    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS track with straight lines - allow location Android 10?
    Scheduled Pinned Locked Moved Suunto 3
    5 Posts 3 Posters 1.7k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      jw cou Silver Members
      Hi,
      My wife keeps getting strange GPS tracks with her S3, ok at the beginning but after a while only a couple of gps points recorded (see below)
      It happens all the time, not just a one-off issue.
      I checked the location permission on her phone (Xiaomi mi10t pro, Android 10 ), and it’s set to ‘Only while using the app’. I guess that’s the problem and should be set to ‘Always’, but the option doesn’t seem available for the Suunto app.
      Is there a known issue with Android 10 and S3, or am I looking at the wrong place to allow the watch to properly use the GPS of the phone all the time?
      I found a coupe of similar questions on the forum but without answers I could understand or try…
      Thanks!
      J 1 Reply Last reply Reply Quote 1
      • J Offline
        jw cou Silver Members @jw cou
        Just found a battery saver setting activated for SA… Removed it, will check this afternoon if that was the problem 🤷🏻‍♂️
        1 Reply Last reply Reply Quote 3
        • Jamie BGJ Offline
          Jamie BG Bronze Member
          Would also probably suggest that your wife turns off wifi and wifi scanning when tracking as I have noticed that sometimes wifi hits can cause the position to show up incorrectly.
          J 1 Reply Last reply Reply Quote 2
          • J Offline
            jw cou Silver Members @Jamie BG
            I confirm that the following solved the issue :
            settings
            battery and performance
            manage apps battery usage
            choose apps - Suunto app
            set to no restrictions
            michel Oude VoshaarM 1 Reply Last reply Reply Quote 4
            • michel Oude VoshaarM Offline
              michel Oude Voshaar @jw cou
              Hi,
              I have the same problem with my S3f. I did all things mentioned here but every run i get straight lines. My phone is an Samsung S9. Is there an solution for this
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
