    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 barometer problems
    69 Posts 11 Posters 14.0k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Dimitrios KanellopoulosD Online
      Dimitrios Kanellopoulos Community Manager @Anssi Auvinen
      @Anssi-Auvinen correct.
      Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
      • EfejotaE Offline
        Efejota Bronze Member
        @Dimitrios-Kanellopoulos : It might be useful to check this activity, that showed a similar behaviour on Monday: https://quantified-self.io/user/b8N0uPCCIxbEKbOPC3wYZMdRP8A2/event/5d0113bf1a5b3af0bc8e360b6c8ddcab1ecdf1647d68d6609bb77180d3c117c1
        No wind, clean sensor, latest firmware.
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Efejota
          @Efejota I looked at this but there is nothing to compare to, what is the problem?
          Vector/T6c/Vertical 2 Ti
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @Brad_Olwin
            @Brad_Olwin different altitude start / end by same place 100m.
            EfejotaE 1 Reply Last reply Reply Quote 2
            • EfejotaE Offline
              Efejota Bronze Member @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos Yes, but not only that. You can see that there were several loops and a progressive descent on the lowest point before the small ascent.
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                Dimitrios Kanellopoulos Community Manager @Efejota
                @Efejota yes yes. That to me looks quite bad. Is it like this all the time ?
                EfejotaE 1 Reply Last reply Reply Quote 0
                • EfejotaE Offline
                  @Dimitrios-Kanellopoulos To be honest, sometimes I noticed differences, but never paid much attention. The other day it was quite evident and remembered it when I read the post. I can check other activities to see when happened.
                    @Efejota keep a decent look for future ones. 😄
                      Brad_Olwin Moderator @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos said in S9 barometer problems:
                      Maybe FusedAlti did not activate for this. I do not see a calibration change when FusedAlti typically activates.
                      Dimitrios KanellopoulosD EfejotaE 2 Replies Last reply Reply Quote 0
                        @Brad_Olwin it can well be.
                        • EfejotaE Offline
                          Efejota Bronze Member @Brad_Olwin
                          @Brad_Olwin When should it happen? I mean, I assumed that it worked automatically, but, if it were the case, when does it kick in? It might be possible that the activity that I shared was started without my usual warm up.
                          Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 0
                            @Efejota it happens like this:
                            if the average vertical error for the GPS altitude is low for x amount of time and the current altitude difference is less than the error, it triggers.
                              @Efejota Here is an example, often the shift in altitude can be more abrupt than this one. Here the S7 did not need to enable FusedAlti but the S9 did. I circled where FusedAlti activated for the S9 and you can see the profiles then match each other.
                              • Anssi AuvinenA Offline
                                Anssi Auvinen
                                Last saturdays ride 136 km’s bike race: S9B elevation 1060m+
                                https://quantified-self.io/user/0NQynLXMmLPswXyjLJcHqdLJvam2/event/VPak9mH6lqgyzX7qpLsO
                                Garmin edge 530: 1607m+
                                Garmin edge 830: 1419m+
                                Garmin edge 830: 1380m+
                                Garmin Edge 530: 1401m+
                                Polar M460: 1575m+
                                Garmin edge 520+: 1,232m+
                                Garmin edge 520: 1279m+
                                Polar Grit X: 1,626m
                                Wahoo ELEMNT BOLT: 1474m+
                                cosme.costaC fazelF 2 Replies Last reply Reply Quote 1
                                  Anssi Auvinen
                                  Found also one Suunto Spartan ultra result with 1422m+.
                                  • cosme.costaC Online
                                    cosme.costa @Anssi Auvinen
                                    @Anssi-Auvinen I think you should contact support, maybe you baro is defective, more comparing with the SSU. Or, checking your values, it is the algorithm itself. I mean, according to the values your lowest and highest altitude are relatively close, so to get these more than 1000 m of ascent is with relative small uphills, Suunto has certain thresholds to trigger the ascent counting, I do not know the values for biking but for running are 3 m for baro and 7 m for non baro in some minutes. Depending on these thresholds some brands can overcount or undercount (suunto tends to undercount).
                                    What I would do is repeat the same route several times and see if the ascent is consistent among activities. If they are, i would tend to believe that the sensor is OK. Then I would do a soft reset, if nothing improves or you already have done it, I would reflash the firmware, maybe something is corrupt.
                                    Anssi AuvinenA 1 Reply Last reply Reply Quote 0
                                      Anssi Auvinen @cosme.costa
                                      @cosmecosta Yes, I will contact support again. I don’t know have you read the whore thread, but seems that may barometer is not sensitive as it used to be. It used to give more meter but now it cannot react as fast as it used to do.
                                      cosme.costaC 1 Reply Last reply Reply Quote 0
                                        @Anssi-Auvinen said in S9 barometer problems:
                                        Yes I read all the thread. But, did you try the hard reset, reflashing the firmware? Maybe you save some days without the watch.
                                          @cosmecosta Yes, I have done the hard reset last week.
                                          • fazelF Offline
                                            fazel Bronze Member @Anssi Auvinen
                                            @Anssi-Auvinen My ride yesterday.
                                            Plotaroute: 4199 ft
                                            Garmin 830: 4075 ft
                                            Suunto 9 Baro (mounted on handlebars): 2993 ft
                                            I’ve let it sit in warm water twice in the last couple of months. I’ve had issues on the bike since I got the watch. I assumed it had to do with me wearing it on my right hand in previous rides as the barometer opening would face into the wind, potentially affecting the measurements. I also assumed it was fixed. I haven’t rode with the watch in a long time but yesterday’s ride seems to suggest it’s still an issue - even with the watch mounted perpendicular to the bike’s movement. I shared this data with Suunto back in 2018 but never heard back.
                                            https://docs.google.com/spreadsheets/d/1llLMEgMqTu6i0fUzrCg5AOTV45ZKkcDlKtj-24kGihI/edit?usp=sharing
                                            freeheelerF Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
