    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Polar OH1 Sync for Swimming
    14 Posts 4 Posters 1.2k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • fazelF Offline
      fazel Bronze Member
      Does anyone have experience using the Polar OH1 in sync mode for swimming activities. I used it this morning for the first time and the results are not what I expected. Here’s a link to the QS activity.
      https://quantified-self.io/user/Zj6gOpckgnhBQjWHN5Yno4rp0Bt1/event/2e35a8bd52b5903c4c1e86d33a1eb92f6bb9bee61ac5899cab5f2a1ec2be0889
      Direct export from SA and upload to training peaks looks a bit better…
      But neither look as nice as the chart after syncing with Polar Flow.
      Any ideas?
      M ? 2 Replies Last reply Reply Quote 0
      • M Offline
        margusl @fazel
        @fazel said in Polar OH1 Sync for Swimming:
        Using its memory function? It works only with Polar Beat mobile app. Though Polar API is now open and few more apps may have popped up.
        But OH1 is not able to sync its buffer to any Suunto watch. It can’t do that even with Polar’s own watches.
        What you see on a graph is a result of few random BT packets that have reached to watch while you were still in water. If you wear your OH1 and watch really close together you might actually log something meaningful while swimming.
        fazelF 2 Replies Last reply Reply Quote 2
        • fazelF Offline
          fazel Bronze Member @margusl
          @margusl thank you! I was wearing it on my goggles. Would it be better to turn off the memory function? Or is it broadcasting to the watch regardless of which mode it is in?
          M 1 Reply Last reply Reply Quote 0
          • fazelF Offline
            @margusl also - would I get good data if I used the Suunto belt and smart sensor?
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @fazel
              Yes.
              Blog: isazi's home
              fazelF 1 Reply Last reply Reply Quote 2
              • M Offline
                margusl @fazel
                @fazel , I only have H10, but I’m assuming(!) there’s no difference on that regard - so broadcasting should not be affected by standalone mode. To my surprise I got this while swimming with H10, recorded with A3P:
                fazelF 1 Reply Last reply Reply Quote 0
                • fazelF Offline
                  fazel Bronze Member @isazi
                  @isazi I’ll have to look. I have a blue belt that came with my Ambit3 Peak I believe. How long has the smart sensor been in production? I think that belt is three/four years old…
                  Thanks!
                  • fazelF Offline
                    @margusl I have the H10 too. This is not cached, correct - simply broadcasting?
                    • M Offline
                      margusl @fazel
                      @fazel , it’s still the same Smart Sensor, if your belt is OK (which, I’m afraid, is highly unlikely for a 3 or 4 y/o Suunto belt) it will work just fine with your 9
                      And as I don’t have an entry for that day in Polar Flow it must be from broadcast.
                      • ? Offline
                        A Former User @fazel
                        @fazel Hi, are you happy with this sensor ? It’s interest me for Hiking and running.
                        Have a nice day 🙂
                        Edit : i just see the baterry duration, to short for me
                        • fazelF Offline
                          fazel Bronze Member @Guest
                          @g287-sf Which sensor?
                          • ? Offline
                            @fazel i was meaning the Oh1. Sorry i miss some technical word in english.
                            • fazelF Offline
                              @g287-sf Okay - you are good. I like it a lot. Probably my favorite HR sensor. The only caveat is for some reason the connection is glitchy if I wear it on the opposite arm as my watch AND it (the OH1) is covered by one or more sleeves (which is frequent in the cold weather). So, if I’m running outside, I make sure to place the OH1 on the same arm as the watch. I’ve experienced zero dropouts this way.
                              When I ride rollers, the OH1 is connected to my laptop and Garmin 830 via ANT+ and my Suunto 9 via bluetooth. No issues with three connections.
                              ? 1 Reply Last reply Reply Quote 1
                              • ? Offline
                                @fazel thank you for your feedback, mine arrived today. I have the idea to wear it on the same front arm as my watch so it should be perfect. At first i want a classic one but for hiking it should bored me with my backpack sternum strap. So i prefer this one and charge it by night at my base Camp.
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
