    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto S9 baro ascent issue
    15 Posts 7 Posters 840 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      TFM1973
      I ran a route of 650m of ascent, my suunto s9 baro marked me more than 1500m of ascent.
      What will be the problem or the cause of the difference in the ascent?
      https://www.suunto.com/move/tonyfierros/6016d90346e687461b2fbb0f
      Screenshot_20210201-215307.jpg Screenshot_20210201-213945.jpg Screenshot_20210201-213901.jpg
      P Mff73M 2 Replies Last reply Reply Quote 0
      • P Offline
        pacos @TFM1973
        @tfm1973 look at all the spikes from 15km.
        I had the same with Garmin 6X Sapphire where my guess was the sweat entering on the barometer holes. On the Fenix the problem was that sensor is on the right side of the swatch, and using it on the left wrist during the running with the swing of the arm and the hole in the direction of the air flow after 20/25 minutes of running, and more on hot seasons (with clearly more sweat), these sequence of spikes started. And creating big ascent values. I went back to Suunto as I was desperate for this issue! That Garmin always denied btw.
        Anyway on Suunto 9B I didn’t have it as baro holes are on the left side and probably not affected by this issue…
        BUT I had a couple of runs where I had small sequence of spikes when it was raining, thus I think that scenario could happen even if more rare?
        In case of Garmin I noted that wasn’t water disturbing sensor but I’m pretty sure my sweat (maybe salt or so), thus I would think the same behaviour could be in S9B but with hole in different position and maybe sensitivity of sensor different is almost 0 to me…
        • Mff73M Online
          Mff73 @TFM1973
          @tfm1973
          why opening a new message for the same issue ?
          https://forum.suunto.com/topic/5839/different-ascent-value-in-suunto-app-s9-watch-and-movescount?page=1#
          something clearly happened at the end of your activity : very spiky altitude.
          SSU (retired), SV1, SV2
          Wife : S9PP
          SA: Always the latest beta :)
          Android + Galaxy S205G
          T freeheelerF 2 Replies Last reply Reply Quote 1
          • T Offline
            TFM1973 @Mff73
            @mff73 this is not the same issue, is diferent.
            Also is a diferente whatch, the past post was for a suunto 9 non baro, I bought the s9 baro and try again … please check both posts
            Thanks
            Mff73M 1 Reply Last reply Reply Quote 0
            • Mff73M Online
              Mff73 @TFM1973
              @tfm1973
              OK, i didn’t think you have bought a new watch 🙂
              So first advice : search the whole forum for “S9” “Baro” “Altitude”, there are numerous posts with all possible causes of this kind of “issue” : from just wind into holes, to faulty units, or just baro holes interferences with clothes, wrist mouvements, sweat, rain, etc…
              Give us more information about the way you wear your watch, the weather, which wrist, etc…
              Do you use Suunto+Climb ?
              Etc…
              Wife : S9PP
              ? T 2 Replies Last reply Reply Quote 1
              • ? Offline
                A Former User @Mff73
                How was the weather ? If weather was changing fast it can make trouble becausd baro fall down.
                It’s a supposition.
                Do you have STRAVA ? i’ve se you can apply there “altitude référence” and it correct mistakes automatically
                freeheelerF 1 Reply Last reply Reply Quote 1
                • freeheelerF Offline
                  freeheeler @Mff73
                  @mff73 said in Suunto S9 baro ascent issue:
                  when you press the button for the elevator you push many times as it will arrive faster 😉
                  living sideways
                  1 Reply Last reply Reply Quote 3
                    freeheeler @Guest
                    @g287-sf said in Suunto S9 baro ascent issue:
                    it could help but isn’t nukeproof either
                    living sideways
                    • ? Offline
                      A Former User @freeheeler
                      @freeheeler it was a suggestions because i’m not enough geek to correctly use all data, it’s my first watch like this
                      • T Offline
                        TFM1973 @Mff73
                        @mff73
                        The weather was sunny without any changes
                        I wear the watch on my right arm
                        I was running with Tshirt for heat rather as I always do it
                        freeheelerF 1 Reply Last reply Reply Quote 0
                          freeheeler @TFM1973
                          @tfm1973
                          and you were sweating after 15km and for better HR readings you pulled the strap tight and with your wrist motion you started pumping on the baro holes… this is the reason in many cases as I observe
                          living sideways
                          T 1 Reply Last reply Reply Quote 2
                          • isaziI Offline
                            isazi Moderator
                            Most of the people having this issue recently had problems with accumulating rain/snow [1], but sweat could be an issue. In your case, something definitely happened close to the end when the watch starts registering all those spikes.
                            [1] https://forum.suunto.com/topic/5866/wildly-incorrect-spiky-altitude-data/
                            Blog: isazi's home
                            stromdiddilyS 1 Reply Last reply Reply Quote 2
                            • T Offline
                              TFM1973 @freeheeler
                              @freeheeler thanks for the info… maybe that can be te cause
                              P 1 Reply Last reply Reply Quote 1
                              • stromdiddilyS Offline
                                stromdiddily Gold Members @isazi
                                @isazi there is a disturbance in the force
                                Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                                User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV :)
                                • P Offline
                                  pacos @TFM1973
                                  @tfm1973 I also add that wearing on right wrist you have the baro hole in the direction of the run (left side of the swatch), thus if you start sweating is easy that he flows in the hole…
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
