    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 vs Google fit
    Scheduled Pinned Locked Moved Suunto 7
    14 Posts 6 Posters 1.5k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      meyton89
      hey all. My suunto says I ve just ran 6.29km in 41 minutes but Google fit says 5.9km in 43 minutes
      I did it as intervals.
      • M Offline
        meyton89
        Ok I ve just checked and this is happening each time. I ve done the run three times since I got this watch and each time my suunto 7 records one distance/time and google fit says another.
        Ok just checked my HR and its different too and its not because of a HR belt
        I use a Samsung galaxy s10 so its the android app
        • isaziI Offline
          isazi Moderator
          I’m recording an activity now to check.
          Blog: isazi's home
          • pilleusP Online
            pilleus
            Don’t worry, Google Fit is never correct! Sometimes the distance will be adjusted hours later in Google Fit. Sometimes. 😎
            https://www.instagram.com/moves.are.life/
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
            Suunto Spartan Ultra Stealth Titanium
            • isaziI Offline
              isazi Moderator
              After finishing the activity found out my Suunto recorded activities are not on Fit πŸ˜„
              Blog: isazi's home
              pilleusP 1 Reply Last reply Reply Quote 0
              • pilleusP Online
                pilleus @isazi
                @isazi if the sync to Fit is enabled, it can take up to two or three hours until the activity is showing up in Google Fit. 😲
                M 1 Reply Last reply Reply Quote 0
                • M Offline
                  meyton89 @pilleus
                  @pilleus its the same activity mostly. The map everything is the same. The stats however are not. I ve done the same route 3 times in the last couple of weeks and the stats are different between the two apps each time
                  • pilleusP Online
                    pilleus @meyton89
                    @meyton89 you can sync from Suunto to Strava and resync with SyncMyTracks to Google Fit. Then the data will be correct. Always. πŸ‘
                    M EgikaE 2 Replies Last reply Reply Quote 0
                    • M Offline
                      meyton89 @pilleus
                      @pilleus I only use Google fit because of the limitations of the Suunto app. If Strava takes it all then I will stick to stravaπŸ‘
                      • pilleusP Online
                        pilleus @meyton89
                        @meyton89 no steps, no 24hr heart rate in Strava, only activities. Suunto wear app, Strava and Fit are needed to have all data in Fit.
                        • EgikaE Offline
                          Egika Platinum Member @pilleus
                          @pilleus said in Suunto 7 vs Google fit:
                          Is there a reason why not to sync from Suunto App to Fit directly using Syncmytracks?
                          pilleusP MO92119M 2 Replies Last reply Reply Quote 0
                          • pilleusP Online
                            pilleus @Egika
                            @Egika no, it’s possible too. But it’s new and I didn’t change it until now.
                            For me it’s different, because I use Suunto Spartan Ultra, Ticwatch Pro 2020 and Amazfit Stratos 3 for different sports. And all watches sync to Strava and then I use SyncMyTracks to sync to Google Fit.
                            • MO92119M Offline
                              MO92119 @Egika
                              @Egika I sync like that (without using Strava), and it’s working fine.
                              • masi0M Offline
                                masi0
                                Guys, there is setting in Google Fit to enable automatic fitness tracking - do you have this option turned on?
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
