    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 update 30-06-2020
    Scheduled Pinned Locked Moved Suunto 7
    104 Posts 32 Posters 21.5k Views 33 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager
      Regarding calories and steps.
      Google fit aggregates steps and calories from the phone as well if you use it.
      So leaving the watch at home , walking with the phone, and syncing will give you steps from phone etc.
      Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
      • ? Offline
        A Former User @Brad_Olwin
        @Brad_Olwin I am. It started working fine few hours later - maybe after I was changing watch face (turning power saver tilt off and back on didn’t help).
        • suzzloS Offline
          suzzlo Moderator
          Due Suunto 7 is a WearOS watch, I see that Suunto is extending the integration with Google Fit. 🙂
          It would be great if we see improvements in that direction for the rest of watches.
          BR
          Suunto: Race, S9Peak, Spartan Sport Wrist
          Garmin: FR745, Edge 530
          SA topics:
          • Guides - https://forum.suunto.com/tags/guides
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Dominik Moser
            @Dominik-Moser I have been checking my steps for the last few days. Google Fit and Suunto while not exact are very, very close to each other. This includes my running so they are off by at most 1-2%.
            Vector/T6c/Vertical 2 Ti
            Dominik MoserD 1 Reply Last reply Reply Quote 1
            • Dominik MoserD Offline
              Dominik Moser @Brad_Olwin
              @Brad_Olwin Right now Fit counts 4840 steps, Suunto 5250. A bit more than 1-2% 😉
              aeroildA 1 Reply Last reply Reply Quote 1
              • aeroildA Offline
                aeroild Bronze Member @Dominik Moser
                @Dominik-Moser My watch now after counting steps for approx. 22 hours since midnight: Suunto 5394 and Fit 5448. That would make a difference of 54 and that is 1% 😉
                • JANTIKAINENJ Offline
                  JANTIKAINEN Bronze Member
                  The new tile with steps, calories and recovery is great!
                  Samsung Galaxy S24
                  Suunto Race Titanium
                  1 Reply Last reply Reply Quote 5
                  • C Offline
                    chriss860
                    Could you show us the new tile? I was waiting for the fitness integration with Suunto‘s own software, so now I‘m courious about news.😊
                      Brad_Olwin Moderator @chriss860
                      And my steps are very close…
                      • Jamie BGJ Offline
                        Jamie BG Bronze Member
                        I think what you are seeing is a temporary delay - mine normally match, especially if you go into the Suunto Today tile first, and then pull up google fit. Steps always match- calories are slightly out, but not by much.
                        • E Offline
                          Erjo_
                          Can someone explain what the calories numbers refer to in the new tile?
                          When I tap the calories it goes from goal to total. Whats the difference between the number shown in big numbers and the total beneath?
                          • EgikaE Offline
                            Egika Platinum Member @Erjo_
                            @Erjo_ said in Suunto 7 update 30-06-2020:
                            RTFM: https://www.suunto.com/Support/Product-support/suunto_7/suunto_7/wear-os-by-google/view-and-manage-your-tiles/#7.3
                            • Jamie BGJ Offline
                              Location accuracy is definitely good, as most recent trip absolutely picked up river/canal track even though some where narrow, and loads were covered in trees, making it tricky for most watches to get good fixs.
                              Battery Life - definitely seems good as seems likely that GPS only use is fairly accurate - based on SUP activity profile (if switching display to off - more on that later). Dropped 20% battery life on a 2hr15 min paddle; and that is after noticing the display was waking up regularly due to wrist motion, but once turned display off that wasn’t an issue any more. Worked well using buttons to wake and open Suunto app, then menu button to bring back to home screen and top shade down to use switch off display option. Not ideal but a work around. Also did use a fair amount of screen time for navigation purposes, using the offline maps.
                              Major Issue - wrist activation motion - need a setting for to be able to turn that off for the Suunto app (have it turned off in wear os settings but doesn’t seem to apply to Suunto app when tracking activity). - This needs to be fixed ASAP. Alternatively acitivities with extensive wrist action need it to be shut off. Personally think the Suunto app should have this as an option. Would make the most sense, or to use the Wear OS settings as guidance.
                              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 3
                                Dimitrios Kanellopoulos Community Manager @Jamie BG
                                @Jamie-BG said in Suunto 7 update 30-06-2020:
                                we hear you very well here
                                marty313M 1 Reply Last reply Reply Quote 3
                                • boza72B Offline
                                  boza72 @jw cou
                                  @jw-cou it would make the S7 an amazing watch. Importing routes and to rename any POI anything you want (or more options). I would like to add more pages for an activity as well I’d like to have two graphs active for any selected activity. I love the S7 plus battery life is ok. Don’t know what everyone goes on about…
                                  Fingers crossed…but know it probably won’t happen.
                                  Watch: Core, Ambit 1, S7
                                  Extras: Garmin belt
                                  Phone: Samsung S30
                                  App: Latest beta
                                    Brad_Olwin Moderator @jw cou
                                    @jw-cou My issue with custom sport modes are autolaps. First, there is no way to turn off auto lap and I typically do not use or like the auto lap. It prevents me from using a custom mode for intervals as the auto lap interferes with the manual laps. My other issue with the watch is that I cannot get my HR zones correct because I cannot customize them again preventing me from using the watch seriously for training.
                                    aeroildA 1 Reply Last reply Reply Quote 3
                                    • aeroildA Offline
                                      aeroild Bronze Member @Brad_Olwin
                                      @Brad_Olwin I agree with you totally on the autolap/manual lap thing! When I run intervals I use the manual lap function. But if this lap approx. coincides with the auto lap, the screen will display the autolap info and when I push the lower right button the manual lap is not registered! Very annoying.
                                      The “personal” HR zones are another annoyance. Or rather, the misleading advertising. According to the Suunto 7 specs. on the Suunto page, the watch supports personal HR zones, but that is not true. It supports generic HR zones based on the set max. HR. I wish they wouldn’t mislead people like this.
                                      aeroildA 1 Reply Last reply Reply Quote 4
                                        Hmm…something doesn’t add up with the steps.
                                        Samsung Galaxy S24
                                          Ok, false alarm, the step count for yesterday was fixed during the night and shows correct steps.
                                          Samsung Galaxy S24
                                          • aeroildA Offline
                                            aeroild Bronze Member @aeroild
                                            @aeroild said in Suunto 7 update 30-06-2020:
                                            I need to correct myself and apologize to Suunto! When using the Running Intervals sports mode, which is the intended one for intervals of course, there is no auto laps and using manual laps work very well.
                                            J 1 Reply Last reply Reply Quote 3
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
