    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Hiking with battery mode Ultra
    72 Posts 9 Posters 14.5k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @surfboomerang
      @surfboomerang The first 15 to 20 min the watch will be adjusting FusedAlti and I guess does some other things. Dimitrios has stated before that FusedTrack does not engage for 15 min or so. Because of this, on a short exercise you are unlikely to notice that much of a difference. You will need 3-4h minimum to see a major difference in battery use.
      Vector/T6c/Vertical 2 Ti
      surfboomerangS 1 Reply Last reply Reply Quote 2
      • surfboomerangS Online
        surfboomerang @Brad_Olwin
        @brad_olwin I would understand it if GPS is only on best the first 20 minutes for the FusedAlti mechanism, but a difference after 3-4hr I don’t get.
        What if I start my activity with 12% battery left and I get a notification at 10% asking me if I want to switch profiles? I would expect it would go in effect immediately instead of taking a couple of hours. With a battery drain of 3-4%/hr that would mean that my watch is empty before the Ultra mode kicks in.
        That also would mean that a lot of reviews/tests on the internet are wrong, because most of them test the fusedtrack technology on a 5 km run or so.
        What about selecting GPS mode OK in a custom battery profile? Shouldn’t that go into effect immediately?
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        zadowZ 1 Reply Last reply Reply Quote 0
        • zadowZ Offline
          zadow @surfboomerang
          @surfboomerang One more question - do you have any ETA/ETE/remaining distatance fields on your display? If so, then watch automaticaly switch to best GPS as they are trying to calculate ETA/ETE. Just like when you switch to navigate display. so, as @Brad_Olwin suggested, check the accuracy after 20 minutes, and make sure that there no any fields referring to ETA/ETE or remaining distatnce to POI or to end. If you have any of those field on your current display, even when there is no route for navigation loaded, watch switch to GPS best.
          Suunto Race
          Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
          Suunto Smart Sensor
          Wahoo Tickr FIT
          Hammerhead Karoo 2
          Swim Ride Run Rest Repeat
          surfboomerangS 1 Reply Last reply Reply Quote 5
            Dimitrios Kanellopoulos Community Manager
            At the first x minutes until Fused Alti kicks in the watch is in Best GPS mode.
            After that it will switch.
            One should never test on battery consumption with 1-3hours of activity.
            Hiking due to slow speed wont use fused track
            Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
            surfboomerangS 1 Reply Last reply Reply Quote 4
              surfboomerang @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos Check!
              I never expected fusedtrack to be active. I just wondered how bad/good the track would be with a 2 min interval.
              OnePlus Nord 4
                surfboomerang @zadow
                @zadow Never thought of that. I do have ETA and ETE fields on one of the displays.
                OnePlus Nord 4
                  surfboomerang
                  Ladies and gentlemen… we have a winner! @zadow
                  I removed the ETE/ETA fields and gave it another try. After 15 minutes the Ultra kicked in and GPS was recorded every 2 minutes.
                  Learning something new every day 😄
                  OnePlus Nord 4
                  zadowZ 1 Reply Last reply Reply Quote 5
                  • zadowZ Offline
                    @surfboomerang I was doing exactly the same test in the past. And exactly for the same purpose - just to see, how it works 🙂 And I ran exactly into the same situation as you did. I asked here in this forum as you did and I got a great explanation from @Dimitrios-Kanellopoulos. So, thanks but all the credits goes to @Dimitrios-Kanellopoulos 😄
                    Suunto Race
                    Suunto Smart Sensor
                    Wahoo Tickr FIT
                    Hammerhead Karoo 2
                    Fenr1rF 1 Reply Last reply Reply Quote 1
                    • Fenr1rF Offline
                      Fenr1r @zadow
                      @zadow It seems odd. I wonder why the presence of data fields that will continue to report null values requires (or was chosen to initiate) precision tracking. Is there something obvious?
                      zadowZ Mff73M 2 Replies Last reply Reply Quote 0
                      • zadowZ Offline
                        zadow @Fenr1r
                        @fenr1r Well, better ask @Suunto, I am just a messenger, not a designer 🙂
                        Suunto Race
                        Suunto Smart Sensor
                        Wahoo Tickr FIT
                        Hammerhead Karoo 2
                        Fenr1rF 1 Reply Last reply Reply Quote 0
                        • Fenr1rF Offline
                          Fenr1r @zadow
                          @zadow OK. Just wondering if you’d been told the “Why” as well.
