    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS and heart rate way out now
    Scheduled Pinned Locked Moved Spartan
    gpsheart ratefail
    20 Posts 9 Posters 4.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • James HillJ Offline
      James Hill
      Hi everyone, getting really pissed off with my Spartan Sport Wrist HR now. It was always great before, but now the GPS tracking and heart rate are not accurate at all.
      I always run with it at Best accuracy, and with GLONAS turned on. And always sync it with the app for GPS optimization an hour or so before my run. I also run with a suunto heart chest strap, and moisten the pads and wear it tight enough it doesn’t slip.
      When I start a run, the watch always finds GPS and heart strap straight away, and before I start the run.
      The GPS is recording a 5.5km run as 5km, and in the first 15 mins or so it is recording my pace as about 11min/km, when I’m easily running a 5 or 6 min/km pace.
      Also, you can see my heart rate data in the attached image. It’s fine for the first half, the jumps up by a huge factor, showing my heart rate as 250 or something.
      I’ve talked to suunto on the phone. Done the soft reset and hard reset and no change.
      I’ve loved suunto up to now, but this is getting ridiculous now. What has happened??
      Anyone got any ideas? Cheers!
      Ps. Can’t figure out how to upload an image
      cosme.costaC R 2 Replies Last reply Reply Quote 0
      • cosme.costaC Offline
        cosme.costa @James Hill
        @James-Hill said in GPS and heart rate way out now:
        For the GPS I can’t help you, but I would try without GLONASS in my experience I got worst results than with only GPS. Some link to the activity with good GPS and other with bad would help.
        Regarding the HR, you have to change the belt, 99.9% sure. There are some threads in this forum talking about that. There is a new version of the belt, check this one or buy a Polar H10 and issues solved.
        Saketo NemoS 1 Reply Last reply Reply Quote 2
        • Saketo NemoS Offline
          Saketo Nemo Moderator @cosme.costa
          Try change battery before.
          I’ve tested h10 and new suunto belt either, my advise is the second one
          • R Offline
            RiphRaph Bronze Member @James Hill
            @James-Hill Suunto chest straps are notorious for failing quickly. I bought one last January and in under two months it was giving me the same off-the-scale readings as you’re getting. Luckily I was able to return it, and I now use a Polar H10, no more problem.
            Formerly Spartan Sport WHR, happy Coros Vertix user since Sept. 2020
            Saketo NemoS 1 Reply Last reply Reply Quote 1
              Saketo Nemo Moderator @RiphRaph
              @RiphRaph
              What you say was true, but for some months now the belts have changed and are back to being reliable.
              In my experience, the H10 has progressively decayed, in order to constantly provide me with junk data, despite changing batteries, resetting and updating firmware. Polar support also turned out to be terrible.
              But hey, again, that’s only mine experience 😉
              MatthiasKlugM 1 Reply Last reply Reply Quote 0
              • MatthiasKlugM Offline
                MatthiasKlug @Saketo Nemo
                @Saketo-Nemo
                Hi, i have exactly the issue and solution, I bought a polar h10
                i have heard about the new suunto heart rate belt and i would like to buy one BUT unfortunately they are out of stock …
                Suunto Race 2 - Software 2.50.26
                Suunto Vertical - Software 2.44.52
                App 6.6.3
                Google Pixel 8a - Android 16
                formerly used:
                S9 Baro Firmware 2.23.24
                SSU-Firmware 2.8.32
                1 Reply Last reply Reply Quote 3
                  DAMN corona !
                  • ___Alejandro____ Offline
                    ___Alejandro___
                    Hi, I can’t comment on the GPS bit, but most definitely can on the HR belt. Polar H10 if you want rock-solid reliability and longevity. I went through three Suunto Smart sensor to one H10 – and it’s still going strong. All the best.
                    L 1 Reply Last reply Reply Quote 1
                    • L Offline
                      loopylou72 @___Alejandro___
                      @Alejandro I switched from 3 suunto HR belts and am now on HR10 number 3! It works great when it works but I keep getting reading drop outs - has this happened to you? Works fine then suddnely down to around 50… I have tried all the tips. If I take off the module and put it back on then it works - but this is useless in a race or hard training run and just annoying to keep having to do on runs. Anyone else had this problem?
