    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B textile/ velcro strap
    31 Posts 10 Posters 3.8k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Shrek3k @sartoric
      @sartoric I ordered one … waiting, with deteriorating patience 😬
      using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
      OS - Android 16/Pixel Pro 7
      Mitch9M 1 Reply Last reply Reply Quote 0
      • Mitch9M Offline
        Mitch9 Silver Members @Shrek3k
        @Shrek3k said in S9B textile/ velcro strap:
        Same here! 🙋
        Watch: Suunto Vertical Titanium Solar (Sand)
        SA: Android (beta)
        HRS: Polar H10
        S 1 Reply Last reply Reply Quote 0
        • DMytroD Offline
          DMytro @sartoric
          @sartoric yep, should arrive sometime mid-August. I’ll report on the quality shortly after.
          • Jamie BGJ Offline
            Jamie BG Bronze Member
            try a abanen (NA)/yooside (UK) hook and loop strap - lightweight, bit of stretch, and very secure as inner hoop is between wrist and strap; and the hook/bar prevents it coming through the lug. Buy two so while one is drying can wear the other. Work exceptionally well.
            sartoricS 1 Reply Last reply Reply Quote 0
            • sartoricS Offline
              sartoric Moderator @Jamie BG
              @Jamie-BG
              Unfortunately it seems they do not have 24mm … or maybe I’ve missed it
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.8 beta
              Jamie BGJ 1 Reply Last reply Reply Quote 1
              • Jamie BGJ Offline
                Jamie BG Bronze Member @sartoric
                @sartoric use the 26mm. Quite a few guys have been putting the 26mm on the Epix which is 22mm.
                https://forums.garmin.com/resized-image/__size/960x720/__key/communityserver-discussions-components-files/600/E59AAC18_2D00_6658_2D00_49DF_2D00_BD33_2D00_651986602EB8.jpeg
                This image shows what the 26mm looks like on a 22mm lug bar.
                • S Offline
                  Shrek3k @Mitch9
                  @Mitch9 said in S9B textile/ velcro strap:
                  Same here! 🙋
                  Received my strap today. First impression is really good, with the exception of the rather shortish spring bars. But … the spring bars and the tool are included, and to change the strap was not hard at all. The material feels good and it seems to be made welll. The mechanism to adapt the length and “tension” feels good, too. I am looking forward to using it, and see how it behaves and how it dries (or gets wet).
                  • sartoricS Offline
                    sartoric Moderator @Shrek3k
                    @Shrek3k
                    Let us know 😁
                    I’m curious if it’ll wobbles
                    SVTS - 2.50.28
                    • sartoricS Offline
                      @Jamie-BG
                      Well, in fact based on the way it is mounted on the pin, I could buy the 22 too.
                      I just need to figure out if it would be snugger having 2mm less or more 😁
                      SVTS - 2.50.28
                      • S Offline
                        Shrek3k @sartoric
                        @sartoric concerning size: my hand/arm is with 19cm the maximum size for S, which I ordered. And - that was perfect, as this is really the maximum size. In the tightest selection it seems stable and give good values while running, so anything bigger than S would have been too big for me
                        • S Offline
                          Shrek3k @Shrek3k
                          Had a run, cycled and showered with the strap, and wore it for more than 16 hrs without break.
                          And up to now it is more comfortable to wear than a regular strap, when tight enough to ensure good readings, and measurements have been excellent. So it has been a really good recommendation (for me). How durable the strap is? Don’t know. It looks really good, but after such a short time nothing else should have been expected 😃
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
