    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    eraeraeggaverg
    Scheduled Pinned Locked Moved Suunto 3
    45 Posts 14 Posters 12.4k Views 14 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C Offline
      Chrys
      Hi!
      I bought a Suunto 3 Fitness 3 weeks ago, as I love trekking. I have issues with the altitude and ascent and descent notes (I checked my phone GPS before starting my exercice). The altitude is mostly incorrect, and the ascent and descent ALWAYS zero! A part this, sometimes after exercicing outdoor, there is no image with the map and my trace. There is any hope for resolving the problem?
      After reading some post in here, I believe I can’t fixe the problem and that is too disappointing…
      Thank you in advance
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager @Chrys
        @chrys there is a fix coming on 4.42 this june but keep in mind that S3F does not calculate ascent and descent its not a hikking watch
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard or use mcp.
        C 1 Reply Last reply Reply Quote 0
        • C Offline
          Chrys @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos I did not know about the ascent/descent…
          I hope the issue will be fixed!
          Ευχαριστώ πολύ!!
          Thank you anyway
          Chryssa
            @chrys anytime!
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @wefwefefweqfwefsdfwef
              @grant-czadzeck This is definitely an Android issue, I ran with my S3 yesterday using iOS and had no issues.
              Vector/T6c/Vertical 2 Ti
              • Jamie BGJ Offline
                Jamie BG Bronze Member @Dušan Ković
                @dušan-ković
                Have you tried the following.
                Open suunto app.
                Go back to your home screen without closing suunto app.
                Press/use gesture (or whatever your phone does) to bring up open apps running in the background (i.e shows little tiles of all open and running apps, one of which should be the suunto app you have open.
                There should be a function to now lock that tile (open running app) - my Oneplus does this by long pressing the suunto app which brings up lock, app info and split screen option. Press the lock option (If i remember correctly on the samsung in some versions you get a little menu button you can press which relates to currently selected tile).
                With it locked it cannot now be cleared from active apps - and even if minimised it should still be working.
                Also make sure that your app location permission is set to be allowed.
                If no go you will probably have to wait until issue is resolved.
                • C Offline
                  Chrys
                  Hi!
                  the last days after exercicing, no map on the app! even after the latest update (Juin, 15th).
                  Is there any idea for this?
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                    @chrys 4.42 version has the fix
                    benjamin ulmerB 1 Reply Last reply Reply Quote 0
                    • benjamin ulmerB Offline
                      benjamin ulmer @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos Hi there, I know this thread is quite old, but I recently bought the Suunto Ambit 3 All Black (I guess about 3 weeks ago). Everything worked quite okay since then, the connection to the Suunto App was up and running in a couple of minutes, just this one thing makes me struggle since then:
                      When I go for a walk, hiking or running I always ran into the following issue
                      Steps to reproduce:
                      • connection to Suunto App okay, GPS on smartphone (Android, Motorola) on
                      • watch up and training started
                      • Suunto App says something like “the watch is using the phone’s gps”
                      • After the workout the following problems show up
                      The problems:
                      1. the measured distance is wrong
                      2. I do not see any GPS / map data but the same as @Chrys posted in June 18: https://forum.suunto.com/assets/uploads/files/1624017065561-suunto.jpg just a picture…
                      System details:
                      Suunto 3, 2.18.18
                      Suunto App Version 4.49.1, all permissions and notifications granted
                      Android 9
                      Are there any other known solutions than the ones mentioned in this thread? As far as I understood the problem was the Suunto App / operating system on smartphones in most cases, but can someone give me a hint on how to verify the watch functionality?
                      Help appreciated,
                      kind regards
                      Benjamin
                      isaziI freeheelerF Brad_OlwinB 3 Replies Last reply Reply Quote 0
                      • isaziI Offline
                        isazi Moderator @benjamin ulmer
                        This post is deleted!
                        • freeheelerF Offline
                          freeheeler @benjamin ulmer
                          @benjamin-ulmer
                          I assume you don’t have an Ambit 3, but a Suunto 3?
                          Do you have all background activities in the phone allowed, too?
                          GPS needs to update in SA very frequently during your activity.
                          I know e.g. that Huawei phones have a very restrictive power saving setting by default. Once the phones screen turns off, some functions are limited, too.
                          living sideways
                            Brad_Olwin Moderator @benjamin ulmer
                            @benjamin-ulmer Sorry I cannot help, this is working with an iPhone, perhaps there are settings that prevent the phone from sharing GPS data? Or, perhaps the phone is shutting down GPS collection?
