    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Spartan Sport Wrist HR Baro ( Difference between ascent and descent)
    Scheduled Pinned Locked Moved Spartan
    7 Posts 2 Posters 868 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Iván Martín MoraI Offline
      Iván Martín Mora
      Good Morning. I don’t know if this question has already been asked. I’ve been looking but can’t find anything like it. I have this Spartan Baro and I would like to know if it happens to you that when I do an activity the difference between ascent and descent is almost always approximately 10 meters. I update the GPS and put the correct reference altitude according to google and others. Thank you very much to all.
      • Saketo NemoS Offline
        Saketo Nemo Moderator
        it is possible that it is due to barometric changes. Are the ascents and descents done on the same route?
          Iván Martín Mora
          @Saketo-Nemo said in Suunto Spartan Sport Wrist HR Baro ( Difference between ascent and descent):
          Los ascensos
          Yes effectively. I am doing that test, I always do the same route. The minimum altitude 880 meters and maximum 1053 meters
            10m d+ of difference are not many but not very few either.
            can you share some links activity?
              Iván Martín Mora
              These are just a few. In others they are 6 meters apart, but mostly between 10-12 meters
              https://www.suunto.com/move/ivanmartin80/5f45647c66b918646c70e863
              https://www.suunto.com/move/ivanmartin80/5f4232d8d3006b0bbedfd96f
              https://www.suunto.com/move/ivanmartin80/5f121b16fa5d0179e0223658
              Thank you
                Ah OK. It is quite normal. I understood it was going back and forth exactly on the same route. This makes the difference because the D+/- is counted every consecutive 3m and on a ring route like yours, rather hilly, these differences are expected.
                The 3 laps are identical and should bring the same difference in height, but here comes the speech of the barometric pressure variation that I was doing above.
                In addition, AFAIK, in the most recent watches FusedAlti starts working several times, during the activity, this helps the comparison between pressure and altitude.
                On Spartans, it should only start working at the beginning of the activity, it seems to me within the first 15’ if you have a good GPS signal (and normally you have it on a bike).
                So I repeat, it seems normal behavior to me 😉
                Iván Martín MoraI 1 Reply Last reply Reply Quote 1
                  Iván Martín Mora @Saketo Nemo
                  s diferencias.
                  Okay, so it’s normal. Thank you all very much
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
