    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    I'm impressed with the AoD battery life. 2 days with 18% left. Anyone else?
    Scheduled Pinned Locked Moved Suunto 7
    11 Posts 6 Posters 1.7k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      marsfarce
      I’ve got tilt to wake, power saver tilt, touch to wake disabled (so basically I’ve got the power saver watch face always on, and if I want to wake the screen I have to press a button)
      AoD enabled and I’ve finished 2 days with 18% left. Mind you I didn’t track any actual activities during those 2 days, but still!
      Anyone else?
      1 Reply Last reply Reply Quote 4
      • isaziI Offline
        isazi Moderator
        Just changed the settings to mirror yours, I’ll now recharge my watch and see what I get.
        Blog: isazi's home
        • Jamie BGJ Offline
          Jamie BG Bronze Member
          About what I am finding with my battery analytics; as I generally find that using the AOD, with an ambient screen usually uses around 2% battery per hour. Based on that its 2 days with approx 4% left. However that can be longer or shorter depending on how often/many notifications you get etc and how often you check the watch.
          If AOD is off I tend to find battery consumption is around 1% per hour which suggests you may be able to get just over 3 days (I doubt 4 is acheivable due to checking notifications etc).
          This of course assumes connected to a phone via bluetooth (and assumes play store is not auto update - and assumes that at no point an app decides to check for updates/etc on its own - i.e. weather apps etc and asummes you aren’t tracking HR 24/7).
          Jamie BGJ 1 Reply Last reply Reply Quote 2
          • Jamie BGJ Offline
            Jamie BG Bronze Member @Jamie BG
            Running watch connected to phone, display off, did one hour of activity tracking yesterday (approx 13%), had loads on notifications today and yesterday. Took watch off charger at 8am, is now 5:30pm following day and I still have 44%, 33.5 hours later. 1.3% battery use per hour (24HR off) and should easily make it to tomorrow morning even with another hour of activity tracking.
            • iTomBI Offline
              iTomB
              Same settings here ( press button to activate watchface).
              1 hour 45 min of cycling.
              Heart trace app activ.
              Watch lasted for 2 days and now 4 hours left.
              Very pleased with that
              55D75EE6-A871-4B44-AA84-7BCA2BBDA162.png 8AABCBF2-E224-4BE3-8126-C155ABCDA0CD.png
              Handbiker
              Spinal cord injury T7 - 16.09.2019
              • isaziI Offline
                isazi Moderator
                I easily did two days (without activities), and still had battery left.
                Blog: isazi's home
                Jamie BGJ 1 Reply Last reply Reply Quote 0
                • Jamie BGJ Offline
                  Jamie BG Bronze Member @isazi
                  yesterday I did a 3 hour padding session on a SUP, and then in the afternoon I did about an hour of hiking. Watch easily made it through all of this and through to the next morning where I still had around 15% of battery left (and that includes me forgetting to switch off the screen while paddling - unfortunately the tilt to wake screen off switch in the Suunto app settings doesn’t work - and when you paddle if activates the screen on vritually every stroke - forgot about that for the first half hour so battery usage probably should have been less).
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                  • Dimitrios KanellopoulosD Online
                    Dimitrios Kanellopoulos Community Manager @Jamie BG
                    @Jamie-BG that should be fixed with the AOD
                    Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                    Jamie BGJ 1 Reply Last reply Reply Quote 1
                    • Jamie BGJ Offline
                      Jamie BG Bronze Member @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos - yes that is certainly one solution
                      • Kai LiuK Offline
                        Kai Liu Bronze Member
                        Is the AoD = “Always on Screen” display setting in the watch display section? I am guessing by AoD you means “Always on Display” but I am confused because the watch says “Always on Screen”
                        S7, S9P, Vertical Solar / boxing, skiing, hiking, running
                          Dimitrios Kanellopoulos Community Manager @Kai Liu
                          @Kai-Liu AOD = AOS
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