                          • Mff73M Offline
                            Mff73 @Fenr1r
                            @fenr1r said in Hiking with battery mode Ultra:
                            maybe the glass is not half full, but half empty (or vice versa 🙂 ), maybe it is by design that, if there is one field or screen that needs “best” precision, then, best precision is set.
                            Effectively, it could be the opposite : if user doesn’t set best , then all data needed would have been “blank” or “null”, and then users will ask why 🙂
                            SSU (retired), SV1, SV2
                            Wife : S9PP
                            SA: Always the latest beta :)
                            Android + Galaxy S205G
                            surfboomerangS Fenr1rF 2 Replies Last reply Reply Quote 0
                              surfboomerang @Mff73
                              @mff73 Maybe it is just how we interpret things.
                              The manual describes the following note in the battery power management section:
                              If while exercising you start navigating or use navigation data like estimated time of arrival (ETA), the GPS goes to Best, regardless of the battery mode.
                              I read that note, but it never crossed my mind that ETA could interfere when you’re not navigating a route or if you turn the Navigation to “Off” in the activity settings.
                              Now, with the background knowledge it is obvious, but before it wasn’t.
                              OnePlus Nord 4
                              • Fenr1rF Offline
                                Fenr1r @Mff73
                                @mff73 Those were the only answers I came up with, too.
                                It seems peculiar that the existence of null-display capable ETE/ETA fields could possibly (and in the background) override two explicit user setting choices: GPS mode and (not using) navigation.
                                An override that the user would only discover afterwards. Or when the watch battery died early.
                                It’s mentioned as a Note in the User Guide, to be fair.
                                I don’t think the user would lose needed data (nav wasn’t selected), he/she would discover extra data (trackpoints) at the cost of battery power.
                                • Fenr1rF Offline
                                  Fenr1r @surfboomerang
                                  @surfboomerang TBH, it seemed so strange to me that I thought it might have been a typo.
                                    surfboomerang
                                    Now that I think of it… what about this situation?
                                    You create a route and send it to your watch.
                                    You start a hiking activity with the ETA and/or ETE fields configured and start navigating the route.
                                    After a while your battery reaches 10% and the watch asks you to switch profiles.
                                    You switch to Endurance or Ultra, but that is never going to work because you have selected ETA/ETE as datafields.
                                    So you can never preserve battery in this situation. Not even if you turn navigation off.
                                    OnePlus Nord 4
                                    Fenr1rF zadowZ 2 Replies Last reply Reply Quote 1
                                    • Fenr1rF Offline
                                      @surfboomerang Does the App allow you to create a sport mode with ETA/ETE fields AND GPS mode set to anything but Best?
                                      surfboomerangS 1 Reply Last reply Reply Quote 0
                                        surfboomerang @Fenr1r
                                        @fenr1r You don’t define GPS mode in the app. It happens in the watch.
                                        You can add ETE/ETA fields without a warning. When you select the sport mode and adjust GPS mode to OK in the watch, it also gives no warning.
                                        OnePlus Nord 4
                                        • Fenr1rF Offline
                                          @surfboomerang said in Hiking with battery mode Ultra:
                                          And that neatly answers what would have been my follow-up. Thanks.
                                          • zadowZ Offline
                                            @surfboomerang Hm, now I am not 100% sure, but if I remember it correctly, watch switch to BEST GPS every time, when ETA/ETE/destination field is in ACTIVE (current) display. Therefore, as long as on your current active display are none of navigation related fields, GPS stays in ULTRA. As soon as you switch to display with any of those fields, watch switch to best in order to give you info what you are requesting - ETA/ETE or remaining distance… you can look at it, note it and then switch back to display without these fields. watches should switch back to ULTRA. This is how I understand how it works. So, pretty smart, IMHO.
                                            Suunto Race
                                            Suunto Smart Sensor
                                            Wahoo Tickr FIT
                                            Hammerhead Karoo 2
                                            Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
