    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Spartan compatible with polar h10 hr sensor
    Scheduled Pinned Locked Moved Spartan
    16 Posts 12 Posters 2.1k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • P Offline
      paddlingnorm
      Hi all,
      Can anyone confirm if the polar H10 sensor is compatible with the Suunto Spartan watches?
      Ive had two Suunto belts and neither lasted longer than 6 months, the H10 gets good reviews and I have seen an odd comment saying it is compatible but before spending the money Id like to know if anyone here can confirm this.
      Cheers
      J pilleusP Luke_SkyrunnerL P R 5 Replies Last reply Reply Quote 0
      • J Offline
        johann.fuehrer Bronze Member @paddlingnorm
        @paddlingnorm Hello,
        I can confirm this, works great!
        P 1 Reply Last reply Reply Quote 1
        • pilleusP Offline
          pilleus @paddlingnorm
          @paddlingnorm Polar H10 and Polar OH1 are working fine here with the Spartan Ultra. 👍
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          • P Offline
            paddlingnorm @johann.fuehrer
            @johann-fuehrer Fantastic, thank you
            • B Offline
              bbx100 Bronze Member
              Is Polar H10 compatible with Spartan watch regarding swimming option. Can it transfer data after swimming into the watch?
              isaziI 1 Reply Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @bbx100
                @bbx100 no, only the Suunto sensor can. I wish there was a supported standard for this but apparently there is not.
                Blog: isazi's home
                B 1 Reply Last reply Reply Quote 0
                • B Offline
                  bbx100 Bronze Member @isazi
                  @isazi Thx for info, I presumed it so too
                  • J Offline
                    jsuarez Bronze Member
                    For running the H10 works great with my SSWHRBaro and is much much frugal on batteries than the Suunto smart sensor.
                    Mff73M 1 Reply Last reply Reply Quote 0
                    • Mff73M Online
                      Mff73 @jsuarez
                      @jsuarez said in Spartan compatible with polar h10 hr sensor:
                      My Suunto Sensor batteries last almost 300h each (with on record around 400h) 🙂 Which is for me roughly one year.
                      Do you mean that H10 batteries last much much longer ? 🤔
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                      J J 2 Replies Last reply Reply Quote 0
                      • J Offline
                        johann.fuehrer Bronze Member @Mff73
                        @Mff73 I’m using mine now nearly two (2!) years with the same battery, which is somewhere in the range of >400 hours and the battery seems to be still quite good. But it depends also highly on the ambient temperature and how cold the battery gets during workouts.
                        • Luke_SkyrunnerL Offline
                          Luke_Skyrunner @paddlingnorm
                          @paddlingnorm Yes it works perfectly. I had the same problems with the Suunto belt and never regrets buying the Polar HR10.
                          • J Offline
                            jsuarez Bronze Member @Mff73
                            @Mff73 Well, that’s not bad, but quite different from my mileage. In my case batteries used to last between 3-4 months (running about 3 times a week with sessions lasting 1 - 1:30hr). I always made sure that after exercise the sensor was removed from the band and the contacts were dried.
                            The H10 was more in the range of 8-9 months. That’s a rough estimation. But the truth is that I really could feel that it drained much less battery.
                            The readings of both Suunto and H10 were fine (the H10 had less spurious HR spikes, but more or less the same overall reading quality).
                            • P Offline
                              paul870 @paddlingnorm
                              @paddlingnorm yup… I had similar problems with the Suunto belt, switched to the Polar H10 and it’s been perfect for nearly 2 years now.
                              Just started to play up a little, but sadly that’s my lack of care with regard to cleaning the belt, you really do need to give it a clean with a mild soap at least every couple runs, when I’ve run hard its easy to not bother, well it is for me.
                              Paul
                              SSS
                              Ambit3 sport
                              • R Offline
                                RiphRaph Bronze Member @paddlingnorm
                                @paddlingnorm You were lucky with your Suunto belts, mine malfunctioned after less than two months!
                                Formerly Spartan Sport WHR, happy Coros Vertix user since Sept. 2020
                                • C Offline
                                  chaichaichai
                                  Hi, Is there a list of compatible Hear Rate belts with Suunto watches and the App? I have a baro but it seems the suunto HRM is out of production…would the garmin dual be compatible?
                                  cheers
                                  sartoricS 1 Reply Last reply Reply Quote 0
                                  • sartoricS Offline
                                    sartoric Moderator @chaichaichai
                                    @chaichaichai
                                    Are you sure ?
                                    https://www.suunto.com/en-gb/Products/Heart-Rate-Belts/suunto-smart-heart-rate-belt/
                                    Maybe it’s temporarily unavailable somewhere,
                                    SVTS - 2.50.28
                                    SSSWHR BARO Amber - 2.8.32
                                    Samsung A5 2016 - Android 7.0
                                    Suunto App Android 6.7.12 beta
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
