    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Notification issues, not silencing phone...
    Scheduled Pinned Locked Moved Suunto 7
    53 Posts 6 Posters 8.7k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Jamie BGJ Offline
      Jamie BG Bronze Member @Lars Bengtsson
      @Lars-Bengtsson S7 with OnePlus 7pro. Don’t use phone silence settings as they can cause tracking issue. May be causing your other issues too, as have no problems at all with vibration due to notifications on watch. I think this is further reinforced by the fact you get notifications on watch?, And you vibration dues work for other stuff? Could try rebooting watch and phone (quite often connection issues are phone not watch).
      Lars BengtssonL 1 Reply Last reply Reply Quote 0
      • Lars BengtssonL Offline
        Lars Bengtsson @Jamie BG
        @Jamie-BG said in Notification issues, not silencing phone...:
        What sort of tracking issues? Maybe it has something to do with my problem also.
        The vibration is working when rebooting and such so it works.
        Believe me, I’ve rebooted both watch and phone several times. I reboot my devices regularly. I did a factory reset the watch again yesterday, no improvement.
        Suunto 7 black
        Oneplus 8T
        Jamie BGJ 1 Reply Last reply Reply Quote 0
          Lars Bengtsson
          I disabled these settings (se picture))
          And now the watch is working the way I want it to work, vibrating on every notification.
          But now the phone isn’t silent.
          How does the Suunto 7 sense that it’s on or off the wrist? Screenshot_20201229-135612.jpg
          I
          Suunto 7 black
          Oneplus 8T
            Lars Bengtsson
            Update:
            When I lay down to rest during the day I slide the notification slider on my oneplus 7 pro all the way up to “Do not disturb”, everything is muted except alarms.
            After I did this today I noticed that the watch and phone are behaving like I want them to. The phone is silent and the watch is vibrating.
            This is just wierd but at the same time I can use this while I wait for a solution. Because this is not how it should work.
            The search for a solution goes on…
            Suunto 7 black
            Oneplus 8T
            • Jamie BGJ Offline
              @Lars-Bengtsson
              When using the phone’s wear os silence option it seems to somehow clash with the suunto apps routing software, and if using a route while tracking and using the map screen to view the route, it can cause the watch to crash. Suunto are aware, and are looking into it, but might take a wear os fix rather than a suunto one - who knows, but in the mean time ensuring that silence is off prior to tracking a routed activity prevents any crashes.
              Not sure if it is using the Optical HR monitor or if there is another sensor, but seems to use that; as if you have set up and have GPay active, when you take your watch off your wrist it will automatically lock it. You have to put your passcode into the watch to unlock it.
              Re - Phone DND - may depend on your settings. Technically if your phone is DND - and you aren’t allowing any notifications, would suspect that your watch shouldn’t vibrate, as would expect it isn’t getting any notifications. But of course will depend on how you set up the DND.
              Lars BengtssonL 1 Reply Last reply Reply Quote 1
                @Lars-Bengtsson
                Seems like you know what you are talking about 😀
                I’m glad to hear that Suunto is aware of this issue, I’m not sure if Google is or if they even care and are going to do anything about it though 🤔
                I don’t have G-pay setup on my watch because G-pay on wearables are not yet available in Sweden.
                I haven’t done anything different in the setup if the DND on my oneplus, it works fine and it doesn’t seem to affect the notifications on the watch because now the watching is working just like I want it to. I just have to remind myself to turn off the DND on my phone when there take the watch off. Thankfully it isn’t that often and alarms on my phone is set to ring through DND, it’s even set to ring even if the phone is powered off 😎
                I’ve reached out to Suunto in every way possible and they got back to me on twitter and wanted to know which devices I’m having these issues with and the OS version of them so I think they’re at least going to look at the issue. Anxious to hear from support if they looked in to it and hear what they have to say about it 😉
                I wonder if it would help if I uninstalled the Suunto app and cleared cache afterwards? And maybe factory reset the watch and skip the setup of the Suunto app on the watch as well, just to se what happens 😋
                I have a friend who also have the Suunto 7 And and a oneplus 7 pro, only his phone had more RAM And is prepared for 5g. Mot sure if this makes any difference And not sure how he is using the suunto 7 and/or what his setup on notifications are bit i will check with him.
