    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problems with Altimeter
    4 Posts 4 Posters 1.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      SeifertM
      Hi Community!
      I have Little Problems with my height measurement. Yesterday i was on the Top of a Mountain at 1569m. My Suunto 9 works Perfect.
      Only at Home the measurement is wrong by 20-30 Meters. I habe entered the height of my village manually. I know That the GPS in my house is Not the Best but it work until 4 days Ago.
      I also restarted the watch.
      Has anyone a thanks!
      Brad_OlwinB 1 Reply Last reply Reply Quote 1
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @SeifertM
        @SeifertM Changes in barometric pressure will affect altitude in watch mode. You can go to the Altitude screen and long press the middle button, Select AutoAdust and the altitude will be corrected. You need to be outside so a GPS fix can be obtained.
        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
        • JorckiJ Offline
          Jorcki
          My Suunto 9 Baro just got replaced because a problem showing totally wrong altitudes during activities (-40m even though the real altitude was about 5m) but also wrong altitudes in the home screen mode. Usually after setting the reference altitude manually, the altitude immediately started rising or lowering by itself.
          According to Suunto service the problem was somekind of a leak etc. that had damaged the watch.
          Stefan KerstingS 1 Reply Last reply Reply Quote 0
          • Stefan KerstingS Offline
            Stefan Kersting Platinum Member @Jorcki
            @Jorcki what kind of leak?
            Instagram: https://www.instagram.com/helgelandsbukken/
            https://www.instagram.com/suunto_adventures/
            IG: Helgelandsbukken, suunto_adventures
            Vimeo: vimeo.com/helgelandsbukken
            Blogg: https://turblogg.midnattsola.com
            • First post
              Last post
            Suunto Terms | Privacy Policy
