    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    troubles with time to charge
    Scheduled Pinned Locked Moved Suunto 7
    17 Posts 6 Posters 1.3k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Theresia WetzelT Offline
      Theresia Wetzel
      Maybe someone can help me, it takes 7-8 hours to charge fully (from 8% to 100%) being plugged in with an adapter and only around 60 minutes charging it with the Laptop. The manual says it should make no difference but 60 minutes and 7-8 hours is a huge difference. Is ist normal or not? What can I do?
      isaziI Jamie BGJ 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Theresia Wetzel
        @theresia-wetzel sounds silly, but did you try a different charger?
        Blog: isazi's home
        Theresia WetzelT 1 Reply Last reply Reply Quote 0
          Theresia Wetzel @isazi
          @isazi I tried many different chargers and even a different/new cable nothing works faster than 7-8 hours of charging
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            @theresia-wetzel mine charges in less than an hour with any of my phone chargers.
            Blog: isazi's home
              @isazi that’s what I thought. I costumer support told me that I need to send it in, which I already did two times but they said nothing can be found and it works fine. But I have the same problem still… Any ideas what I can do?
              pavel.samokhaP 1 Reply Last reply Reply Quote 0
              • pavel.samokhaP Offline
                pavel.samokha @Theresia Wetzel
                @theresia-wetzel may be cable issue? Have you tried to clean contacts?
                Opinions expressed are solely my own and do not express the views or opinions of my employer
                  Theresia Wetzel @pavel.samokha
                  @pavel-samokha That’s the first thing I tried. Didn’t help 😞 The interesting thing is, that I have no issues charging it via Laptop. That makes it so wired and hard to understand the problem.
                  Mff73M pavel.samokhaP 2 Replies Last reply Reply Quote 0
                  • Mff73M Offline
                    Mff73 @Theresia Wetzel
                    @theresia-wetzel
                    i have no S7, but couldn’t there be any wear OS setting that could prevent the watch to charge at “full” speed if … (but strange that it is the wall charger that fails, but who knows).
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                      @theresia-wetzel have you sent in to support both watch and cable?
                        pavel.samokha
                        and also have you tried to reset the watch?
                          @pavel-samokha yes and yes. Nothing could be found but nothing has changed either. Still the same problem.
                            @theresia-wetzel yep, weird case.
                            Have no idea other then find someone with S7 in you vicinity and check with his cable/S7 or return S7.
                              Theresia Wetzel @Mff73
                              @mff73 I don’t know. I couldn’t find anything.
                              • P Offline
                                PiotrN
                                Have you used a charger without fast charging - only 5V?
                                  Theresia Wetzel @PiotrN
                                  @piotrn Yes, tried this too. No difference. 😞
                                  • Jamie BGJ Offline
                                    Jamie BG Bronze Member @Theresia Wetzel
                                    @theresia-wetzel
                                    There is obviously no issue with your cable, and or your watch as performs fine with laptop, thus must be related to:
                                    Wall socket.
                                    USB charger plug (I use an old mobile one, that is basically the same power as a USD port in a laptop, and have no issues - mine fully charges in under 90mins). I do not have it in a faster charge plug unit.
                                    Would suggest changing both to see if that can’t help.
                                      Theresia Wetzel @Jamie BG
                                      @jamie-bg I would be glad if it would be this easy. Already tried different wall sockets, even in different apartments and houses. No difference.
                                      I tried 5 different charger USB plug ins, even bought two new ones with 5V and 2 with 0,5A (like the suunto support told me to try) and still no difference. And my two different power bank won’t work at all. I really don’t know what to do and I’m starting to think I’m crazy. I love this watch, it works perfect for me but it makes me insane that I only able to charge it via laptop 😞
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
