    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HR issue
    37 Posts 11 Posters 4.6k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Willi CannellW Offline
      Willi Cannell
      I have S9 and smart sensor. Can anybody help me with this HR issue? Randomly during workouts the HR will jump to zone 5 and freeze there, often 190-200bpm. Sometimes it stops after a few minutes, sometimes it stays there for 20+minutes. I replaced the sensor batteries about a 2 weeks ago (~18hr of use since then). I’ve tried using performance mode and endurance mode. The watch is about a year old. Problem started happening about a month ago and is a consistent issue now. I didn’t see a post about this issue, if there already is one, pls refer me to it. Thanks, Willi
      isaziI 1 Reply Last reply Reply Quote 1
      • isaziI Online
        isazi Moderator @Willi Cannell
        @Willi-Cannell sounds like a strap issue. Do you have the old Suunto strap? And yes, discussed many times in the forum already 🙂
        Blog: isazi's home
        Willi CannellW 1 Reply Last reply Reply Quote 0
          Willi Cannell @isazi
          @isazi thanks! strap is 10 mo old. do you know if that’s the old one?
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Online
            @Willi-Cannell is the connector between pod and strap black or white?
            Blog: isazi's home
              @isazi black and says movesense on it
              • isaziI Online
                @Willi-Cannell black is the old one. Try to contact support.
                Blog: isazi's home
                  Willi Cannell
                  Thank you for the help! While I have you: do you know how often battery should be replaced in sensor pod?
                  isaziI Mff73M 2 Replies Last reply Reply Quote 2
                  • isaziI Online
                    @Willi-Cannell sorry, just got mine the other day so don’t know how long the battery lasts.
                    Blog: isazi's home
                    • Mff73M Offline
                      Mff73 @Willi Cannell
                      @Willi-Cannell said in HR issue:
                      I manage to keep a battery for almost 300h of effective workout. Long enough 😊?
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                      • zhang965Z Offline
                        zhang965
                        The level of battery can be checked with some app on your phone for example BLE tool.
                        And have you tried wash your belt? You should clean it if you not.
                        And polar’s belt works great with suunto watch, if you fed up with suunto strap, go grab a polar HR belt.
                        Winners Wear Winners
                        Mff73M 1 Reply Last reply Reply Quote 2
                        • Mff73M Offline
                          Mff73 @zhang965
                          @zhang965
                          Do you know if Polar belt (just belt) is OK with Suunto Smartsensor ?
                          Suunto new model belts are still out of stocks, and i can not so longer wait for a new one.
                          Wife : S9PP
                          cosme.costaC zhang965Z 2 Replies Last reply Reply Quote 0
                          • cosme.costaC Offline
                            cosme.costa @Mff73
                            @Mff73 No, is not compatible. The distance between connectors and the size of them are different. Suunto’s is more compact than the Polar.
                            • zhang965Z Offline
                              zhang965 @Mff73
                              @Mff73 said in HR issue:
                              @zhang965
                              I don’t know, I only use the Polar OH+ on arm, so I cannot give you the answer,
                              But what do you mean by new model belts?
                              there is a new one?
                              https://www.amazon.fr/Suunto-Ss021582000-Ceinture-cardiofréquencemètre-Noir/dp/B00V8B6S4M/ref=sr_1_10?__mk_fr_FR=ÅMÅŽÕÑ&dchild=1&keywords=suunto+belt&qid=1590645298&sr=8-10
                              I always have a backup belt.
                              Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 0
                              • Mff73M Offline
                                Mff73 @zhang965
                                @cosmecosta
                                Thanks.
                                @zhang965
                                Suunto has finally identified that their belts have some issues and have introduced a new design which should make them more reliable and durable.
                                One should recognize the ‘new’ design model, with the color of the brand/model marking on the belt (grey background) like there.
                                https://forum.suunto.com/topic/4140/which-hrm-chest-strap/35?_=1590646214269
                                Wife : S9PP
                                • Brad_OlwinB Offline
                                  Brad_Olwin Moderator @zhang965
                                  @zhang965 I have one of the new belts and @Dimitrios-Kanellopoulos has used his for over a year with no issues. If you order a black belt from Suunto you will get the new design, do not order a colored belt, they are the older design.
                                  Vector/T6c/Vertical 2 Ti
                                  Mff73M 1 Reply Last reply Reply Quote 1
                                  • Mff73M Offline
                                    Mff73 @Brad_Olwin
                                    @Brad_Olwin
                                    Currently, all belts are out of stock at Suunto.com. Since more than one month.
                                    Surely Covid root cause.
                                    Wife : S9PP
                                      Brad_Olwin Moderator @Mff73
                                      @Brad_Olwin
                                      I bought a new one recently, make sure to put your email in to be notified when a black belt is available then order. Mine came about one and one half weeks ago.
                                      Mff73M 1 Reply Last reply Reply Quote 0
                                      • Mff73M Offline
                                        Mff73 @Brad_Olwin
                                        @Brad_Olwin
                                        I put my email, but never receive one. Plus, I check regularly the site, and never see any stock. 😢
                                        Wife : S9PP
                                          @Mff73 Put the email in again, I did as soon as I got the notification I ordered.
                                          • herlasH Offline
                                            herlas Silver Members
                                            Is this the new version? SUUNTO Smart Sensor - AW16 https://www.amazon.com/dp/B00LVNEDDU/ref=cm_sw_r_other_apa_i_Rtc0Eb78RZD3G
                                            SRS Ti
                                            SRun (primarily road runner so testing SRun is a must ;))
                                            A 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
