    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Intensity target - how to turn it on?
    12 Posts 5 Posters 857 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • kabziorK Offline
      kabzior Bronze Member
      OK, so this a little bit embarrassing, but how can one turn intensity as a target?
      I wanted to have HR zone as a target during running, so according to manual:
      To exercise with intensity target:
      Before you start an exercise recording, swipe up or press the lower button to open the sport mode options.
      Tap Targets or press the middle button.
      Toggle Intensity on.
      Select Heart rate, Pace or Power.
      (The options depends on selected sport mode and if you have a power pod paired with the watch).
      Select your target zone.
      Swipe right to go back to the sport mode options.
      But when I go to “Targets” I only have “duration” or “distance” and I cannot see anywhere any Intensity toggle. Am I looking in wrong place?
      Thanks for help.
      • sartoricS Offline
        sartoric Moderator
        You should check HR zones option in the start screen.
        But, which watch model do you have?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        kabziorK 1 Reply Last reply Reply Quote 0
        • EgikaE Offline
          Egika Platinum Member
          this is in S9 section - so obviously an S9
          • sartoricS Offline
            sartoric Moderator
            Nothing is obvious 😁
            SVTS - 2.50.28
            • kabziorK Offline
              kabzior Bronze Member @sartoric
              @sartoric said in Intensity target - how to turn it on?:
              And where exactly is that HR option?
              By “start screen” you mean the one just before start registering, when you can press lower button to go to options? I do not see any HR option over there…
              S9B
              isaziI 1 Reply Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @kabzior
                @kabzior go to the start menu, options, intensity zones, keep going right, press the lower button when asked, select your zone.
                Blog: isazi's home
                kabziorK 1 Reply Last reply Reply Quote 1
                • kabziorK Offline
                  kabzior Bronze Member @isazi
                  @isazi said in Intensity target - how to turn it on?:
                  Thank you very much Sir, either I am slow or this is like the most embroiled part of user manual 😉
                  BTW, manual mentions also:
                  In addition, there is a dedicated display for HR zones in the sport mode default display.
                  The zone display shows your current HR zone in the middle field, how long you have been in that zone, and how far away you are in beats per minute to the next zones up or down.
                  The background color of the bar also indicates which HR zone you are training in.
                  How do I get this screen? Do I need to set it up in SA in my custom sport mode?
                  isaziI 1 Reply Last reply Reply Quote 1
                  • isaziI Offline
                    @kabzior it’s in the default running mode, and you can add it to customized modes too.
                    Blog: isazi's home
                    • kabziorK Offline
                      Indeed I can, thank you very much once again.
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @kabzior
                        @kabzior I agree that the manual can be terse and features can be difficult to find. However, once you know them I think the UI is brilliant. A lot is packed onto a small screen without wasting space. For example, I know what zones I am supposed to exercise in so I never have a field showing HR, it is simply too easy to see on the zone ring. You can have the zone ring show without a target zone if you wish (this is how I usually use it). When you arrive at the select target screen simply go back without selecting a target.
                        Vector/T6c/Vertical 2 Ti
                        kabziorK 1 Reply Last reply Reply Quote 3
                        • kabziorK Offline
                          kabzior Bronze Member @Brad_Olwin
                          @Brad_Olwin Yes, I agree with you on that, UI is clean and easy to use, I must admit this is the first time I was not able to find something, now that I already know where is it, it seems logical, but I was mislead by the manual. So my complain here is rather about the manual than the watch itself.
                          And yes, the ring is super useful, this is how I used it so far, but since I wanted to go deeper into HR zones I wanted to try target zone and dedicated screen, do not know whether I will use it or not, but it is worth to try since it is there 🙂
                          Brad_OlwinB 1 Reply Last reply Reply Quote 2
                            @kabzior I agree about the manual, I rarely find out how something works from the manual:)
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
