    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - PXDZ.200824.005 (H MR2) Bug Issues
    Scheduled Pinned Locked Moved Suunto 7
    17 Posts 5 Posters 1.6k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Jamie BGJ Offline
      Jamie BG Bronze Member
      Anyone finding any bugs.
      I have found the following AOD/Tilt to wake/Cinema mode bugs;
      set AOD to off, tilt to wake off, 24/7HR off/ touch to wake on. Ran that for 16 hours and then put watch on DND and cinema mode, while on charge (so not distrubed and so no light from ambient screen).
      This morning decided to go with AOD on and found the following issues:
      1. Screen wouldn’t stay on. Checked the cinema mode on the quick settings and it was off. Tried chaning watch faces, Tried switching AOD on and off. Eventually I tried the cinema mode setting, turned it on and off in quick settings and that triggered something so that the AOD switch now works. So not quite sure whether its AOD or Cinema mode - but seems it can glitch.
      2. Discovered that tilt to wake had somehow switched itself on - never use it I have too much wrist movement (drinking water etc) - so prefer touch to wake. When I switched it off it went off. So not a major bug but definitely annoying. Not sure when it switched itself on,but suspect it occurred with first issue.
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
      • Dimitrios KanellopoulosD Online
        Dimitrios Kanellopoulos Community Manager @Jamie BG
        @Jamie-BG I think at @Egika knows one of the issues. I am not quite sure about 1 but about 2 this can be cause by the Suunto app (wear app)
        Creator of Quantified-Self.io
        youtube.com/c/dimitrioskanellopoulos
        https://instagram.com/dimitrioskanellopoulos
        https://www.strava.com/athletes/7586105
        Jamie BGJ 1 Reply Last reply Reply Quote 0
        • Jamie BGJ Offline
          Jamie BG Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos OK - point 2 might make sense as while still connected to wear os app, it somehow disconnected from suunto app and wouldn’t reconnect. Had to reconnect to wear os and suunto app to get it to sync my tracked activity. Also noticed there was a quite a bit of lag before it updated yesterdays steps - seem to have lost connection sometime yesterday.
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            @Jamie-BG The thing (bug) is:
            Suunto app reads the tilt to wake setting and stores it once at boot time
            You use the app and then you finish using it , and restores it.
            So if you have changed the setting after the boot time it will restore back a wrong value if you use the suunto app (watch app I am refering always).
            To solve this:
            • When you change the tilt to wake setting reboot the watch. Then the Suunto app on the watch will bring back the correct setting after using it
            EgikaE 1 Reply Last reply Reply Quote 2
            • EgikaE Offline
              Egika Platinum Member @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos yup! Good description.
              There seems to be another change in wear OS:
              Befor the update the cinema mode would be re-set to off when pressing a button and thus ending it.
              With the update the cinema mode is kept enabled even if the watch is woken up with a button press. It will go back to cinema until it is actively toggled to off.
              t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
              Jamie BGJ 1 Reply Last reply Reply Quote 1
              • E Offline
                Emma buik
                please fix this problem suunto use to open i
                • Jamie BGJ Offline
                  Jamie BG Bronze Member @Egika
                  @Egika - and its a problem as the quick setting icon doesn’t stay lit up so you don’t know that you are in cinema mode.
                  • EgikaE Offline
                    Egika Platinum Member @Jamie BG
                    @Jamie-BG said in Suunto 7 - PXDZ.200824.005 (H MR2) Bug Issues:
                    er - no. for the the cinema mode icon stays blue (active).
                    • Jamie BGJ Offline
                      @Egika - restart for connectivity issues may have fixed that, but when I had my issue it didn’t which is why I had some many problems trying to work out why my screen wasn’t AOD.
                      • C Offline
                        cjp131
                        My wife and I are both wearing Suunto 7s and updated our watches last week. We both also use Android devices and use the Messages app for texts. Since the update, our Messages app isn’t syncing/updating with our phones. (Both of our watches are experiencing this issue independently.)
                        Now, text messages are still appearing as notifications in the watch, but when you click “open” on Messages or open the Messages app, it doesn’t update (currently shows texts from the day we updated our watches to the lastest software).
                        I’ve tried uninstalling/reinstalling Messages, rebooting the watch, etc. No luck yet.
                        Dimitrios KanellopoulosD Jamie BGJ 3 Replies Last reply Reply Quote 0
                          Dimitrios Kanellopoulos Community Manager @cjp131
                          @cjp131 I got more reports of this
                            @cjp131 please also ping Google , aka on their messages app support
                            C 1 Reply Last reply Reply Quote 0
                            • Jamie BGJ Offline
                              Jamie BG Bronze Member @cjp131
                              @cjp131 - which android phones are you using and are you sure that you are using the android messaging app and not the manufacture’s messaging app?
                              • C Offline
                                cjp131 @Dimitrios Kanellopoulos
                                @Dimitrios-Kanellopoulos Will do! Let me know if you hear anything on this as as a fix, and I’ll be sure to report back if I get anywhere with this issue as well 🙂
                                • C Offline
                                  cjp131 @Jamie BG
                                  @Jamie-BG we’re on Pixel 3 devices, running Android 11. We’re using Google’s “Messages” app, which was running and syncing properly before the latest Wear OS update on Suunto 7.
                                    @cjp131 I have forwarded this already
                                    • Jamie BGJ Offline
                                      @cjp131 sorry to hear that, especially as I don’t have this issue. Apologies re lateness of reply - wasn’t sure my last text message was correct or not, so had to get someone to send me one. It all synced up fine.
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
