    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Backlight during a run activity
    15 Posts 9 Posters 1.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • P Offline
      pacos
      Hello,
      During a run activity the touch screen locks and to light the screen I have to press the middle button causing the screen sliding to the next… am I missing something or it’s so unpractical by design?
      Thanks
      DMytroD 1 Reply Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @pacos
        @pacos there are workarounds but not a direct solution. You can also search a forum for this, it was suggested functionality to be expanded.
        But you can try few things out:
        lock the buttons during activity, so you stay on the same screen while activating backlight
        Change to white theme to improve readability
        Toggle always on backlight
        Toggle backlight by tap with 2 fingers in watch settings
        Hope I’m not missing something.
        • surfboomerangS Online
          surfboomerang
          I would recommend to set the backlight to ON from the activity options right before you start running. This is a one-time setting so during your run, your backlight will stay on, but once you ended the activity the backlight functions as you configured it in the general options.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          markytarkyM isaziI 2 Replies Last reply Reply Quote 4
          • markytarkyM Offline
            markytarky Silver Members @surfboomerang
            @surfboomerang did you check how this influences the battery? I never tried and I’m curious. For example, 1h run without light is what? 3-4% of battery on performance mode with wrist HR on. If not, I’m going to try it myself tonight 😸
            Instagram
            Watch: S9B customized, S9P all black
            Suunto App: iOS beta
            freeheelerF surfboomerangS 2 Replies Last reply Reply Quote 0
            • freeheelerF Offline
              freeheeler @markytarky
              @markytarky
              it eats battery but only the nordic polar night lasts longer than the battery with backlight toggled on 😉
              living sideways
                surfboomerang @markytarky
                @markytarky Never watched it so closely, but I suspect it isn’t very much difference on a 1h run if you set the brightness to 5-10% (which makes it easy visible in total darkness).
                And you can always charge your watch again when you’re home 😉
                I can imagine this is an issue for ultra runners, but not for the rest of us.
                OnePlus Nord 4
                1 Reply Last reply Reply Quote 3
                • zadowZ Offline
                  zadow
                  with brightness set to 35%, 1 hour run with back light on, consumes approximately twice as much battery as with back light set to off. That is my observation on S9b.
                  Suunto Race
                  Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
                  Suunto Smart Sensor
                  Wahoo Tickr FIT
                  Hammerhead Karoo 2
                  Swim Ride Run Rest Repeat
                    Dimitrios Kanellopoulos Community Manager
                    as a side note there is also standbylight. That is like 2% of bightness and can help
                    Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                    BulkanB 1 Reply Last reply Reply Quote 2
                    • isaziI Online
                      isazi Moderator @surfboomerang
                      @surfboomerang said in Backlight during a run activity:
                      I am doing this for after sunset runs now. And I only learned about this feature a month ago! Before I was checking the watch only when passing under a lamp 🙂
                      Blog: isazi's home
                      • BulkanB Offline
                        Bulkan Moderator @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos said in Backlight during a run activity:
                        This is what I use most and the toggle of two fingers.
                        Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                        P 2 Replies Last reply Reply Quote 0
                        • P Offline
                          pacos @Bulkan
                          @Bulkan what’s the toggle with 2 fingers?
                          markytarkyM BulkanB 2 Replies Last reply Reply Quote 0
                          • P Offline
                            pacos @Bulkan
                            @Bulkan at this time the most practical way is setting the battery mode in customized, same as performance, but activating the touch screen… is it touch screen active consuming more battery?
                            surfboomerangS 1 Reply Last reply Reply Quote 0
                              surfboomerang @pacos
                              @pacos battery drain for touch is negligible but touch with long sleeves and sweat can make the watch do things you don’t want.
                              OnePlus Nord 4
                              1 Reply Last reply Reply Quote 4
                                markytarky Silver Members @pacos
                                @pacos you can activate the light with a touch on your screen with 2 fingers at the same time. This is a kind of manual light activation.
                                Instagram
                                • BulkanB Offline
                                  Bulkan Moderator @pacos
                                  @pacos Here you have how to activate toggle.. Is very useful.
                                  @pacos said in Backlight during a run activity:
                                  I always use with touchscreen on, because I don’t do events too long diary. The touch battery for me works pretty well but I live in a place where I don’t run in low temperatures.
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
