    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Random reboots of the Suunto 7 during recording an activity
    Scheduled Pinned Locked Moved Suunto 7
    suunto5rebootrecordingactivity
    119 Posts 17 Posters 28.2k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager
      I had a user in another forum that said that if you disable these settings in the wear os app it fixes his issues
      Creator of quantified-self.io
      youtube.com/c/dimitrioskanellopoulos
      instagram.com/dimitrioskanellopoulos
      www.strava.com/athletes/7586105
      olymayO 1 Reply Last reply Reply Quote 1
      • olymayO Offline
        olymay Gold Members @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos Thanks for the info.
        I have tried tracking an activity (again, from sat at my desk) with these settings both on and off and I can confirm that it has worked for me.
        When it crashed, I checked my settings and the ‘power saver tilt’ was again turned on, despite my having turned it off.
        When it worked OK (with the settings shown turned off) the ‘power saver tilt’ stayed turned off.
        So, it appears that some settings (map always on, WearOS notification settings) can force ‘power saver tilt’ to turn back on.
        I use these WearOS notification settings, so this is certainly not an acceptable permanent solution.
        I believe this is still a problem with ‘power saver tilt’.
        Suunto 7 Graphite Copper
        Suunto App Beta (Android - Pixel 6 Pro)
        Jamie BGJ Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
        • Jamie BGJ Offline
          Jamie BG Bronze Member @olymay
          @olymay - what watch face are you using? Are you using one of the suunto power save watch faces? If so have you tried with another watch face, as it should automatically disable power save tilt?
          olymayO 1 Reply Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @olymay
            @olymay said in Random reboots of the Suunto 7 during recording an activity:
            what do you mean?
            • olymayO Offline
              olymay Gold Members @Jamie BG
              @Jamie-BG I am using the ‘Heatmap’ watch face. It is beautiful and it is the one I want to use.
              I am prepared to make only so many concessions when using a £400 smartwatch, and using a watch face I do not like is not one of them, sorry.
              Jamie BGJ 1 Reply Last reply Reply Quote 0
              • olymayO Offline
                @Dimitrios-Kanellopoulos In your message before mine, the one with the screen shot. I turned off both of those settings and was able to track an activity, following a route, scrolling to the map screen AND had map always on turned ON. The app did not crash because it did not force ‘power saver tilt’ to turn ON.
                • Jamie BGJ Offline
                  @olymay - I am not suggesting as permanent fix, but it may be the cause of the issue as to why power save tilt switches back on, and knowing whether it does this with or without this type of watchface may give the devs a better idea of the cause and thus enable the fix to be found quicker.
                  • olymayO Offline
                    @Jamie-BG Sorry, my last reply came across sharper than I intended.
                    I have now tried with a non Suunto watch face.
                    I tried with all of the combinations I have previously mentioned (I have done them so many times now I don’t even to refer to my notes anymore!) and I can confirm that the choice of watch face had no impact on the result.
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                      @olymay but you still have the issue after those optins where disabled (at my screenshot above)?
                      Just making sure
                      • olymayO Offline
                        @Dimitrios-Kanellopoulos sorry, I waffled a bit.
                        After I turned off the notification settings in your screenshot, I no longer had the issue of the app crashing during an activity.
                        I now have two options before my next run (maybe tomorrow):
                        • On the Watch, turn OFF the always on map in the Suunto Wear App: Power saving>Display>Always-on-map
                        • On the phone, turn OFF both of the notification settings in the WearOS app: Notifications>Silence phone while wearing watch>Silence incoming calls & Silence alerts and notifications
                        Both of these seem to allow an activity to track and use the map screen without forcing the ‘power saver tilt’ to reactivate and crash the app.
                        I can also confirm that the choice of watch face has NO impact on the watch crashing, for better or worse.
                        1 Reply Last reply Reply Quote 3
                        • R Offline
                          Robert_mp @olymay
                          Hi @olymay and @Dimitrios-Kanellopoulos , yesterday I made a small test (25min walking, 2,2 km). All was ok, NO crashing… but maybe it was too short.
