    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Assisted GPS issues on S9 since 2.13.18
    19 Posts 6 Posters 1.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F Offline
      fritzbt2013 Bronze Member
      I’ve been having issues with the Assisted GPS feature on my S9 since updating to 2.13.18. I sync to the Suunto App on my iPhone.
      My problem became realized since heading out for a trail run a couple of days ago and I did not get GPS tracking right way. In fact it took 25 minutes into the run! Luckily I mostly knew the route.
      After the run I checked on the watch and it said my assisted GPS was not updated since 12/31/2020 (it was 1/15/21). I rebooted the watch and it synced right away. The next day the problem returns. This time I restarted the suunto App and it finally updated. Today I cant get it to update by restarting App. I have not restarted the watch yet.
      Prior to 2.13.18 I hardly thought about this. It seemed to update daily. What changed here? Does the AGPS data no longer update daily? Is this a new bug? What’s the work around? I love my S9 but I’m starting to think we need a break. Any assistance here is appreciated.
      NOTE: One additional detail I see my iOS App updated to 2.0 yesterday.
      isaziI ? F 4 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @fritzbt2013
        @fritzbt2013 if I am not wrong this is more about the app than the watch. Android users have not add the issue (except at the beginning of the year when Sony effed up). Is it still not working with the newly updated app?
        Blog: isazi's home
        • ? Offline
          A Former User @fritzbt2013
          @fritzbt2013 as I understood from @Dimitrios-Kanellopoulos there is an issue with the latest public release of iOS app and hotfix should come soon.
          F 1 Reply Last reply Reply Quote 1
          • F Offline
            fritzbt2013 Bronze Member @Guest
            @andrasveres Thanks for this info.
            @isazi Still not working unless I reboot watch (which I just did, so I’m good today).
            • ? Offline
              @fritzbt2013 is there any possibilities to you to downgrade your ios app if the new isn’t working good ?
              F 1 Reply Last reply Reply Quote 0
              • F Offline
                @g287-sf Not easily on iOS as far as I know.
                • ? Offline
                  @fritzbt2013 you must check on YouTube, i know it’s possible to install older version because i use an very old ipad and whe last version aren’t compatible. I have the possibility to instal other version. So maybe there is a way for you to.
                  At least you can jailbreak your iphone and do what you want 😉
                  • F Offline
                    fritzbt2013 Bronze Member @fritzbt2013
                    @fritzbt2013 Watch synced AGPS data without issue today (no firmware or SA update). So not sure of the failure pattern here. Maybe it’s a cloud service issue … will continue to monitor daily for now.
                    1 Reply Last reply Reply Quote -1
                    • F Offline
                      @fritzbt2013 Continues to work without issue for me now. Still on 2.0.0 and 2.13.18. One additional detail I want to add is that at some point when I was having issues I must have switched the app to only use GPS when using. I switched that to “Always Allow” and now the AGPS data updates overnight like it did before.
                      • ? Offline
                        @fritzbt2013 have you try to sync the watch with suunto link directly on your computer ? If i’m right it automatically update gps data
                        • ? Offline
                          A Former User
                          My AGPS is upgraded from today. I do the same trail as monday (i just stop 250m before)
                          I import all my data on QS and i can see my altitude info aren’t the same
                          Today
                          Monday
                          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                            Dimitrios Kanellopoulos Community Manager @Guest
                            @g287-sf what do you mean its not the same? They differ 3meters right?
                            Creator of Quantified-Self.io
                            youtube.com/c/dimitrioskanellopoulos
                            https://instagram.com/dimitrioskanellopoulos
                            https://www.strava.com/athletes/7586105
                            ? 1 Reply Last reply Reply Quote 1
                            • Łukasz SzmigielŁ Online
                              Łukasz Szmigiel
                              I think that we’re finally getting to a point where a sticky topic on GPS performance is necessary, as the amount of misconceptions about this technology is very high.
                              S9PP 2.50.26
                              1 Reply Last reply Reply Quote 3
                              • ? Offline
                                A Former User @Dimitrios Kanellopoulos
                                @dimitrios-kanellopoulos I mean when you look at mini and Maxi altitude it’s
                                First run 21m mini / 40m maxi
                                The second run it’s 8m mini / 20m maxi.
                                it was the exact same place and i follow the same GPX.
                                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                                  @g287-sf got it right… Same GPS system ?
                                  • ? Offline
                                    @dimitrios-kanellopoulos yes same set up, my S9Baro and SA to sync the gpx. Before everything i launch SA, sync. After i launch my watch wait for HR and GPS and that’s all.
                                    Watch is set in GPS/GZSS + Galileo (i’m in France)
                                      @g287-sf Try glonass should be more consistent on altitude or beidou
                                      • ? Offline
                                        @dimitrios-kanellopoulos ok i will try, it give me an excuse to do a the trail again 🙂
                                          @g287-sf haha
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
