    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 fails to sync after charging
    13 Posts 7 Posters 844 Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Stevek
      Hi,
      I’m new to Suunto and got a 9 in the black friday sales. All good at first, downloaded app and then pair watch and good to go. No problem syncing activities etc. I plugged into PC with Sunntolink to charge and make sure I was on latest firmware. After that it wouldn’t sync with my Andriod phone. A simple unpair and pair fixed that. 5 days later I needed to charge, this time plugged the cable into my standard charging port. Again the watch didn’t sync after charging. This time I had to delete app, reboot watch before I could pair and sync.
      Any ideas?
      Thanks,
      Steve
      Brad_OlwinB Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator
        Well, I would have suggested to soft reset the watch, that you already did.
        Let’s see if it’ll get stuck again.
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        S 1 Reply Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Stevek
          @Stevek I am not on Android so I cannot help much but list the phone, version of SA you using and that will help. Also, do you have Movescount app installed on your phone?
          Vector/T6c/Vertical 2 Ti
            Dimitrios Kanellopoulos Community Manager @Stevek
            @Stevek what app version are you using ?
            Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
            • S Offline
              Stevek
              I’ve not used the Movescount app
              App version 4.31.0
              Watch software: 2.12.30
              I did sign up for the beta app, in case that helped. But I’ve not loaded it yet.
              Thanks
              • S Offline
                Stevek @sartoric
                @sartoric Interesting. Although it was on 95% after the last charge, but I recharged anyway to see if it would get stuck again. And it seems OK - maybe that soft reset worked. It’ll probably be 4 or 5 days before it needs charging again. I’ll post an update then. Thanks
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  @Stevek Did you update the watch while you had not synced an activity ?
                  • cosme.costaC Offline
                    cosme.costa
                    @Dimitrios-Kanellopoulos I think there is a small bug with the last firmware of the watch or the combination of the watch and SA. I have suffered it 3 times already, that every now and then the watch and SA are unable to sync. SA is not able to see the watch. In my case soft reset solves the issue, I haven’t tried to reboot the phone or other things.
                    I’m waiting to this to happen again to get some logs but I have read in the forum that other people has had this issue so I think that is more general. Because it happens from time to time, I couldn’t determine what triggers it, maybe the number of syncs, I do not know.
                    What I know is when it is going to happen because, after saving the activity, the watch is extremely slow to load the autolaps screen, it loads first one km, then the second, then the third, …. Until the screen shows all the autolaps. Because of that I am more inclined to believe that the issue has been introduced with the last firmware.
                      Dimitrios Kanellopoulos Community Manager @cosme.costa
                      @cosmecosta that is known (soft reset that solves the issue).
                      Android version 4.33.1 should come with a fix .
                      You are on Android right?
                      cosme.costaC 1 Reply Last reply Reply Quote 1
                        cosme.costa @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos said in S9 fails to sync after charging:
                        Yes Android 10 (Android One)
                        Good to know that is known and solved.
                          @cosmecosta So just to repeat. For your info:
                          • Sometimes when the connection is establised and lost many times (eg try to turn BT on/off many times or connect to SL etc) the watch becomes laggy (lost packets) and cannot connect to the app after that. A reboot helps.
                          This is fixed as said and will come to you I think next week
                          M 1 Reply Last reply Reply Quote 2
                          • M Offline
                            Mi_chael Bronze Member @Dimitrios Kanellopoulos
                            With a firmware update?
                            isaziI 1 Reply Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @Mi_chael
                              @Mi_chael 4.33.1 is the next Android beta.
                              Blog: isazi's home
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