                      ___Alejandro____ EgikaE cosme.costaC 3 Replies Last reply Reply Quote 0
                        ___Alejandro___ @loopylou72
                        @loopylou72 Hmmm, that’s a lot of HR belts ya went through… Sounds like you’re a very heavy user – maybe you’re just one of the unlucky ones that go through 'em regardless? Were all the belts reading off of the same watch? Maybe there’s the issue? Otherwise, I’ve no idea. Sorry!
                        L 1 Reply Last reply Reply Quote 0
                        • EgikaE Offline
                          Egika Platinum Member @loopylou72
                          @loopylou72 maybe something else in the system is the underlying problem. How do you wear the belts (position, wet/dry, shirt material, weather etc)?
                            cosme.costa @loopylou72
                            @loopylou72 I have used a lots of suunto straps, then I switched to the polar H10 and now I’m using the polar OH1.
                            In my case, the behavior with the Suunto smart sensor was high spikes (over 200 bpm) when the strap was starting to fail, you can clean it but in a few runs it is out again, then with the polar H10 when it started to fail instead of spikes I got sudden drops, first I thought it was the strap but it was the battery that was starting to be low (the polar H10 has quite high battery consumption). I had to ditch the chest straps due the bruises that they proke me and I switched to the polar OH1 and I’m pretty satisfied with it, the downsizes, in my opinion, are that the battery doesn’t last much and that the reactions in HR changes are a bit slower that with the chest straps.
                            • L Offline
                              loopylou72 @cosme.costa
                              @cosmecosta thanks for this - the Polar app says the battery is full but maybe the app is incorrect. I will change it and see. Is the OH the arm band? Do they work OK? thanks for responding!
                              cosme.costaC 1 Reply Last reply Reply Quote 0
                              • L Offline
                                @Alejandro 3 suunto HR monitors - just got them replaced when they failed then gave up and bought the polar. Worked fine and then starts to drop. Polar also replaced it - twice… now am giving up on Polar! Yes I run about 100km+ a week and use it on every run.
                                ___Alejandro____ 1 Reply Last reply Reply Quote 0
                                • L Offline
                                  loopylou72 @Egika
                                  @Egika yes have tried different positions, back to front even. Different watches, gel/saliva! Maybe it is my heart!
                                    @loopylou72 said in GPS and heart rate way out now:
                                    Yes it is the arm band, and for me it works OK, I’m using it for more than a month.
                                    S 1 Reply Last reply Reply Quote 0
                                      @loopylou72 The only other thing I can think of is that I always disconnect the H10 sensor from it’s belt after every activity, as it tends to rinse-out the battery (not sure if it’s still maintaining a Bluetooth connection after the activity), and a failing battery would also make the HR reading drop way lower than it should (but I’m assuming that Polar support would have tried that with you before sending you new ones?).
                                      Or maybe it’s just your super-efficient-Tony-Stark-like-iron-man heart, for the win. 🙂
                                      Otherwise, like cosmecosta says, try a Polar OH1 or a Scosche Rhythm+ . I prefer the chest belts, but they may work out better for you. Happy Hunting!
                                      • S Offline
                                        Shrek3k @cosme.costa
                                        @cosmecosta said in GPS and heart rate way out now:
                                        I am a Wahoo Tickr Fit (armband) user for more than 15 months now (3-7 runs a week, up to 100km/week) and very satisfied with the performance and comfort. I can most certaibly recommend these armbands - as can my wife who is using one, too. Before that I used a Scosche Rhythm Plus armband, but the battery time of the old version is too short. Otherwise recommended, too , although the newer Scosche Rhythm 24 should be better (but is too expensive and hard to find in Germany)
                                        using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                                        OS - Android 16/Pixel Pro 7
                                        • L Offline
                                          @Alejandro thanks I used to take the module off but then wondered if that made any difference and got lazy! I will do it every time! I changed the battery today even though the Polar app says it is full… thanks so much for the help hopefully this will do the trick!
                                          • L Offline
                                            loopylou72 @Shrek3k
                                            @Shrek3k thanks for the info!
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
