    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7: Suunto App audio control widget
    Scheduled Pinned Locked Moved Suunto 7
    7 Posts 4 Posters 557 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • masi0M Offline
      masi0
      Can you add data widget to as activity window to control audio from phone?
      Jamie BGJ 1 Reply Last reply Reply Quote 0
      • Saketo NemoS Offline
        Saketo Nemo Moderator
        In Suunto application (I mean app wear os Suunto) no. If the phone is BT connected to the watch, when you start the music, if that’s what you mean, you can check it by pressing the back button from the activity and entering the menu with a swipe down.
        • Jamie BGJ Offline
          Jamie BG Bronze Member @masi0
          @masi0 -under settings, in the general category , there is the option to auto-launch media controls. This way whenever you are remote controlling media it should bring the media controls up (saves having to go into quick settings and launch from there).
          • masi0M Offline
            masi0
            I know there is this option already availabe but require to go back to the menu, do the swipe etc. - wouldn’t that be simpler just simply swipe or press middle button for proper data field? so much less hassle especially while you are running 🙂
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @masi0
              @masi0 you can configure your middle button to do exactly that.
              Blog: isazi's home
              masi0M 1 Reply Last reply Reply Quote 0
              • masi0M Offline
                masi0 @isazi
                @isazi also during sports? thought mid button switches between data fields?
                • isaziI Offline
                  @masi0 if you are within an app, the buttons do whatever the app tells them to do. In normal watch mode, you can configure what buttons do.
                  Edit: I now understand that you want a music field during activity, I did not understand that previously.
                  Blog: isazi's home
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
