    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto9 Baro Elevation Issues
    13 Posts 9 Posters 1.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • O Offline
      Oisinb
      Hi,I received a Suunto 9 Baro back on December 20th and on most of my runs the elevation profile continually fluctuated by around 1-10m despite the fact that I was running on a consistent gradient. This led to my elevation gain on the run being significantly higher than basemap values and other watches would suggest. In one case a run with 200m of elevation gain was recorded as 840m by my watch. Assuming this to be an issue with my specific watch I contacted suunto customer support who determined that it was most likely a hardware issue. I sent the watch to the Suunto Repair Centre, who then sent me a new watch which I received on May 7th. On my very first run the exact same thing happened with the fluctuating elevation profile. Upon reading some forums I found that someone was having a similar issue and like me they also wore their watch on their right hand. To see if this was the issue I started to wear my watch on my left hand instead and no longer had any issues with elevation. I believe that the cause of the issue may be that the holes leading to the air pressure sensor face towards the direction of airflow when wearing it on your right hand which may cause issues for the sensor. Here is the data for 6 runs (3 on left hand and 3 on right). I ran the same route every time but on the right hand significantly different elevation gains were recorded. I was wondering if anyone else has had this issue? Suunto 9 Baro issue.png
      N Mff73M EgikaE 4 Replies Last reply Reply Quote 0
      • N Offline
        nseslija Bronze Member @Oisinb
        @Oisinb I started to wear my S9B on the right hand couple a months ago and didn’t notice any ascent and descent difference compared to when I wore it on my left hand.
        Ambit 2S
        Ambit 3 Peak
        Suunto 9 baro
        Suunto Vertical Ti Solar
        • N Offline
          @Oisinb @Oisinb but I do not run, and during my hikes the speed, which is low, doesn’t cause an issue.
          Ambit 2S
          Ambit 3 Peak
          Suunto 9 baro
          • Mff73M Offline
            Mff73 @Oisinb
            @Oisinb
            Either the wind, or your hand is blocking the holes while moving your wrist.
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            A 1 Reply Last reply Reply Quote 2
            • A Offline
              AndyD2574 @Mff73
              I’ve just come in from a run…exactly same as yesterday…Baro 9 recorded exactly same distance BUT a 25 metre discrepancy between the 2 runs over 4 mile??
              I’m having major doubts about this watch as never had a single issue with my Fenix 5x
              I really want to work with this watch but I’m quickly losing faith after 1 week??
              sartoricS EgikaE 2 Replies Last reply Reply Quote 0
              • sartoricS Offline
                sartoric Moderator @AndyD2574
                @AndyD2574 said in Suunto9 Baro Elevation Issues:
                If you think this can only get worse, I would return it.
                SVTS - 2.50.28
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Suunto App Android 6.11.12 beta
                • EgikaE Offline
                  Egika Platinum Member @Oisinb
                  @Oisinb I once had a hike up a hill in very high wind that almost blew me off of the mountain.
                  Elevation data for this activity was bad as well - while usually there are absolutely no issues at all with the S9B.
                  Others are right - the barometer holes are facing forward when the watch is worn on the right hand.
                  It then depends on clothing and running style if there is an impact in the altitude measurement.
                  freeheelerF 1 Reply Last reply Reply Quote 1
                  • EgikaE Offline
                    Egika Platinum Member @AndyD2574
                    25m in distance or altitude?
                    If distance: this is a very good accuracy over 4miles, but off topic in this thread
                    If altitude: what is the absolute altitude gain/loss during those 4 miles?
                    A 1 Reply Last reply Reply Quote 0
                    • A Offline
                      AndyD2574 @Egika
                      @Egika sorry it was an altitude difference of 25 metres over the 4 miles
                      • freeheelerF Offline
                        freeheeler @Egika
                        @Egika
                        my favourite topic 😉
                        blocked holes is the reason in most cases IMHO…
                        strong winds could also be a reason as wind equalizes pressure differences and hence the baro gets “tricked”. but should be compensate with fusedalti…?!
                        living sideways
                        • EgikaE Offline
                          Egika Platinum Member @freeheeler
                          @TELE-HO yeah - it’s not compensated. Fused Alti is relevant for the low pass filter offset over all - while the baro sensor is responsible for the quick changes (and thus influenced by heavy wind and other stuff like getting some air pump effect from moving clothes worn over the watch )
                          • CookiemonsterC Offline
                            Cookiemonster
                            I have a very similar issue. I have just purchased a 9 Baro and went for a 54 I’m ride which was a flat route around the Bay and along the beaches of Singapore. The GPS tracked the route perfectly but the altitude measuring recorded 6.3km of ascent! I think the highest point of the route would have been about 15m near home away from the coast. The plot shows wild variations with a Low point of -116m as per the attached plot. I never had such issues with my Ambit3P and this should be a superior product. Any suggestions, or is this one to take to Suunto support? EA8A3A23-FE1F-4D7E-8CA9-0506F06F7A79.jpeg
                            Dragon Boat Paddler, leisure/fitness Cyclist & Scuba Diver
                            Suunto 9 Baro
                            Ambit 3 Peak (retired)
                            Eon Steel + Tank pod Awesome primary dive computer
                            Zoop - great back-up dive computer
                            isaziI 1 Reply Last reply Reply Quote 0
                            • isaziI Online
                              isazi Moderator @Cookiemonster
                              @Cookiemonster It only happened once to me (well, except kayaking, that’s a different topic though) wearing the watch inside the jacket during a very strong storm, with very strong winds. I guess you didn’t wear long sleeves in Singapore right? I never did 🙂
                              Maybe your arms were bent enough to create some kind of vacuum around the baro sensor?
                              Blog: isazi's home
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
