    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 update 30-06-2020
    Scheduled Pinned Locked Moved Suunto 7
    104 Posts 32 Posters 19.8k Views 33 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      jw cou Silver Members @aeroild
      I had a wild reboot of the watch during a long trail today - I remember someone else mentioning this too. Not super annoying - the watch saves the activity before rebooting, but you still end up with 2 separated run, and the one saved just before reboot is missing data (like ascent), even if it’s all fine in QS.
      @Dimitrios-Kanellopoulos is it worth me sharing the link of the two activities? Or it’s useless because that could be caused by so many things…?
      • marty313M Offline
        marty313 @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos Wrist activation while tracking paddling is a major issue. No matter how well charged my Suunto 7 is as the beginning of a say kayaking trip, it goes into essential mode after some 2 1/4 hours. This should ideally be baked into kayaking mode. The altimeter is pretty useless when sea-kayaking and can safely be switched off.
        EgikaE Jamie BGJ 2 Replies Last reply Reply Quote 1
        • EgikaE Offline
          Egika Platinum Member @marty313
          @marty313 yeah.
          I mentioned this before, the only chance to survive is the following procedure :
          Start activity
          Switch to main screen
          Enable cinema mode
          Screen will stay off and you need a button press to check stars…
          pilleusP 1 Reply Last reply Reply Quote 1
          • pilleusP Offline
            pilleus @Egika
            @Egika said in Suunto 7 update 30-06-2020:
            the only chance
            is to use another watch. 👍
            I want to see speed, distance and heart rate while paddling and not to stop paddling and press a button to get the information.
            It was the main reason for me to give away the S7.
            https://www.instagram.com/moves.are.life/
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
            Suunto Spartan Ultra Stealth Titanium
              Dimitrios Kanellopoulos Community Manager
              There will be a fix for this
              pilleusP 1 Reply Last reply Reply Quote 3
              • pilleusP Offline
                pilleus @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos said in Suunto 7 update 30-06-2020:
                For kayaking there should be the option to choose the displayed fields on the screen, because there is only half a second time to have a look at the screen during the movement of the arm.
                Speed, stroke rate, heart rate and distance are needed information for me.
                And shown permanently using the co-processor of the 3100 chip.
                Dimitrios KanellopoulosD Jamie BGJ 3 Replies Last reply Reply Quote 0
                  Dimitrios Kanellopoulos Community Manager @pilleus
                  @pilleus we are developing a better solution
                  pilleusP 1 Reply Last reply Reply Quote 5
                    @pilleus actually is already developed
                    1 Reply Last reply Reply Quote 4
                    • pilleusP Offline
                      The best solution has the Ticwatch Pro 2020. Every kilometre there is an audio output with distance, speed, heart rate and cardio zone. No need to use the display or have a look on the screen during paddling.
                      I know that it is not possible with the S7 due to the missing speaker.
                      Just a view to other watches. 😊
                      • suzzloS Online
                        suzzlo Moderator
                        No speaker… but you can use Bluetooth headphones, right?
                        BR
                        Suunto: Race, S9Peak, Spartan Sport Wrist
                        Garmin: FR745, Edge 530
                        SA topics:
                        • Guides - https://forum.suunto.com/tags/guides
                        • EgikaE Offline
                          Egika Platinum Member @pilleus
                          @pilleus for me whitewater kayaking I don’t need the stats on the way. And won’t hear any audio information either. It’s just about tracking the path and marking certain sections with a lap point (waypoint would be better).
                          • Kai LiuK Offline
                            Kai Liu Bronze Member
                            Is battery better or worse … thinking should I install or not
                            S7, S9P, Vertical Solar / boxing, skiing, hiking, running
                            isaziI ? 2 Replies Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @Kai Liu
                              @Kai-Liu my battery life is the same as before: two days without activities, less with.
                              Blog: isazi's home
                              • ? Offline
                                A Former User @Kai Liu
                                @Kai-Liu said in Suunto 7 update 30-06-2020:
                                it’s definitely not worse for me
                                • Jamie BGJ Offline
                                  Jamie BG Bronze Member @marty313
                                  @marty313 :
                                  Do what I do - start the activity, then lock the app (always do that due to another watch that regularly paused itself when my wrist pressed the button), then click top left for menu, then pull down the notification shade and press the watch screen off (also known as cinema mode - picture of a watch). This switchs off the screen.
                                  Easy to see activity screen when you want by pressing the suunto app button.
                                  • Jamie BGJ Offline
                                    Jamie BG Bronze Member @pilleus
                                    @pilleus :
                                    Use a custom profile - have done that for my SUP activity as the standard is very basic
                                    You will not be able to get stroke rate, as i don’t think that is an option yet (didn’t come up as one for Paddleboarding), but you can definitely get the others laid out how you want.
                                    Then easy to choose as will come up as one of your regulars.
                                    • hqvkamilH Offline
                                      hqvkamil
                                      Any feedback about last update?
                                      Sunnto 7 Graphite Copper
                                      isaziI 1 Reply Last reply Reply Quote 0
                                      • isaziI Offline
                                        isazi Moderator @hqvkamil
                                        @hqvkamil there’s a whole thread about it 🙂
                                        Blog: isazi's home
                                          This post is deleted!
                                          • W Offline
                                            who93
                                            Thanks for the update, it is good to see that the watch constantly is improving!
                                            However, there is a big problem with the altitude accuracy with the new update. When running in the city, the watch is 10-20m off the actual altitude - I guess that is ok.
                                            But with the last hike, the watch was 150m below the actual altitude. The mountain peak is at 1430m, before the update the watch also showed 1430m. With the new update, I am at 1288m.
                                            Below two pictures, one before the update one with the new update. Same Start - Peak - End points, but with a slightly different route.
                                            If it matters, I changed the GPS accuracy to 10s, but this shouldn’t be the reason for 150m wrong altitude.
                                            isaziI 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
