitor this and it was the same with external HR. I´ll get back with info tomorrow
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                    Dimitrios Kanellopoulos Community Manager @helgonet12
                    @helgonet12 thanks
                    • zadowZ Offline
                      @dimitrios-kanellopoulos I scrolled back in time thru my activities and found out that “Stretching” was also causing morning high resource drop .
                      (Before I created activity to measure morning HRrest from “Other6” I was using “Stretching”)
                      So it may be the same “day only” activity as Yoga, as you explained…
                      Suunto Race
                      Suunto Smart Sensor
                      Wahoo Tickr FIT
                      Hammerhead Karoo 2
                      • ChrisAC Offline
                        ChrisA Platinum Member @helgonet12
                        @helgonet12 I had this too, see my post some months ago:
                        https://forum.suunto.com/topic/5045/resources-drop-from-90-to-0
                        Cheers Christian
                        • SnusRS Offline
                          SnusR
                          good morning guys.
                          What i also noticed is that if you do a reset on the watch (press upper button for x seconds) the ressource is automatically set to 50% after “reboot”.
                          is this the expected behavior?
                            Dimitrios Kanellopoulos Community Manager @SnusR
                            @snusr yes. That is expected as it looses it inner state. They will come up or down to their level shortly after.
                            helgonet12H 1 Reply Last reply Reply Quote 1
                              @dimitrios-kanellopoulos Hi! I used running app instead of walk and it did not have the same drop as before. I was out walking later today since I had to go to work earlier so I will try again tomorrow.
                              I looked for indoor running but could not find it? do you mean treadmill? I have looked twice for indoor running but it is not there.
                              There is also some wired behaviour when scrolling down the sports modes using the button down. after a while it start to scroll down buy it self really fast until it hits the last sportmode. It does not happen if using touch. I tried this I a couple of times and it was the same every time.
                                @dimitrios-kanellopoulos Hi! I have during the weekend tried different activities like running, hiking and walking but it is the same on all. Hiking had the big drop as walking. The strange thing tough is that when I used running instead go walking this Saturday the resources worked fine. but today I used running instead of walking and I got the same big drop as walking (see picture) Skärmavbild 2021-03-15 kl. 08.40.23.png
                                • isaziI Offline
                                  isazi Moderator
                                  Just noticed the behavior this week because I decided to record my commute to work. Same huge drop in resources (today from more than 80 to 20) after a mellow 30 minutes bike ride.
                                  Watch: Suunto Vertical Ti
                                  Blog: isazi's home
                                  1 Reply Last reply Reply Quote 3
                                    @dimitrios-kanellopoulos Hi! Tested the walk activity today and same behaviour (big drop) happens on the new firmware 2.14.12.
                                      @helgonet12 yes this was not fixed in this FW. Walking will produce the same issue if there are HR inconsistencies.
                                      helgonet12H 2 Replies Last reply Reply Quote 0
                                        @dimitrios-kanellopoulos ok. I thought so. Just wanted you to know 😀. Hoping it will come with the next update. Happy Easter 🐣 to you and everyone else in the forum.
                                          @Dimitrios-Kanellopoulos Hi. Any news about the fix for recourse drop on the S9B? It’s been a while since the first report of the issue. I know it is not the most important issue but still it should have been fixed I think during this time. Thanks.
                                          • SuperFlo75S Offline
                                            SuperFlo75 Silver Members Bronze Member
                                            I think I had the same ‚feature‘ with my S9PP same days ago… I started ‚Trailrunning‘ for a short time in the morning when I walked on the parking area in front of my work… I wanted to calibrate the altitude… about 30 second and a lost of resources from about 70% to 30%… I nearly couldn‘t stop laughing…
                                            Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                                            Suunto Wing
                                            Suunto 9 Peak Pro Titanium (owns my wife now)
                                            Suunto Spartan Ultra
                                            SA iOS 2.47.3 (19893)
                                            Instagram @superflo75
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