                A colleague of mine also have a Suunto 7 bit his phone is a Samsung Galaxy s20+ (l may have mentioned this before in this thread, not sure 🤓 ).
                Suunto 7 black
                Oneplus 8T
                • Jamie BGJ Offline
                  @Lars-Bengtsson I don’t think this has anything to do with the phone suunto app. I think this is more of a wear os watch/phone issue.
                    @Jamie-BG
                    Maybe you are right.
                    I got this in a reply from Suunto in a pm on twitter after I reached to to them:
                    "…check in the wearOS app in your phone. Under settings select notifications>silence phone>make sure silence alerts and notifications is OFF.
                    We need to also keep in mind there are a lot of things that have an impact on the said feature. On the watch, the software plays a big part, so make sure your software has been updated. On the phone, it would mainly depend on how Bluetooth protocols are handled, which in turn depends on the phone model, the software version, the platform, etc. We understand those challenges can be frustrating and please know we keep improving the suunto 7…"
                    I think they are aware of these issues and are working on it for future updates, and that’s enough for me. ☺
                    Suunto 7 black
                    Oneplus 8T
                    • olymayO Offline
                      olymay Gold Members
                      I don’t know if it’s the same issue you are having, but I put my S7 into battery saver mode during the night and when I wake it up in the morning, it no longer silences the notifications on my phone.
                      This is a WearOS issue on the phone, NOT an issue with the S7 or Suunto App.
                      To resolve it, I simply launch WearOS on the phone and go to Notifications>Silence phone while wearing watch where both toggles will already be on. I then turn each one off, and then turn them back on again. Et voila, my phone will once again be silenced.
                      May not work for you, but might be worth a try.
                      Suunto 7 Graphite Copper
                      Suunto App Beta (Android - Pixel 6 Pro)
                        Lars Bengtsson @olymay
                        @olymay said in Notification issues, not silencing phone...:
                        Interesting!
                        Otherwise after you’ve done this the notifications on watch and the phone is silent untill you set it to battery saver mode again?
                        What phone are you using?
                        *Edit: I saw in your signature that you have a Pixel 5 😊
                        Suunto 7 black
                        Oneplus 8T
                          Lars Bengtsson @Lars Bengtsson
                          @Lars-Bengtsson said in Notification issues, not silencing phone...:
                          Interesting!
                          Well I’ve tried this also on my devices but the problem remains…
                          I’ll wait and let the developers at Suunto, Oneplus and Google do their magic on this one 🙂
                          Suunto 7 black
                          Oneplus 8T
                          olymayO 1 Reply Last reply Reply Quote 0
                          • olymayO Offline
                            olymay Gold Members @Lars Bengtsson
                            @Lars-Bengtsson Correct. Every time I set the watch to battery saver and back again, it stops silencing the phone, despite the toggle in WearOS on the phone being set to silence.
                            As I do this every night I have gotten used to jumping into the app and toggling the settings off and on again.
                            It’s a minor gripe and something I still think is a WearOS issue unfortunately.
                              Lars Bengtsson
                              Update…
                              After the update from Suunto, no difference.
                              I’m waiting for the update to Android 11 from Oneplus, hoping that this will do the trick.
                              I’ve gotten used to having the settings like they are now, only thing that’s bugging me is that if I’m not wearing the watch Both the watch and phone are silent if I forget to turn off “do not disturb” on the phone…
                              I wonder why Suunto couldn’t fix this issue with the latest update…
                              Suunto 7 black
                              Oneplus 8T
                              • Jamie BGJ Offline
                                @lars-bengtsson you have lost me a bit there. But watch generally will be silent if DND is on the phone (depending on how you have set up your DND).
                                The watch, for most apps, runs off phone notifications, thus if they are off due to DND, you will not receive them on the watch - sort of makes sense.
