    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Adding Waypoints not working
    14 Posts 6 Posters 1.0k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • AudaxjoeA Offline
      Audaxjoe
      Sorry if this has been covered, I couldn’t find specific advice by searching.
      I am trying to add waypoints to a route on SA.
      I have added them on an external editor, they are then stripped on import.
      I have then added them manually in SA, they are showing on the app but not being transferred to the watch.
      I have cleared the catch
      I have uninstalled and re-installed SA
      I have deleted the route from the watch and then re-installed.
      Am I missing something? I am running Android, latest SA and Beta tester.
      Suunto Vertical
      Suunto 9 BARO
      Garmin Fenix 3, 5
      Suunto Vector
      • isaziI Offline
        isazi Moderator
        Importing a GPX with waypoints has been discussed recently, I will link the post when I find it.
        As for adding waypoints in SA, that should also work. Did you transfer the new route with waypoints to your watch, or updated a route that was already on the watch?
        Blog: isazi's home
        • isaziI Offline
          isazi Moderator
          https://forum.suunto.com/topic/4682/import-gpx-to-sa-with-waypoints
          Blog: isazi's home
          • AudaxjoeA Offline
            Audaxjoe
            Hi Isazi
            I did both, imported with way points, not showing, then added waypoints, which are showing in SA but not on watch. I’ll check the other thread.
            I also did a quick route in SA and added way-points (i.e. plotted in SA) and still no waypoints added.
            Suunto Vertical
            Suunto 9 BARO
            Garmin Fenix 3, 5
            Suunto Vector
            inkognitoI 1 Reply Last reply Reply Quote 0
            • inkognitoI Offline
              inkognito Platinum Member @Audaxjoe
              @Audaxjoe Did you use any other waypoint type than “Waypoint”? I have encountered missing waypoints when setting “Building”/“Lake” etc… Using only the “Waypoint” type usually does the trick for me…
              SV: fingers crossed :D
              S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
              Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
              Despite some pretty bad luck, I still love Suunto!
              • AudaxjoeA Offline
                Audaxjoe
                No I just used the default way point in SA. Nothing fancy. I did re name the Way point that was all.
                I have checked the other thread but this does not seem to help as I appear to be following the correct procedure. I have also restarted the watch and reinstalled SA.
                Suunto Vertical
                Suunto 9 BARO
                Garmin Fenix 3, 5
                Suunto Vector
                Mff73M 1 Reply Last reply Reply Quote 0
                • Mff73M Online
                  Mff73 @Audaxjoe
                  @Audaxjoe
                  And the routes your are created are correct? The preview track on the watch is the same as on the map?
                  Maybe you are facing the route cache bug, and all you see is always the same route (thus, without WP).
                  I can’t find again the thread for this bug, sorry, someone may find it 😉
                  Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
                  Suunto Vertical all black
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android 13, Galaxy S205G
                  • AudaxjoeA Offline
                    Audaxjoe
                    I have tried clearing the catch and uninstalling. Also I have imported a route and plotted another in SA. All show waypoints in SA but not on watch.
                    Suunto Vertical
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                      Dimitrios Kanellopoulos Community Manager @Audaxjoe
                      @Audaxjoe can you share the file ?
                      And what do you mean not shown on the watch ?
                      Creator of Quantified-Self.io
                      youtube.com/c/dimitrioskanellopoulos
                      https://instagram.com/dimitrioskanellopoulos
                      https://www.strava.com/athletes/7586105
                      • sartoricS Offline
                        sartoric Moderator
                        Remember that there is still the “route update” bug
                        SVTS - 2.48.16
                        SSSWHR BARO Amber - 2.8.32
                        Samsung A5 2016 - Android 7.0
                        Samsung A33 2022 - Android 15 - One UI 7.0
                        Suunto App Android 6.4.7 beta
                        Suunto App IOs 3.6.0 (20927) beta on MBP M1 Max
                        • AudaxjoeA Offline
                          Audaxjoe
                          Sorry for delay in replying @Dimitrios-Kanellopoulos I was on holiday and forgot all about the issue.
                          It turns out it was user error. On adding a WayPoint on the track in SA, I expected it to show as a navigation option. So when waypoints showed zero I presumed they were not on the track or device.
                          I now realise they do not show as separate items, they are part of the track navigation. It is working very well now. And an excellent and much needed addition.
                          Suunto Vertical
                          Suunto 9 BARO
                          Garmin Fenix 3, 5
                          Suunto Vector
                          sartoricS 1 Reply Last reply Reply Quote 3
                          • sartoricS Offline
                            sartoric Moderator @Audaxjoe
                            @Audaxjoe said in Adding Waypoints not working:
                            POI not waypoints 😉
                            SVTS - 2.48.16
                            • AudaxjoeA Offline
                              Audaxjoe
                              I think many would disagree… Google is your friend.
                              Suunto Vertical
                              Suunto 9 BARO
                              Garmin Fenix 3, 5
                              Suunto Vector
                              sartoricS 1 Reply Last reply Reply Quote 0
                              • sartoricS Offline
                                @Audaxjoe
                                is it for me ?
                                Anyway … you said that the waypoint count was 0 … but the count you see in the navigation screen is for POI not for Waypoints (that’s basically what generated confusion)
                                so I just pointed out the typo with a smiley face
                                SVTS - 2.48.16
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
