    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 BARO not saving last settings in sport mode.
    14 Posts 6 Posters 993 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      Martin Tuharský
      The watch does not save the last setting in sport mode. I want to turn off the heart rate measurement from my wrist and turn on the chest strap in the sensors. During the next training, I have to turn on the chest belt search again in the settings.
      Suunto T3
      Suunto T6
      Suunto Ambit 2
      Suunto Ambit 3S
      Suunto Ambit 3 Peak
      Garmin Fenix 5
      Suunto 9 Baro
      Coros Vertix 2
      Suunto Vertical
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Martin Tuharský
        @Martin-Tuharský That is by design, you do not need to turn off wrist HR, if the strap is there the watch will use the belt and not wrist HR
        Vector/T6c/Vertical 2 Ti
        • M Offline
          Martin Tuharský
          Thank you for answer. I need the chest strap search always on and when I don’t have it so that my heart rate isn’t measured at all. If I turn on the chest strap search, this option is turned off again during the next workout.
          Suunto T3
          Suunto T6
          Suunto Ambit 2
          Suunto Ambit 3S
          Suunto Ambit 3 Peak
          Garmin Fenix 5
          Suunto 9 Baro
          Coros Vertix 2
          Suunto Vertical
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Martin Tuharský
            @Martin-Tuharský you don’t actually need to play with the configuration. If your S9 is connected with a chest strap, and that happens automatically if they are paired and the chest strap is on, it will use that one. If you want OHR, don’t wear the chest strap. If you don’t want anything, do not wear the strap, plus disable the OHR from the settings.
            Blog: isazi's home
            M 1 Reply Last reply Reply Quote 2
            • M Offline
              Martin Tuharský @isazi
              @isazi I’ll try again with the pictures.
              Number one.
              I will select the sports mode.
              Number two.
              She is not looking for a chest strap.
              Number three.
              The wrist pulse is turned off. That’s how I want to leave. This is fine.
              Number four.
              For sensors, the chest strap search is switched off.
              Number five.
              I’ll turn it on.
              Number six.
              She is looking for a chest strap.
              After the end of the activity during the next training, the search for the chest strap is switched off again.suunto 9.jpg
              Suunto T3
              Suunto T6
              Suunto Ambit 2
              Suunto Ambit 3S
              Suunto Ambit 3 Peak
              Garmin Fenix 5
              Suunto 9 Baro
              Coros Vertix 2
              Suunto Vertical
              freeheelerF isaziI 2 Replies Last reply Reply Quote 0
              • freeheelerF Offline
                freeheeler @Martin Tuharský
                @Martin-Tuharský
                go to the menu, settings, connectivity, pair sensor and your watch should remember your chest belt 👍
                living sideways
                Brad_OlwinB 1 Reply Last reply Reply Quote 1
                • Cuba1hrC Offline
                  Cuba1hr
                  I have a question and probably know the answer…I haven’t tested.
                  If you use chest belt and leave OHR ON, will it drain battery more with that setting than OHR OFF?
                  I turn it off always. I don’t know if the green LEDs turn on then, probably not.
                  freeheelerF 1 Reply Last reply Reply Quote 0
                    freeheeler @Cuba1hr
                    @Cuba1hr
                    what’s your guess?? 🙂
                    spoiler alarm: it uses less battery… it also shows the estimated left battery runtime
                    living sideways
                    • Cuba1hrC Offline
                      Cuba1hr
                      😂 That’s why: “(…) probably know the answer.”
                        Brad_Olwin Moderator @Cuba1hr
                        @Cuba1hr @TELE-HO @Martin-Tuharský correct, it will use more battery to leave OHR on. However, there are a couple of bugs IF you turn OHR off. 1. Progress bar for target distance an duration will not work. 2. SuuntoPlus summary after exercise will not be displayed. So, your choice. These should get fixed with the next update, hopefully.
                          Brad_Olwin Moderator @freeheeler
                          @TELE-HO @Martin-Tuharský you will not have to pair the belt again. It is remembered and if on your chest will override OHR. Hope that makes it clear.
                          • Cuba1hrC Offline
                            Cuba1hr
                            @Brad_Olwin said in Suunto 9 BARO not saving last settings in sport mode.:
                            I saw that, on YT video posted here on forum. I will test that with and without OHR…and get the same result:)
                            Next update, hopefully, that’s all we have.
                            • EgikaE Offline
                              Egika Platinum Member @Brad_Olwin
                              Why would that be?
                              If the LEDs don’t light up since a chest belt is connected, why would just the setting of optionally use the WHR make a difference in battery consumption?!
                              • isaziI Offline
                                @Martin-Tuharský I don’t have to do all that, my chest hr monitor and stryd connect automatically.
                                Blog: isazi's home
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
