    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Replace Bearing Navigation Instructions With Degrees
    feature suggestionnavigationuser interface
    3 Posts 3 Posters 1.1k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Fenr1rF Offline
      Fenr1r
      Suggestion
      1. Replace the instructions with the numeric bearing in ~twice its current font size.
      2. Possibly replace the (bottom) current cardinal+bearing with simple cardinal (or tap-to-change field … or leave blank).
      3. Revise the relevant manual section.
      S9 BN 3.png The wrong font (Arial) … but bigger - you get the idea.
      Rationale
      The instructions take up primary visual real estate on a key functional screen (not inactive, like the sleep tracking activation info on the Spartan). Once the functionality is understood*, the instructions are redundant every time they recur. And they recur (and persist) every time.
      img_1223-scaled-1F.jpg @Egika
      The arrow is great when you can see your target, the numbers are better when you can’t or when you are just checking the compass while recording an activity. Centered and Big is clearer, both at-a-glance while moving, and in detail for those with older eyes.
      Plus, and I may be biased by being used to Suunto’s Sp/Sx interface AND general bearing lock function but …
      *The instructions seem unnecessary as the only things one could do with that display are Lock a bearing or go Back. And the middle button (with adjacent arrow or caret [possibly flashing]) is the default for Actions elsewhere in the UI. Upper & Lower soft buttons for menu movement where available (and distinguished by carets) or inoperable (user can’t do any damage). Folk using the watch would almost certainly know this already, having reached that screen.
      Possible hybrid alternative
      Have the instructions appear once on 1st use and then fade out to be replaced by big bearing. Or recur and fade out every time. But do any Suunto watch function displays have fade/replace? Not worth developing for this.
      Splendid job on introducing this feature, Suunto, by the way.
      Thanks to @Efejota for the font idea and @Egika for checking current function.
      Mister PYCM 1 Reply Last reply Reply Quote 11
      • EfejotaE Offline
        Efejota Bronze Member
        Brilliant!
        • Mister PYCM Offline
          Mister PYC Silver Members @Fenr1r
          @fenr1r
          Very very correct.
          Instructions are only necessary the very first time and them when we master the feature they are totally useless and forbid to have better information like you proposed.;
          May be just a suggestion here … in case of bearing nevigation setup, undertline
          The advantage is that you will visually very easily see the difference between when you are in the process to setup the bearing direction versus when you are just looking to the COMPASS
          All is possible in IT
          Driven by you fear you stay on the ground, driven by your dreams you fly
          • First post
            Last post
          Suunto Terms | Privacy Policy
