    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    POI creation problem
    Scheduled Pinned Locked Moved Spartan
    11 Posts 6 Posters 1.1k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ThomasRT Offline
      ThomasR
      As far as I understood, if one switched to the app, new POI’s still shall be created with movescount. Unfortunately, the later seems not to work. How do you solve this Problem?
      • D Offline
        dzemrau
        Try adding an altitude to the POI.
        • PrenjP Online
          Prenj
          Add altitude manually and it should let you save it. But remember to sync with cable, as Suunto app doesn’t offer syncing of anything from movescount to watch with mobile phone.
          Suunto Race
          • inkognitoI Offline
            inkognito Platinum Member
            Once you switch completely to the Suunto App, you loose the connection to Movescount. New POIs created in Movescount will no longer be synced to your watch. In fact, this transition makes the POI funtionality of the watch very limited… The only way to sync the POIs to your watch is to disconnect it from the Suunto App, pefrorm a hard reset and connect to Movescount again… Or you can wait and hope that Suunto is going to implement POI functionality to the Suunto App soon…
            SV: fingers crossed :D
            S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
            Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
            Despite some pretty bad luck, I still love Suunto!
            PrenjP 1 Reply Last reply Reply Quote 0
            • PrenjP Online
              Prenj @inkognito
              @inkognito said in POI creation problem:
              Doesn’t suuntolink sync settings done in movescount to watch?
              Suunto Race
              isaziI inkognitoI 2 Replies Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @Prenj
                @Prenj it should, if I understood it correctly.
                Blog: isazi's home
                  inkognito Platinum Member @Prenj
                  @Prenj It doesn’t, at least for me. To be sure, I tried to add multiple POIs right now. Connected the watch to the PC, Suuntolink optimized GPS and that’s all. Those POIs are not in the watch. Movescount says “New settings are not synced”.
                  PrenjP 1 Reply Last reply Reply Quote 1
                  • PrenjP Online
                    Prenj @inkognito
                    @inkognito
                    Maybe it has to do with watch model you own? My blind guess would be you are not using some ambit or traverse, but some spartan or S models?
                    Suunto Race
                    inkognitoI 1 Reply Last reply Reply Quote 0
                      @Prenj We are currently in Watches / Spartan category of the forum 🙂
                      • PrenjP Online
                        Prenj @inkognito
                        @inkognito
                        Sorry, wasn’t paying attention to it 🙂
                        So yes, that’s probably the reason for it. POI-s for post-ambit watches will be left with suunto app only. That’s the intention. Movescount, or whatever it’s going to be named in the future, will be used just for older watch models.
                        So if you care about POI-s, you better stay with movescount app/web combination until Suunto app gets POI-s.
                        Suunto Race
                        • C Offline
                          chrish Bronze Member
                          At least regardless of which watch forum you are in, the topic of partially crapped-out POI support applies. It’s just a matter of which POI feature you want and don’t have. Suunto is consistent if nothing else.
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
