    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Random reboots of the Suunto 7 during recording an activity
    Scheduled Pinned Locked Moved Suunto 7
    suunto5rebootrecordingactivity
    119 Posts 17 Posters 34.9k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • olymayO Offline
      olymay Gold Members
      I have taken a video of the issue as it happening today. This was recorded indoors, so there is no GPS lock, however it does the same thing even with a lock.
      Suunto 7 Video
      Suunto 7 Graphite Copper
      Suunto App Beta (Android - Pixel 6 Pro)
      pavel.samokhaP 1 Reply Last reply Reply Quote 0
      • pavel.samokhaP Offline
        pavel.samokha @olymay
        @olymay had very similar symptoms. For some reasons watch can’t switch to offload(ambient)-mode and as I said - factory reset fixed the issue for me
        Opinions expressed are solely my own and do not express the views or opinions of my employer
        olymayO 1 Reply Last reply Reply Quote 0
        • olymayO Offline
          olymay Gold Members @pavel.samokha
          @pavel-samokha I’ve done one factory reset. I’ll try another later today when I have some time. I’m also getting a new phone tomorrow (Pixel 5) so that will also force another reset and maybe that combination of three resets and a new phone will persuade it to work.
          If not, it’ll go back to Sunnto for a refund and I’ll buy a Garmin 😞
          pavel.samokhaP pilleusP Brad_OlwinB 3 Replies Last reply Reply Quote 0
            @olymay I also reported this to Suunto, will try to push the issue
            • pilleusP Offline
              pilleus @olymay
              @olymay with a new phone you do not need to reset the S7. Search for the adb solution in xda-developers. It’s easy to use. 👍
              https://www.instagram.com/moves.are.life/
              Suunto Vertical Black Lime
              Suunto 9 Peak Pro Black
              Suunto Spartan Ultra Stealth Titanium
              • pilleusP Offline
                pilleus
                A walk with a loaded route and fused track didn’t cause any problems. I cancelled the route on the way and reloaded it, no problem.
                I am sure that it’s a software related problem in connection with the phone.
                olymayO 1 Reply Last reply Reply Quote 1
                • olymayO Offline
                  olymay Gold Members @pilleus
                  @pilleus Can you try with the higher accuracy gps track? I have never used the fused track (I don’t run for long enough to worry about battery life… yet).
                  And when I run I do not take my phone with me, so how could that connection be the issue?
                  I do agree with yo in that it is likely a software issue, as this has only been happening since the recent big update.
                  Yes, I do know that I can use the ADB solution (used it before with other Wear OS watches) but as I seem to be resetting the S7 almost daily at the moment it isn’t really an issue to do it when I get my new phone 🙂
                  pavel.samokhaP pilleusP 2 Replies Last reply Reply Quote 2
                    @olymay if you’re able to work with adb - then try to do adb bugreport please
                    • pilleusP Offline
                      pilleus @olymay
                      @olymay okay, I don’t use the S7 without phone, because both gadgets are on board. 😊
                      Tomorrow I will be back with an activity with best GPS settings and without phone connection.
                      • olymayO Offline
                        @pavel-samokha More than happy to try, but that isn’t something I have done before. Do you have a link to a guide please?
                          @olymay don’t have exact guide, roughly the same as with android phone:
                          • Install ADB on you computer
                          • Enable Dev mode on Suunto 7 (in Settings->About-> click multiple times (7 or 10, don’t remember) on Build Number)
                          • Enable ADB debugging on Suunto 7 (Settings -> Dev options -> ADB debugging)
                          • Connect Suunto 7 to your computer via cable
                          • Authorize this computer to debug on S7 (popup should appear on S7)
                          • Open Command Prompt on your computer and type adb bugreport
                          After that you should have file with bugreport
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @olymay
                            @olymay That is not normal, and I have not seen this problem. I would definitely contact support. They are typically quite helpful.
                            Vector/T6c/Vertical 2 Ti
                            BulkanB 1 Reply Last reply Reply Quote 0
                            • DRezvoffD Offline
                              DRezvoff
                              there is a problem if 2 applications are installed and running simultaneously on the Smartphone - Movescount and SuuntoApp
                              Suunto 9 Peak Pro Titanium
                              Suunto Spartan Sport WHR
                              Sony Xperia 1, Android 10.
                              • BulkanB Offline
                                Bulkan Moderator @Brad_Olwin
                                @Brad_Olwin I have a friend in the exactly situation and my S7 doesn’t do it.
                                Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                                • pilleusP Offline
                                  pilleus
                                  The problem seems to be solved for my S7 after 3 crashes and 3 factory resets.
                                  5 activities with different settings and without any problem.
                                  2 activities with connected phone, AOD, tilt-to-wake, best and good GPS settings, no route and route.
                                  3 without connected phone, with and without AOD, with and without tilt-to-wake, with best GPS and route.
                                  May be that after the update something was left in the cache or something else was wrong.
                                  It’s okay for me now. 👍😊
                                  • olymayO Offline
                                    olymay Gold Members
                                    GOOD NEWS EVERYONE!!
                                    After three factory resets my watch seemed to be behaving last night (was only tested indoors and not on a run). My new phone arrived this morning so I went through a fourth factory reset to connect that.
                                    I have just been for a 7K run following a route and it worked PERFECTLY!!
                                    It seems that multiple factory resets (three seems to be the magic number) manages to clear whatever glitch may be present.
                                    pilleusP 1 Reply Last reply Reply Quote 2
                                    • pilleusP Offline
                                      pilleus @olymay
                                      @olymay said in Random reboots of the Suunto 7 during recording an activity:
                                      It’s magic! 😜🤣👍
                                      • sheraniS Offline
                                        sherani
                                        Unfortunately I was not so lucky, yesterday fifth hard reset and I can still reproduce the app crash during the activity following a path. Going through the various screens you first notice a slight slowdown passing from the laps screen to the one with the altitude profile while all the others transitions are smooth. However, the problem occurs just after 5-6 km until the final crash of the app and loss of activity data. I state that I always run without a mobile phone and I also tried to activate the airplane mode to see if anything changes, obviously without success.
                                        olymayO 1 Reply Last reply Reply Quote 2
                                        • olymayO Offline
                                          olymay Gold Members @sherani
                                          @sherani That sounds like a right pain in the a**! It also sounds like yours it lasting significantly longer before crashing than mine did (mine was crashing as soon as it tried to go into power saving mode).
                                          By hard reset, do you mean a full disconnect and factory reset? If not, I would suggest trying this, and it may take a few times (it took me three!). If that is what you have done, then you may have to send it back to Suunto 😞
                                            pavel.samokha
                                            Hello guys.
                                            As you know I reported the bug and response is that it’s known and top priority at Suunto. Should be fixed with next update but unfortunately third-party (hardware provider) is involved so no ETA.
                                            1 Reply Last reply Reply Quote 8
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