                              benjamin ulmer @Brad_Olwin
                              @isazi I am sorry, but your post reply shows up as deleted, but thanks anyway.
                              @freeheeler That’s completely true. I missed the Ambit part. Sorry for the confusion. I thought of something like this, but could not see anything indicating a problem.
                              @brad_olwin I will dive into this in detail in the next days. Thanks for your suggestion.
                              Some general facts about my actions take so far:
                              I did not only reinstall the Suunto App but also
                              • turned on all notifications from smartphone to watch in the Suunto App watch settings section
                              • in Android settings on my smartphone
                                • enabled all notifications from Suunto App
                                • gave all permissions for the Suunto App
                                • completely disabled the energy saving mode
                                • turned of the smart battery mode
                              Is there any options I missed to check out and missed to find in the previous posts on this topic here?
                              Kind regards.
                              benjamin ulmerB 1 Reply Last reply Reply Quote 1
                                benjamin ulmer @benjamin ulmer
                                Hello,
                                I ran through some initial steps I had take before once again today:
                                • uninstall and install the Suunto App
                                • Soft reset the watch
                                • Hard reset the watch
                                Nothing changed. I tried this a already a couple of days ago, but it did not solve my problems back then as well.
                                In addition I made some checks to my phone’s GPS, because I asked myself if there were some general issues with it, that i.e. Google Maps does not show because of it’s integration into Android OS. I checked the GPS tracking using Openstreetmap just to make sure, that a complete Google independent software works and it located my smartphone via GPS at any time.
                                I am going to get in touch with the Suunto support team. Probably they come up with some new solutions. If so, I will share them here.
                                Kind regards
                                Benjamin
                                benjamin ulmerB 1 Reply Last reply Reply Quote 2
                                  I just wanted to give you an update. Unfortunately I could not solve the problem. The official Suunto support continues answering with very lame standard solutions, which is not really helpful at all.
                                  I am going to use my watch for sports I do not required GPS for and daily tracking of sleep, …
                                  When it comes to GPS I’ll stick with my old Ambit as it actually works perfectly okay.
                                  Nevertheless, thanks for your great information here in the forum.
                                  Keep on the good spirit. 💪
                                  Kind regards,
                                  Benjamin
                                  Mff73M GuillaumeFG 2 Replies Last reply Reply Quote 1
                                  • Mff73M Online
                                    Mff73 @benjamin ulmer
                                    @benjamin-ulmer
                                    Did you eventually try this?
                                    https://forum.suunto.com/topic/6001/suunto-fitness-3-not-recording-gps-data/5
                                    You could also try with another phone (android or iOS), ot last chance, get another S3 and test (from someone else or buy on to send it back after tests (no nice but…)).
                                    Good luck.
                                    SSU (retired), SV1, SV2
                                    Wife : S9PP
                                    SA: Always the latest beta :)
                                    Android + Galaxy S205G
                                    • Mff73M Mff73 referenced this topic on
                                      benjamin ulmer @Mff73
                                      @mff73
                                      Yes I did (https://forum.suunto.com/topic/6001/suunto-fitness-3-not-recording-gps-data/5), but it did not solve my problem.
                                      I have not tried another phone yet, but I think I’ll give it a try, just to make sure (although I am pretty sure it will because most of the issues with S3 and smartphones seem to be caused by smartphone rather than S3 - at least that’s what I found when searching the web)
                                      Thanks anyway.
                                      • benjamin ulmerB benjamin ulmer referenced this topic on
                                      • freeheelerF freeheeler referenced this topic on
                                      • Z Offline
                                        zt_zzzzz
                                        The same error:
                                        https://forum.suunto.com/topic/7113/s3f-no-speed-during-cycling
                                        • GuillaumeFG Offline
                                          GuillaumeF @benjamin ulmer
                                          @benjamin-ulmer same problem here
                                          as you can see about 13km but only few meters tracked by gps
                                          all app’s permissions are set correctly
                                          Suunto 5 Peak
                                          GuillaumeFG 1 Reply Last reply Reply Quote 0
                                            GuillaumeF @GuillaumeF
                                            Ok,another running today and now I have zero gps data !
                                            I checked before start the excercise to see the GPS arrow on my watch.
                                            The only difference with my last excercise is the new version of the android app (4.51.5)
                                            So for me the Gps problem is due to the android app
                                            Please fix it
                                            Suunto 5 Peak
                                            freeheelerF 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
