    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 GPS very bad and often without signal
    gpssuunto 9
    18 Posts 10 Posters 3.3k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hello,
      my wife and me bought a Suunto 9 each on the same day in Dec 2019. We always run together. So we can compare both watches. Let me call my whatch S9-1, the other S9-2. Both are updated frequently. My whatch S91 needs sometimes 7 minutes to find the gps whereas S92 finds it within seconds. Also, during running S9-1 loses GPS signal for a couple of km while S9-2 continues measuring.
      Yes, I did rest the whatch several times.
      Yes, I run updates.
      Yes, I synchronise my S9-1 with my smartphone before running.
      I think, it is just broken.
      Anyone has an idea? Same experience.
      Many greetings
      Mff73M isaziI Brad_OlwinB Saketo NemoS 4 Replies Last reply Reply Quote 0
      • Mff73M Offline
        Mff73 @Guest
        @running-L
        It seems you have all arguments to send it back to Suunto for repair or exchange.
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        • isaziI Offline
          isazi Moderator @Guest
          @running-L I can only suggest a hard reset, but I agree with @Mff73 you should contact support and have your watch checked.
          Blog: isazi's home
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Guest
            @running-L Check Settings/General/About and ensure you have a current AGPS file. It simply seems that the file is not getting synced to the watch. Let me know the data on the AGPS file or if it says NA/
            Vector/T6c/Vertical 2 Ti
            • zhang965Z Offline
              zhang965
              Return it to suunto to get repair.
              Winners Wear Winners
              freeheelerF 1 Reply Last reply Reply Quote 1
              • freeheelerF Offline
                freeheeler @zhang965
                @zhang965
                sorry for being offtopic…man where did you hide? I’ve missed your inputs 😀
                ontopic: yes, send it in, mine has signal within seconds… even before it detects my cold heart…
                living sideways
                • T Offline
                  tomahawk5000
                  Hi, in my Suunto I have that situation that once I open navigation then show my location then I have to wait much more than once I go to exercise and I chose any training. Is it normal?
                  Kind regards,
                  Tomek
                  Suunto 9 baro -> Vertical 2
                  • sartoricS Offline
                    sartoric Moderator
                    Did you check what @Brad_Olwin suggested a couple of post above ?
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.10.7 beta
                    • T Offline
                      tomahawk5000
                      Yes but I don’t see connection (maybe because of my poor English… Sorry)? AGPS is from 20th. Still not sure why location is quick once I chose exercise but once I chose my location from navigation it take much more time
                      Kind regards,
                      Tomek
                      sartoricS 1 Reply Last reply Reply Quote 0
                      • sartoricS Offline
                        sartoric Moderator @tomahawk5000
                        @tomahawk5000
                        Oh,ok. So it’s quick for exercise, but slow for navigation.
                        Anyway, agps is up to date ?
                        Did you try a soft reset ?
                        SVTS - 2.50.28
                        T 1 Reply Last reply Reply Quote 0
                        • T Offline
                          tomahawk5000 @sartoric
                          @sartoric
                          AGPS is up to date 20th of April
                          Regarding soft reset yes few times mostly due to the issue with notification with calling.
                          Kind regards,
                          Tomek
                            Brad_Olwin Moderator @tomahawk5000
                            @tomahawk5000 said in Suunto 9 GPS very bad and often without signal:
                            Why are you opening Navigation? when you start an exercise, the GPS icon will go from unfilled to colored when a GPS fix is achieved, there is no need to go to Navigation first.
                            T 1 Reply Last reply Reply Quote 1
                            • Saketo NemoS Offline
                              Saketo Nemo Moderator @Guest
                              @running-L
                              Same settings of GPS ? (only GPS, GPS+glonas/beidou/galileo).
                              And of course, both are setted on GPS best, right?
                              all obvious things but … I try to help 😉
                              • T Offline
                                tomahawk5000 @Brad_Olwin
                                @Brad_Olwin it was just an example with different fix achieve between find my location in navigation and exercise
                                Kind regards,
                                Tomek
                                Fenr1rF Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                • Fenr1rF Offline
                                  Fenr1r @tomahawk5000
                                  @tomahawk5000 Are you using a national grid system for location coordinates or the GPS Lat/Long default?
                                  • T Offline
                                    tomahawk5000
                                    Not sure how to check that?
                                    Compass unit - degrees
                                    Position format - wgs84 hd°m’s.s
                                    Kind regards,
                                    Tomek
                                    Fenr1rF 1 Reply Last reply Reply Quote 0
                                    • Fenr1rF Offline
                                      @tomahawk5000 If you haven’t changed the settings, then that’s the default and it certainly looks right. I was wondering whether conversion to a particular local format might be causing problems.
                                      Without the possiblity of a problem with that extra stage, I agree that a user should see the fix results, whether for recording Exercise (filled arrowhead) or Navigation (coordinate display) within essentially the same timeframe from either request.
                                      Not for me, but possibly for anyone Suunto-side: how much longer (in seconds) does a Nav fix take vs an Ex? Same-ish margin regardless which method tried first?
                                        @running-L It does sound like you may have a hardware issue, I have two S9s and they both fix very fast and rarely (I cannot remember the last time) lose a GPS fix during an exercise. It is possible when in areas that are difficult for GPS (deep canyon for instance). But, I did not get a GPS error when running a race early in March where there was a slot canyon. I would start a support ticket.
                                        Register Login
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