                                If you want notifications on watch but not phone, then you need to use the silence phone option in the phones wear os app.
                                Of course standalone watch apps like agenda etc will continue to notify as part of watch, its not a push through notification.
                                  @jamie-bg Have you read the thread?
                                  As I explained in the beginning I have to have the phone on dnd, silent or what ever you call it (it’s a oneplus 7 pro so I have the notification slider up on the right side of the phone all the way upp so the phone is silent, no vibrations or anything. And I get notifications on my watch. This is exactly like I want it when I’m wearing the watch. There is one problem with this"fix"; if I forget to slide the notification slider on the phone to get notification in sound and vibrations I will miss calls and texts and more, this has happened a few times and it is a bit frustrating. If I go into settings on the wear OS app and set The phone to silent when watch is on and I’m wearing it, the phone still gives me notifications, both in sound and vibrations. But the watch doesn’t always give me a notification. The notification is there on the watch, I can see the little dot at the bottom of the screen. This is apparently a glitch that has to do with Wear OS and the watch OS. Been in contact with support and they are aware of the issue. I was hoping that the latest update would fix this but no such luck.
                                  Now I have to wait for Android 11 from Oneplus and maybe a update on the wear OS app from Google.
                                  Hope you understand my problem ☺
                                  If you have some tips or maybe even a fix for this issue I’m all ears. But please read the thread if you haven’t already so I don’t have to repeat myself.
                                  Maybe you have read it and I just didn’t remember that I am sorry 😊
                                  Suunto 7 black
                                  Oneplus 8T
                                  • Jamie BGJ Offline
                                    @lars-bengtsson This isn’t wear os or Android - this is purely OnePlus.
                                    That profile slide button is great, but it isn’t properly integrated into Android and that is what is causing the issue.
                                    I have similar problems with it, with other apps. I use a profile manager to create profiles and automatically switch them on and off i.e. set up a night one so no quite, wifi, data etc off, then early morning keeps quite but data wifi on and sync on, so pulls in all my email etc ready for me when i wake up. Just before wake up time, the profile switches back all volumes etc. this used to work great on my previous phone, but ever since got OnePlus it doesn’t. I have to use the slider every morning to switch from active to silent and back again . Personally would rather not have this feature as never use it - a profile switcher is a much better option, and or just as easy to adjust in quick settings. But is definitely linked to this slider and how they have tweaked android to make this work.
                                    So no I don’t see a solution at any time in the future, as would require OnePlus to fix.
                                      @jamie-bg But the problem was there before I started to use the slider. I started to used it to get notifications to work the way I wanted them to, just as they did with my other watches. The slider is just to silence the phone while the setting in Wear app for silencing phone is of because it doesn’t work for me. 😇
                                      Suunto 7 black
                                      Oneplus 8T
                                        Lars Bengtsson
                                        I bought myself a Oneplus 8T this week and I’m sad to say that the problem persists even on Android 11.
                                        I really hope Suunto is working on the issue.
                                        Suunto 7 black
                                        Oneplus 8T
                                          Lars Bengtsson
                                          Update:
                                          The issue remains. Been in contact with support for Suunto, Oneplus and Google but no help. Suunto is telling me to contact Oneplus and vice versa.
                                          Frustrating to say the least.
                                          Thinking of buying a different watch.
                                          Suunto 7 black
                                          Oneplus 8T
                                          aeroildA 1 Reply Last reply Reply Quote 0
                                          • aeroildA Offline
                                            aeroild Bronze Member @Lars Bengtsson
                                            @lars-bengtsson I just tested this on my Oneplus Nord and my Suunto 7. My Oneplus Nord is updated to Android 11 and I had the alert slider on Ring. In the Wear OS app I had selected that the phone should remain silent when receiving a phone call. When getting a phone call my phone’s display turned on, but there were no vibration and no ringing. My Suunto 7 did vibrate. I also tested it with the slider on Vibrate. Phone didn’t ring or vibrate, but watch did vibrate. So I guess I do not have the same issue that you have.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
