Ambit3 Peak elevation gain
correct. The baro holes on the A3P are very prone to be clogged. Or sweat etc.
@Dimitrios-Kanellopoulos said in Ambit3 Peak elevation gain:
Or swear etc.
I can’t curse around my Ambit? Damn, that’s restrictive.
Oops.
@Fenr1r lol
Hello, so today the same problem after skimo. The watch shows in logbook ascent 792 m and descent 1179 m. I am posting link to Strava activity (where I have corrected elevation) as I do not have my smarthpone right now with me and cannot share from Suunto app. I have synced the watch with Suuntolink. I have cleaned the baro hole. Any more ideas? Thanks.
I think I win.
@fazel Nah, you’ve just peaked.
@dominikbalko looks like your descent is correct and your ascent is wrong. Do you have auto-stop on? Sometimes ski touring is so slow in the uphill, that the watch pause the activity. In that time you don’t collect ascent.
@marcrie Yes, I have it on. You are correct, I will try it next time with off. Thank you for help.
@marcrie Is it possible to edit minimum speed for pause?
@dominikbalko in movescount you can’t change the minimum speed. I also read the app developer manual and in my opinion there is also no possibility to do it via app.
@marcrie OK, I have browsed the apps available for watch, do you think this one should work as reminder to start activity after pause? Because I often forget to restart activity, that is why I am using auto-pause.
https://www.movescount.com/apps/app12691237-Restart_Reminder
@dominikbalko
nice
… you’re waking up sleeping dogs and pour salt in almost healing wounds
@freeheeler Sorry, I did not want to start a new thread as the auto-pause was related to this.
@dominikbalko looks good but just try it ;-). Maybe you have to set the value ‘3’ in line 10 to 1. At the moment the alarm beeps only if you are faster than 3km/h. I don’t know how fast you climb :-).
@Fenr1r have you read Sanderson (Way of Kings)? You remind me of Wit (aptly named).
@fazel maybe one of Elon Musks satellites started, hit a gps satellit and pushed it 3500m out of orbit
@dominikbalko
don’t get me wrong, it just reminded me how great those ambit apps were. I don’t entirely miss them but it is just great what’s possible
am facing a similar issue when going skitouring, I get always 200/300 meters more than in reality. I have Fusedalti activated, and noticed that the altitude is decreasing costantly when temperature drops (e.g exiting the car before starting the tour). I suspected the barometer and sent it for RMA but Suunto claims the barometer is ok.
As I would like to avoid setting manually the altitude every time before startin, is there any other workaround?
@zzmike76
is the behaviour different when you set the altitude manually before the start? -
@freeheeler yes when setting it manually it is more precise. I realized the skitour sport mode was set to auto, I will try this weekend with altitude mode only.
With my SSWHR I never had to set the altitude manually and readings were correct
Register Login