                          Configurations:
                          Sport mode: custom of walking with: 4 fields screen, 4 fields screen, map screen
                          Exit the app while recording: yes
                          Phone call: no
                          Music controls: yes
                          Follow a route: yes
                          Always on map: enabled and disabled (mostly enabled, but I tried to change between both options to test a bit more)
                          AoD: on
                          Tilt to wake: off
                          Tap to wake: off
                          Power save tilt: off (I checked before the activity, during the activity some times, and in the end of it, that this option was all the time OFF and it didn’t changed to ON)
                          During the activity I changed lots of times to the map view, and it was fluent while I was operating with the watch. I only had lag on the summary of the activity when I finished (I experience this always)
                          What I also experienced, but maybe is a different point to this thread, is that if I had “map always on” activated, when I changed to a screen different from the map, let it go to save battery mode, and the forced it on again, when I changed to the map view, it turned back to 200m zoom (it doesn’t keep the last one), and it was like it loaded the map again. With “map always on” desactivated, I haven’t experienced this issue.
                          • olymayO Offline
                            olymay Gold Members
                            After a few days of rest, I went for another run today.
                            Settings:
                            Sports mode: Basic run tracking a route
                            GPS: 1s
                            Aeroplane: OFF
                            AoD: ON
                            Tilt to wake: OFF
                            Tap to wake: OFF
                            Map always active: ON
                            Power saver tilt: OFF
                            Brightness: AUTO
                            Music streaming to BT headphones and controlled from headphones.
                            These were exactly the same settings as I reported on the 2nd November, with one key difference.
                            This time, I followed the advice in @Dimitrios-Kanellopoulos post and I turned off the silence notification settings in WearOS on my phone.
                            Everything worked perfectly!! I was able to use all of the screens, including the map screen, and the data screens always returned to the low power mode and did not crash the app.
                            I have checked and can confirm that ‘power saver tilt’ has NOT been turned back on.
                            It’s not ideal, but at least I now have a usable interim solution until Suunto roll out the proper fix for this problem.
                            If anyone else is still experiencing the app crashing, please try and this ‘fix’ and let me know how you get on 🙂
                            • P Offline
                              Piotrd
                              Hi all,
                              I am experiencing the same problem, tried different settings, no luck. But what I find the worst is the response I got from suunto. I sent it to have it fixed, described it thoroughly, and…they sent it back to me, with a note that it works fine for them.
                              I read here it’s a known issue, yet authorized customer service is not giving a beep about it. So they just can’t fix it and so they pretend there’s no issue? That’s so lame. Can’t use it, can’t even sell it cause I don’t want to sell a buggy device. Sorry suunto, never again. They should return money or offer replacement, but they prefer to lose clients.
                              pavel.samokhaP 1 Reply Last reply Reply Quote 0
                              • pavel.samokhaP Offline
                                pavel.samokha @Piotrd
                                @Piotrd sorry for your experience.
                                Have you tried what we’ve figured out in this topic:
                                1. Go to settings -> gestures -> disable “power saving tilt” and reboot the watch after that
                                2. On your mobile phone in WearOs App go to Notifications -> Silence phone while wearing watch, and check that options there are disabled
                                After that there were no problems for me with S7
                                Opinions expressed are solely my own and do not express the views or opinions of my employer
                                P 1 Reply Last reply Reply Quote 3
                                • olymayO Offline
                                  olymay Gold Members
                                  @Piotrd i was having this exact same issue and I can confirm that what @pavel-samokha suggests works (at least it does for me). Give it a try and see how you get on.
                                  I understand there is a fix for this coming soon 🙂
                                  • P Offline
                                    Piotrd @pavel.samokha
                                    @pavel-samokha @olymay
                                    Thanks a lot guys. Will test it today.
                                    So the phone should NOT be SILENCED, is that right? Can it be done just before run and reverted afterwards or does it need a watch reboot too?
                                    • olymayO Offline
                                      olymay Gold Members @Piotrd
                                      @Piotrd Correct, in WearOS app on the phone, go into notifications and turn off both toggles under ‘silence phone while wearing watch’. This is what I do and it works for me.
                                      And yes, you can toggle this for each individual activity and you should not need to restart your watch or phone each time.
                                      I keep a note on my running headphones to remind me to turn it off each time I go out 😉
                                      • P Offline
                                        Piotrd @olymay
                                        @olymay @pavel-samokha thx a ton guys, it worked! Only tried once so far, but seems that this might be the solution. If it works, I’m ok waiting for the update, at least the watch is usable now!
                                          pavel.samokha
                                          I guess with arrival of PXDZ.201119.005.A1 this one should be closed, it’s fixed
                                          P.S. And thanks for all who contributed to the subject, I believe it helped solving the issue and workaround was really helpful in the meantime
                                          1 Reply Last reply Reply Quote 7
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
